Results 1 to 18 of 18
Thread: 12 V fan ?
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 1766
    Default 12 V fan ?
    Looking for a free standing , oscillating fan , running off 12v to cover a small lounge ?
    Any suggestions, thanks.
    Ford Figo 2016
    Kriel
    Thanked: 226
    Default Re: 12 V fan ?
    You can use a 230v fan with a dc to ac inverter as well... Just saying it's an option...
  3. The Following User Says Thank You to John.oosthuizen95 For This Useful Post:
    Aug 2008
    Harties
    Thanked: 681
    I have a Liesurequip 12V fan.
    Look here - I think this is what you want.
    If you make a noise or need music in the bush or on the beach, you’re missing the point.
    Aug 2008
    Thanked: 1766
    Quote Originally Posted by PRA View Post
    Thanks, little fancy and pricy but well worth looking at if needs be
    Ford Figo 2016
    Aug 2008
    Thanked: 1766
    Quote Originally Posted by John.oosthuizen95 View Post
    Thanks, I have 2 perfect 220v fans so this idea could well work if the converter idea pans out. What should I look for?
    Ford Figo 2016
    Gaborone, Botswana
    Thanked: 1794
    What is the intended application?
    Camping?
    Load Shedding?
    Kobus
    Aug 2008
    Thanked: 1766
    Camping?
    Load Shedding?
    Morning Kobus. I have a 12 volt setup in house lounge running off solar. Very hot in Summer. Have various 220 fans but thinking of saving money by using the battery as well as keeping it busy as it only powers led lights at night .
    Ford Figo 2016
    Gaborone, Botswana
    Thanked: 1794
    Morning Duncan.
    I'm running a cheap 30cm 35Watt 220V Desk fan off a Mecer inverter. Slight hum when on the inverter but it can go on for hours without a problem.
    Kobus
  10. The Following User Says Thank You to KobusDJ For This Useful Post:
    Aug 2008
    Thanked: 1766
    Morning Duncan.
    Yes, I have the inverter setup all working great but my Mecer inverter from 10 years ago has a very noisy fan. Only use it when load shedded. Wife sits nearby to watch tv during the day so a pain in the bum.
    Will go to OW and have a squizz
    Ford Figo 2016
    Sep 2008
    Vanderbijlpark
    Thanked: 293
    220V fans do not like modified sinewave inverters a lot. The fans run noisily and at reduced speed. (induction motors)
    12V fans are the way to go IMO.
    ZS6VL
  13. The Following 3 Users Say Thank You to An3s For This Useful Post:
  14. #11
    Thanked: 69
    how big is that unit ?( ah i see 16 inch ), I am thinking use in a rooftop tent but the size might be an issue .
    I have a usb driven fan that is small enough but i doubt it will be strong enough in serious heat.
    Boat shops for yachts might have some options but they will be pricier than the Leisurequip i'm sure
  15. #12
    May 2014
    Tshwanetoria
    Thanked: 1360
    I am yet to find a 12v fan that is not noisy, and that is efficient.
    For camping purposes that may work, but in the lounge?
  16. #13
    [REMOVED]
    Thanked: 342
    I have this for camping and it works great. Think I paid R400 for it at Montana Traders. It runs fine off a 30watt solar panel.
  17. #14
    Thanked: 1609
    Cash Crusaders sell some nice USB fans that are quiet and will run all day off a USB battery bank. They are pretty small but move a decent volume of air, they don't oscillate but maybe just get 2 or 3 of them.
    Edit. They have 3 sizes if I remember correctly, one small one with an integrated battery, medium sized and then slightly bigger, all around a R100 each give or take.
  18. The Following 2 Users Say Thank You to Skylark For This Useful Post:
  19. #15
    Aug 2008
    Thanked: 1766
    Quote Originally Posted by MartinClem View Post
    Wife saw the fans in that yacht on tv show, SV Nandji
    Ford Figo 2016
  20. #16
    Sedgefield
    Thanked: 121
    We use one of these in our caravan, not to noisy and does a good job.
    https://www.midas.co.za/pebble.asp?relid=143715
    Toyota
    2019 Toyota 2.8 GD-6 4x4 Raider DC Auto
  21. #17
    Aug 2008
    Thanked: 1766
    Quote Originally Posted by Iggi View Post
    Thanks, worth a look and only 5 minutes from here.
    Ford Figo 2016
  22. #18
    Wartburg
    Thanked: 2702
    Silent 12V fans are not cheap. A few years back I bought quite a few in a quest to find a silent one which moved "enough" air. The pedestal fans above were not on the market at the time, so don't know how they compare? I ended up importing a few Caframo Ultimate fans at about R1k each. They move decent amounts of air at the least noise levels of all tested. Not oscillating though.
    For your application I would invest in a small pure sinewave inverter. You will still spend more than the first pedetsal fan above though.
    Mike Lauterbach
  23. The Following User Says Thank You to mikeml For This Useful Post:
