Results 1 to 8 of 8
    Thanked: 42
    Default Which Pool Solar Heating?
    Hi
    I am looking to recommission the solar pool heating system at our house.
    The basics are all still in place, the pipes were capped and panels removed due to extensive damage when we moved in - I require a fitting kit which varies wildly in cost from R1k to R4k and panels.
    From my research this is easily DIY'able with plenty of suppliers.
    The question is which brand to go for? There appear to be three basic flavors with varying countries of origin (I am leaning heavily towards "triple" or high density panels to save space for solar panels later):
    Heliocol - Apparently imported from Israel by ITS Solar (Lifetime (?) warranty/12 Year Guarentee) - R16k
    HiTemp - High density panels (10 Year warranty) - R10k
    http://www.solarpoolheatingsa.co.za/ - Awaiting Quote but basically R1500/panel
    Sun Command - Available form Lex Pools (5 year warranty) - Awaiting quote
    Generic Spaghetti panels - Up to double density
    I was surprised that I couldnt seem to find an SA manufacturer (?)
    Recommendations and opinions on the above welcomed!
    David
    P.S. The pool is 40 000l (8x4x1,25(avg)) and with a distance of 15m from pump to house with the riser requiring an addition 2.5m.
    Dec 2014
    Thanked: 96
    The Sun Command panels are manufactured in SA. LEX Pools is a very reputable installer.
    Solid panels retain and transfer heat much better than the spaghetti type since there is no vacant space.
    Jack
    2005 Discovery 3 V8 HSE - 🤩
    2004 Discovery 2 TD5 GS - sold
    1996 Discovery 1 5.7lt Chevrolet 🤤 - sold
    1994 Defender 110 Hardtop 3.9 Auto Conversion - sold 🤑
    Thanked: 42
    Default Re: Which Pool Solar Heating?
    Thanks Jack, great info will check them out!
    Mar 2013
    Boksburg
    Thanked: 7
    Hi
    Proauto Rubber sell an SA version.
    Rubber pipe type.
    https://parmegastore.com/
    I had a heliocoil for years.
    The panels was damaged by hail after the warrantee expired.
    Would recommend Heliocoil.
    The rubber type panels give off on the inside thus blocking the tubes after a couple of years
    My lorrie: 2014 Toyota Hilux 4x4 D4D M
    Vrou se platkar: 2006 Polo Sedan 1,6
    4x4 Trailer: Echo 4
    EX: Amarok BTDI DC
    Thanked: 220
    Get the Hitemp version, they sell a DIY kit. https://hitemp.co.za/product/diy-panels-kits/
    Touareg V10
    KTM 1290 Super Adventure R
    Jun 2013
    Thanked: 3152
    Have a look here, these guys are brilliant and very good prices.
    https://xtremesolar.co.za/solar-pool-heating/
    Stranger
    BMW R1200R
    Mar 2007
    Thanked: 26
    Quote Originally Posted by SpiderGear View Post
    Also using the Hi-temp system. I can recommend the diy option
    Mar 2011
    Walker Bay
    Thanked: 1531
    Make sure you install enough panels.
    We lived in a windy area and the solar made
    our pool a real pleasure to use.
