Results 1 to 13 of 13
    Apr 2019
    Thanked: 66
    Default 2.4gd6 hilux manual problems
    Hello i have a 2.4gd6 4x4 hilux 6 speed manual with 85 000km.
    Gearbox shifts badly to 2nd and alright to 3rd. So i had the car now at a gearbox place . The checked the synchros, bled the clutch , (had toyota previously check the gearbox linkages). While they were there i told them to replace the 2nd and 3rd synchro even though the old set looked 100percent. Long story short gearbox feels exactly the same after the new synchros.
    So my guess is the clutch , the workshop said the clutch has about 50% life left. If i remember correctly the car felt easier to shift into gear when i was driving on farm roads than it was on tar , earlier this year. Little tire slippage helps with shifting
    What do you guys think ?
    1996 300tdi Defender 110
    2017 2.4gd6 Hilux 4x4 DC Manual
    Thanked: 19844
    Default Re: 2.4gd6 hilux manual problems
    What gearbox oil?
    Jakes Louw
    Apr 2019
    Thanked: 66
    What gearbox oil?
    This problem has been the same with toyota mt gear oil , castrol bot 402 and now total .
    Thanked: 19844
    Quote Originally Posted by Niela View Post
    Just seeing what has been eliminated so far.
    Then your guess could be correct. Although it is strange that it's only one gear.
    Jakes Louw
    Apr 2019
    Thanked: 66
    Just a summary:
    Toyota checked the linkages.
    Gearbox workshop replaced 2nd and 3rd synchro even though they looked 100 percent , they also said gearbox looks very good inside.
    Gearbox workshop bled the clutch system.
    Have been through 3 different oils , still same issue.
    Thanked: 19844
    My advice is don't sell the 300tdi...........
    Jakes Louw
  7. The Following User Says Thank You to jelo For This Useful Post:
    FWM
    Jun 2016
    Randfontein
    Thanked: 5831
    Is the sticky shifting the same when hot and cold?
    Willie Knoetze
    2019 Nissan NP300 2.5tdi d/c 4x4
    Apr 2019
    Thanked: 66
    Marginally better after hot.
    Henties
    Thanked: 2184
    Does it make any difference whether you shift up, from 1st to 2nd, or down from 3rd to 2nd?
    2012 FJ Cruiser
    1983 FJ60 Landcruiser -sold-
    Thanked: 309
    Maybe check where the gearlever enters the gearbox - some boxes have a nylon bush/ball that can wear out.
    And sommer get some.Unihlide from Henri Stoffberg to make sure everything inside the box is as smooth as can be.
    Si vis pacem, para bellum
  12. The Following User Says Thank You to thabogrobler For This Useful Post:
    FWM
  13. #11
    Apr 2019
    Thanked: 66
    1st to 2nd is rough , 3rd to 2nd is smooth.
    Double clutching makes no difference when upshifting.
  14. #12
    Nigel
    Thanked: 2728
    Laugh at me if you want to, but try 5% Uniglide FRC in that box. Plenty of evidence of how well it works.
    Uniglide
    +27 zero eight 2 four 95 9252
  15. The Following User Says Thank You to Henris For This Useful Post:
    FWM
  16. #13
    Apr 2019
    Thanked: 66
    Anybody know of a good toyota gearbox specialist to help solve this problem ?
