Results 1 to 20 of 40
Thread: Pizza oven
    Centurion + Others
    Thanked: 434
    Default Pizza oven
    Hello all,
    Ive just given my oven 150mm insulation layer.
    50mm ceramic blanket and about 100mm perlite/cement layer.
    The fire bricks on the floor have small gaps between and are not 'perfectly' smooth.
    what can one do to fill the gaps successfully that will take the heat?
    thanks
    cc
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
    Hillcrest
    Thanked: 20155
    Default Re: Pizza oven
    Quote Originally Posted by Capt Chaos View Post
    Hello all,
    thanks
    cc
    Nice - What about a bed of steel.
    Please tell me about the perlite/cement mix. I am making a Hibachi braai and doing the same mix. Which cement did you use. I see some people use some "white" cement.
    NAGOF
    HAM Callsign - ZS5KAD
    Malagas
    Thanked: 148
    Capt some phodies please. Also about to do a pizza oven. Bought the shell and once in place I need to do the insulating layer.
    What ratio did you do your mix.
    Thanked: 1842
    Hello all,
    thanks
    cc
    The floor smoothness is very important to be able to slide over it. I opted for 6mm tiles as opposed to firebricks. Ceramic tiles are cured at a higher temperature than you can get in your oven. Se pic ......
    I have al;so been looking at Perlite and Cement. I think the 46,5 is ok. I also think a final layer of clay a nd cement improves insulation.
Name:	Floor of oven.jpg
    MikevR
  5. The Following User Says Thank You to MikevR For This Useful Post:
    Thanked: 1842
    Quote Originally Posted by MikevR View Post
    I have also been looking at Perlite and Cement. I think the 46,5 is ok. I also think a final layer of clay a nd cement improves insulation.
    Re orientated picture will be corrected.
    MikevR
    Thanked: 1842
    Re orientated picture correction - Ceramic floor
    MikevR
  8. The Following 3 Users Say Thank You to MikevR For This Useful Post:
    Thanked: 20097
    @ MikevR: tell us about the galvanised steel?
    Thanked: 1842
    I was experimenting with reflective surfaces and a retain of the floor concrete ring before the insulation, You will notice there is a air input pipe as well this has a valve on the outside - the unit I built is multi purpose and a hobby experiment. It functions as a Roaster - rotisseries (with Weber Rotiserie ring) and / or smoker and if I place a plough disc type wok skottle braai upside down it becomes a pizza oven. The skottle is place about 2/3rd down the drum see picture of deflector plate position. I also keep the Skottle braai separate for fry ups and breakfasts. I have added the overall picture again of the whole unit. My next project is to change my fire pit design for my flame braai. I will do a separate thread on that.
    Enjoy
Name:	Deflector Plate above fire box.jpg
ID:	630067   Click image for larger version.
Name:	Skottle Braai.jpg
ID:	630068   Click image for larger version.
Name:	Smoker - Roast with Webber Rotisserie ring fitted.jpg
    MikevR
  11. The Following User Says Thank You to MikevR For This Useful Post:
  12. #9
    Thanked: 20097
    Enjoy
    Aha thanks, I recall that system now.
  13. #10
    Centurion + Others
    Thanked: 434
    I got the perlite from the Pratley factory , west of JHB.
    i bag perlite 1 bag cement.
    I just used the Builders stuff. - to be honest didnt think of different as wife is arty and gonna clad it in mosaic/bits of tiles.
    I made the mistake of buying a Hamilton oven [ charges like a raging buffalo] as they're only 45mm thick.
    consequently doesn't retain the heat.
    I've now done it correctly and after a hot 1 hour fire, there is not a bit of felt heat outside,
ID:	630077   Click image for larger version.
  14. The Following 4 Users Say Thank You to Capt Chaos For This Useful Post:
  15. #11
    Hillcrest
    Thanked: 20155
    Ah so normal cement. Thanks.
    NAGOF
  16. #12
    Thanked: 20097
    You can also mix 50/50 vermiculite and portland 32.5 MPA.
  17. #13
    Hillcrest
    Thanked: 20155
    Thanks, it seems that the choice between vermiculite and perlite hinges on the finish. I am looking for something that is aseptically pleasing as it will sit on a dining table.
    So for a table top hibatchi it looks like perlite and some form of white cement. White cement being the ...gar in the wood pile. I have seen refereance to using Plaster of Paris, and other products like Polyfilla and other gysum type fillers.
    NAGOF
  18. #14
    Thanked: 20097
    Yes, I've seen plaster of paris mentioned as well. I don't think that even needs perlite?
  19. #15
    Thanked: 1842
    One can also mix White Wash powder into your cement and perlite if you are worried about colour. It also smoots off very nicely. Also one can use tile adhesive but a bit expensive.
    MikevR
  20. The Following User Says Thank You to MikevR For This Useful Post:
  21. #16
    Centurion + Others
    Thanked: 434
    Fluffy,
    The perlite and cement mix is much whiter than i expected.
    I thought it would be cement-grey, but it is much whiter
  22. The Following 2 Users Say Thank You to Capt Chaos For This Useful Post:
  23. #17
    Ruimsig
    Thanked: 44952
    Mike, please tell me you degalvanised the steel or at the very least, it wont be used in the chamber where food will be
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
  24. #18
    Aug 2017
    Durban or Centurion
    Thanked: 1900
    Pratliperl...
  25. The Following User Says Thank You to SAND For This Useful Post:
  26. #19
    May 2018
    Pearly Beach near Gansbaai
    Thanked: 344
    Do perlite pizza ovens work?
    This method of pizza oven insulation has been used for thousands of years, so it is tried and true; Both vermiculite and perlite will withstand high temperatures, insulate well, and expand with heat so it doesn't crack easily.
    https://www.fornobravo.com/pizza-oven-insulation/
  27. #20
    Thanked: 1842
    Hi Sean
    Thank you for the query, It appears I am going to have to paint the inner surfaces of the drum with 1 part hydrochloric acid to 3 parts water. Remove all traces of Galvanised surfaces. Thereafter complete wash down and apply a coat of cooking oil. then refire without food. I will ensure there are no zinc related surfaces in the chamber at all. I hope this is a learning for others as well. Zinc is poisonous and is released from galvanized surfaces when heated.
    MikevR
  28. The Following 3 Users Say Thank You to MikevR For This Useful Post:
