Results 1 to 20 of 29
    Feb 2013
    Thanked: 2104
    Default GD6 2.4 vs 2.8 fuel consumption.
    Hi all, anyone with real life experience, consumption between the 2.4 and 2.8?
    Like for like, Fortuner vs Fortuner, SC vs SC, DC vs DC.
    I'm actually mostly interested in Fortuner auto 4x4, but I think any of the others should help color the picture.
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
    Thanked: 2529
    Default Re: GD6 2.4 vs 2.8 fuel consumption.
    My wife has a fortuner 2.8 4x4, but the 2020 model. I doubt she gets much under 12l/100km. I have just procured a Hilux 2.8 4x4 and it is getting around 8.6. The main difference is obviously driving style. Both are autos.
    Mar 2012
    Ballito
    Thanked: 707
    Vehicle as per signature.
    265/65/17 AT3Gm tyres since the beginning
    Roofrack as per: https://www.4x4community.co.za/forum...oofrack-build)
    2" Spacer lift in front.
    ZS5CMA
    His: '17 Hilux GD-6 4x4 A/T ~135000km
    Hers: '19 Mitsu Eclipse Cross ~ 35000km
    Semi-retired: '12 Polo BlueMotion ~350000km
    Burned to a crisp: '05 WJ 2.7CRD
    https://www.instagram.com/fstopza/
  4. The Following User Says Thank You to cainslie For This Useful Post:
    Mar 2015
    Thanked: 838
    You will also need to distinguish between the 130 kW and 150 kW 2.8. The 150 kW is heavier on juice by a fair amount.
  6. The Following 2 Users Say Thank You to Tom13 For This Useful Post:
    Thanked: 7177
    My 2.8 Fortuner hovers at 11.5 - 11.8 l/100km purely city driving. But I don't drive like a granny, and the older I get the heavier my foot seem to get.
    Open road, cruising on speed control it easily goes down to below 7L/100. Not towing of course.
    Christa
  8. The Following 2 Users Say Thank You to lekhubu943 For This Useful Post:
  9. #6
    Alicedale
    Thanked: 56
    Quote Originally Posted by Tom13 View Post
    thatís odd - I find the 150kw engine much the same on the high way and towing the boat about 1km/l better.
    '21 Hilux 2.8 Auto 4wd
    '19 Fortuner 2.8 Auto 4wd
  10. The Following User Says Thank You to Bryan Webber For This Useful Post:
  11. #7
    Feb 2013
    Thanked: 2104
    Quote Originally Posted by lekhubu943 View Post
    Have you measured while towing on tar?
  12. #8
    Feb 2013
    Thanked: 2104
    Quote Originally Posted by Bryan Webber View Post
    If I recall the 150 kW should be lighter than the 120 kW according to Toyota specs whatever that's worth.
    I actually forgot about the 120 vs 150, in general how do you find the difference between the 2 in general daily driving and then towing?
  13. #9
    Thanked: 7177
    Going by the on board computer only, which is pretty accurate, it has never been above 13 as far as I can remember. On tar.
    Christa
  14. #10
    Dec 2012
    PMB
    Thanked: 627
    Agreed, the 150KW is definitely more economical.
  15. The Following 2 Users Say Thank You to TOY4X4 For This Useful Post:
  16. #11
    Alicedale
    Thanked: 56
    Daily driving the 150kw is more energetic right through the rev range. The towing it also feels stronger even considering my previous was chipped with a pipe by KSD.
    The biggest difference I’ve found is the following:
    - Way better cooling, both FT and previous Hilux viscous fans would kick in on most uphills. (2.7 ton boat and trailer) my 150kw viscous prob has kicked in twice when towing the boat on a hot day on the same routes.
    - bigger turbo seems to give it more torque/power in the higher rpm. The fortuner and previous hilux both eventually chipped with a pipe always seemed to loose steam at 3500rpm up. My old lady has a stock 2.8 and after driving it yesterday for the first time in a while I’m taking it to ATN to be mapped.
    - then the gearbox. The lock up points are lower on the 150kw. The TC actually locks up compared to my previous hilux which would hardly ever get into 6th. Shifting points seem better and I would say this is likely the biggest difference between the two. Still - I would prefer the manual but the box is improved.
    if you have a google you will note there were Changes as I have found above.
    overall economy compared to chipped 2.8’s is much the same. All 3 of our 2.8’s get 8.5km/l up to 9.5km/l driven really well.
    the previous hilux would give around 5km/l towing the boat on the same route over 130km and the new one around 6km/l. Difference could be because of the gearbox, but I normally lock them in 4th the entire trip.
  17. The Following User Says Thank You to Bryan Webber For This Useful Post:
  18. #12
    Mar 2015
    Thanked: 838
    I went back to a 2016 test of a 130 kW Fortuner Auto and compared it to a Feb 2021 test of a 150 kW Fortuner Auto by CAR magazine.
    Toyota claimed figure 2016: 7.6 L/100km
    Toyota claimed figure 2021: 8.9 L/100km
    Fuel route test 2016: 9.1 L/100km
    Fuel route test 2021: 11.1 L/100km
    So Toyota also agreed that the 150 kW is heavier on juice by 1.3 L/100km on the claimed figure. In real life it is even heavier by 2.1 L/100km in mixed driving on a controlled route.
    For interest sake the 2021 Fortuner was 0.7 seconds faster to 100 km/h and 0.8 seconds faster between 100 and 120 km/h.
  19. #13
    Thanked: 2529
    Just been driving with my wife in my new Hilux and I can see why we get massively different consumption. Her fortuna is a 2020 so 130kw and Mine is 150kw. If I drive mine, I am getting around 8.6l/100km. When she drives it it is more like 12.5l/100km.
    I think how you drive and how many things you do to the vehicle will make a bigger difference than the 2.4 vs 2.8. I am interested to see Bryanís impressions on towing a big boat. I have only towed mine on flat roads around dbn to the ski boat club and back so far. Next time I am down there, will probably try out umkomaas and see how it does on some rolling hills.
    I am sure it will have to work a lot harder.
  20. #14
    Aug 2020
    Oasis
    Thanked: 7022
    Comparing the fuel consumption of different Fortuners are like comparing facial hair on models
    Willem Greyling
    "You too need a new signature" - Hedgehog
  21. #15
    Thanked: 2529
    Quote Originally Posted by MANDREAS View Post
    Go and buy the V6 Amarok already!
    Edit - or better yet, a 100k mountain bike!
  22. The Following User Says Thank You to stephenplumb For This Useful Post:
  23. #16
    Alicedale
    Thanked: 56
    yeah, I know a few guys who get better and worse than I get. My wife and drive much the same and 8.5km/l is what we average at. Both our vehicles do have bigger Tyres. 255/75R17 so Iím sure that makes me them a bit heavier juice.
    however Iím adamant even compared to tuned up only spec 2.8ís the new 150kw working hard is lighter on fuel and stronger towing than the 130kw.
    Quote Originally Posted by stephenplumb View Post
  24. The Following 2 Users Say Thank You to Bryan Webber For This Useful Post:
  25. #17
    Thanked: 40
    We have both the 2.4 Fortuner 4x4 and the new 2.8 Hilux 4x4. Town and surrounds driving mostly and consumption on on the 2.4 Fortuner is 9.4l /100km and the new Hilux 2.8 is 9.2l /100km. I can add that both of us do not have a heavy foot....
  26. The Following User Says Thank You to skotepetoors For This Useful Post:
  27. #18
    Mar 2015
    Thanked: 838
    Quote Originally Posted by skotepetoors View Post
    Is that on the trip computer or calculated? My current Toyota is fairly accurate. The previous one was out by 3 km/L so on a tank it was out by 150 km. Hectic.
  28. #19
    Thanked: 2529
    Since you are towing a stuffing heavy boat (I had mine on the weigh bridge and it was 2150 with a fair amount of fuel) have you ever felt the need to add a gearbox cooler? I know this was considered a requirement back in the day for any towing automatic, but that was in the days before lockup clutches etc.
    Once I have my brake setup working nicely, I will be dragging the old girl around the neighbourhood (well at least to Umkomaas) and would like to know the Gearbox is up to it and I donít need to add an additional cooler.
  29. #20
    Thanked: 40
    Yes, as per trip computer.
