Page 2 of 2 FirstFirst 1 2
Results 21 to 40 of 40
Thread: Pizza oven
  1. #21
    Mar 2012
    Ballito
    Thanked: 993
    Default Re: Pizza oven
    I have seen refereance to using Plaster of Paris, and other products like Polyfilla and other gysum type fillers.
    My DIY furnace is made with plaster of paris and vermiculite with shredded steel wool mixed in as well.
    Messy to build, not exactly pretty (I didn't try hard), but still works.
  2. #22
    Centurion + Others
    Thanked: 434
    Its coming on.
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
  3. The Following 5 Users Say Thank You to Capt Chaos For This Useful Post:
  4. #23
    Thanked: 1836
    I looks good. Must have been difficult to build it like that though
    MikevR
  5. #24
    Florida
    Thanked: 1148
    In constructing a pizza oven other that using the correct refractory materials and insulation to maintain the heat inside I would add two further considerations.
    1. The oven must be at the correct height for easy use and more important to have proper vision into the oven. Most ovens I've seen are generally too low - real back breakers.
    2. the position of the flue/chimney should be in the front of the oven and not in the centre of the top of the dome.
    Any comments on these points?
    A friend has just installed a wood burning pizza oven at his new build home. The oven he installed is a manufactured one and really looks great. The only problem, IMHO is that the oven is too low. The oven itself really looks classy. The goal now is to get invited for pizzas! Have a look see on the their website. I'm thinking that this could be a worthwhile option. Does anyone know of them and if so what is the feedback on the products.
    https://www.fireanddining.co.za/
  6. #25
    Thanked: 1836
    [QUOTE=TRON;4736803]In constructing a pizza oven other that using the correct refractory materials and insulation to maintain the heat inside I would add two further considerations.
    Hi Tron
    1. I agree totally the plinth should be set on top of a 9 course brick platform. Wood storage underneath
    2. The chimney not only should be set in front of oven above opening but also be able to adjust volume of exhaust. Sometimes one wants to slow the process right down if you are baking overnight.
    MikevR
  7. #26
    Florida
    Thanked: 1148
    [QUOTE=MikevR;4736858]
    Hi Tron
    Mike, if the unit has a proper door to close the opening you should be able to adjust flow in. But I do think that no harm will be done if an adjustable flap can be inserted in the pipe just above the ovens chimney. The question is how to do this.
  8. #27
    Thanked: 1836
    [QUOTE=TRON;4737890]
    Quote Originally Posted by MikevR View Post
    Tron, have a look at the fireplaces at Builders Warehouse. Their flues / chimneys have built in flaps. Maybe you could copy the concept. I still like the idea of a 40 mm galv pipe entering from the side at the bottom with a tap on it to regulate inflow of air if door is closed
    MikevR
  9. The Following User Says Thank You to MikevR For This Useful Post:
  10. #28
    Apr 2012
    Pretoria East
    Thanked: 45
    Resurrection of an old thread.
    I have a manufactured pizza oven (1st pic) that kept on losing heat overnight. As far as I could tell the dome is perlite cement mix but way too thin.
    I have started to do additional layers of pratleyperl cement mix aiming to double the thickness of the dome.
    (second pic)
    Fingers crossed that it will retain heat for longer.
ID:	711215   Click image for larger version.
    Wouter
    Me:2019 Amarok V6😁😁
    Swambo: 2021 Ford Everest specialist pavement hopper
    Imagine trailvan( Ufudu) in tow
  11. The Following User Says Thank You to propofol For This Useful Post:
  12. #29
    Nov 2006
    Thanked: 892
    Please educate me.
    Why do you need heat until the morning?
  13. The Following 2 Users Say Thank You to Damdan For This Useful Post:
  14. #30
    Thanked: 1836
    I have since changed to a purchased wood fire oven and it works wonderfully. We can do evening meals in it, and we also like to cook overnight the tougher cuts and things like ham hocks, Short-rib, Brisket etc. i.e., We may have an evening meal and then we double wrap long cook meat in baking paper and then double wrap in Al Foil and place it in Wood fired Oven overnight. Next morning it is fantastic. Just breaks apart. Lovely for a Saturday lunch time Meal. We use ours more than our braai set up. We also use a home-made Tuscan grill to cook our Chicken flatties or steaks on. Can even do hamburgers on it. Lots of stuff on YouTube for those who are interested.
Name:	Wood fired oven - .JPG
ID:	711260   Click image for larger version.
ID:	711261   Click image for larger version.
Name:	Home made tuscan grill.JPG
    MikevR
  15. The Following 3 Users Say Thank You to MikevR For This Useful Post:
  16. #31
    Thanked: 1836
    Apologies 1 photo incorrect orientation.
Name:	Prepared for oven.jpg
ID:	711263   Click image for larger version.
Name:	Ready for cooking.jpg
    MikevR
  17. The Following 3 Users Say Thank You to MikevR For This Useful Post:
  18. #32
    Linden
    Thanked: 6482
    That looks like bluegum ... do you start with that and then use something else for long lasting coals? Please educate me. Also where you bought your oven, i'm moving in to a new place soon and a pizza oven is on my radar
  19. #33
    Thanked: 1836
    Hi Morne,
    Herewith some notes attached. For hardwoods a mostly use Macadamia and Mapani. For start wood I use old gum which also makes fair coals. I usually do a 3-level stack but if i am cooking overnight, then once I have pushed the 3 levels into the oven then I had 2 more hardwood logs. I have someone who now supplies me my wood cut at 350 mm long which I find is ideal.
    Attached Files Attached Files
    MikevR
  20. The Following 2 Users Say Thank You to MikevR For This Useful Post:
  21. #34
    Linden
    Thanked: 6482
    Hi Morne,
    Thanks, and the company where you purchased your oven?
  22. #35
    Thanked: 4790
    Quote Originally Posted by propofol View Post
    (second pic)
    I would love to build myself a proper wood pizza oven.
    Couple of questions:
    1. Why do you need heat overnight?
    2. Can't you just add more wood to keep the temps up?
  23. #36
    Thanked: 1836
    Hi Morne',
    https://www.ecopizzaovens.co.za/
    Hi Icepick88,
    See my note above re option to cook overnight or any long cook. Plus by adding wood at intervals may raise the temp too much whereas you want a slow low temp cook to get the best cook results.
    There are so many meals you can cook in a wood fired oven. All take different cooking times at different temps. The fun is in the learning? I have added some photos of cooked and uncooked. first 2 photos are Eland Brisket and Eland Short Rib. Ideal to slow cook in a Wood Fired Oven. You must also try Marrow Bone roast. Any good meat cut wrapped in Marrow Bones
Name:	Eland brisket.JPG
ID:	711269   Click image for larger version.
Name:	Eland Short Rib.JPG
ID:	711270   Click image for larger version.
Name:	Lamb Foreleg Shanks after 1,5 hours.jpg
ID:	711271   Click image for larger version.
Name:	Piza - ham cheese and chillies.JPG
ID:	711272   Click image for larger version.
Name:	Pork Belly in cast iron pan cooked.JPG
ID:	711273   Click image for larger version.
Name:	Pork hocks ready to make soup..jpg
ID:	711274   Click image for larger version.
Name:	Pork chops, Mushrooms and potatoes.JPG
ID:	711275   Click image for larger version.
Name:	Marrow Bone Roast.jpg
    MikevR
  24. The Following 3 Users Say Thank You to MikevR For This Useful Post:
  25. #37
    Thanked: 2867
    One of the best pizza shops in Bloem said he tested a lot of wood and found Bluegum burned the hottest of that which he tested.
  26. The Following User Says Thank You to Mr.G For This Useful Post:
  27. #38
    Thanked: 2867
    Quote Originally Posted by IcePick88 View Post
    More wood does not necessarily mean more heat..You need a wood that burns well and creates high enough temps without needing to overload the oven with wood..Gluegum seems to be a good allrounder
  28. The Following User Says Thank You to Mr.G For This Useful Post:
  29. #39
    Ruimsig
    Thanked: 44895
    Hi Morne',
    Hi Icepick88,
    Mike, it would be great to see some of these dishes on It Are Time. RvW was always experimenting with his oven and was of the view that it was for much more than pizzas, which you have brilliantly demonstrated here. It is probably one of the best low-n-slow setups ever devised. I was fortunate enough to have a lamb shank done, overnight, in a pizza oven and that has formed the yard stick for lamb shanks as far as I am concerned. Every one I have had since, and some of them have been great, have never come up to that standard.
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
  30. The Following User Says Thank You to Estee For This Useful Post:
  31. #40
    Thanked: 1836
    Quote Originally Posted by Mr.G View Post
    Hi Mr. G, I agree with you about over stoking and as I mentioned above, Blue Gum is a great starter wood to get hardwoods ignites and has a very hi heat but the coals do not last like hardwoods, which you need when cooking low and slow. Therefore use it as your base layer.
    MikevR
  32. The Following User Says Thank You to MikevR For This Useful Post:
