Page 2 of 2 FirstFirst 1 2
Results 21 to 40 of 40
  1. #21
    King Williams Town
    Thanked: 2320
    Default Re: Rivnut/Zebranut setting tool
    Many thanks all, much appreciated for the correct method.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  2. #22
    Thanked: 2108
    You can check out a couple of yootube movies as well. Nice ideas there and you have a lathe.
  3. The Following User Says Thank You to Spiceman For This Useful Post:
  4. #23
    Apr 2011
    Hartbeespoort
    Thanked: 93
    https://www.frontrunneroutfitters.co...AaAreHEALw_wcB
    Saw that and since the I just use a piece of flat bar What ever fits in the position to clamp against.
    Find the places I normally want a rivnut the rivnut tool often would not fit.
    Also if I do more than 15 in a year itís plenty and most are m6 or m8 regardless.
  5. #24
    May 2017
    Honeydew
    Thanked: 74
    This is one tool I find indispensable, up there with cable ties and duct tape. I have used it hundreds of times in all sorts of situations.
    Kind regards
  6. The Following 2 Users Say Thank You to JamesV For This Useful Post:
  7. #25
    Oct 2012
    Thanked: 617
    Any suggestions for when you have to use an existing hole but it is a bit big?
  8. #26
    Tshwanetoria
    Thanked: 1371
    Quote Originally Posted by mudgrubber View Post
    If you can, insert a washer at the back, with the correct hole size. Often, you have to drill that yourself.
    You do get an extra long rivnut to accommodate a washer. Rivco
    https://www.rivets.co.za/rivnuts.php
  9. The Following User Says Thank You to hatjohan For This Useful Post:
  10. #27
    JHB
    Thanked: 275
    Rivco also make a nice setting tool available from 4x4 Direct
    https://4x4direct.co.za/pop-rivets-a...964222206.html
  11. The Following 2 Users Say Thank You to Woolf For This Useful Post:
  12. #28
    Thanked: 2181
    Maybe I'm doff but if you can access the back of the hole to add a washer why not just use a normal nut?
  13. #29
    King Williams Town
    Thanked: 2320
    Buy a bigger rivnut. Looking at a U tube, they can go to 10mm,unless I'm mistaken.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  14. #30
    King Williams Town
    Thanked: 2320
    Quote Originally Posted by Half-Pint View Post
    Maybe you install a fridge slider into back of bakkie for example or drawer system and want to make it removable but don't trust the rivnuts to hold on their own. So you push rivnut through and put washer on other side of rivnut to give more surface area grip.
    Hence you just need to work from top of load bin and not send wifey under bakkie to hold a spanner in the case of nuts and bolts.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  15. The Following 2 Users Say Thank You to hunter26 For This Useful Post:
  16. #31
    Jun 2012
    Thanked: 3858
    Go up one size in rivnut, once the rivnut is loose in the hole on fitting you will have issues down the line.
    Anton Muller
    "That which can be asserted without evidence, can be dismissed without evidence." Christopher Hitchens.
    2020 X3 M40i
    Birkin SR20VET race car
  17. #32
    Feb 2018
    Middelburg
    Thanked: 45
    Rivnuts are used where you don't have access to the nut.
  18. The Following User Says Thank You to GreigD For This Useful Post:
  19. #33
    May 2016
    Thanked: 4821
    Quote Originally Posted by GreigD View Post
    That, and it is a form of "captive" nut.
    You might have to re-tighten something from time to time and holding a normal nut at the back might be a "schlepp".
    2006 VW Touareg V10 (Sold)
  20. The Following User Says Thank You to 4ePajero For This Useful Post:
  21. #34
    Tshwanetoria
    Thanked: 1371
    No, you are not doff , but there are many instances where the rivnut is preferred. I for instance have installed rivnuts in the floor of my loadbin. Installing the bolts to fasten a drawer system is now a easy, one man jobbie. No need for someone to lie underneath the vehicle, holding a nut.
  22. The Following User Says Thank You to hatjohan For This Useful Post:
  23. #35
    Tshwanetoria
    Thanked: 1371
    No, not always.
  24. #36
    Tshwanetoria
    Thanked: 1371
    Like this
  25. #37
    May 2016
    Thanked: 4821
    Like this
    Good example, using a washer.
    The best practice it to apply the water proofing before you tighten the Rivnut.
  26. #38
    Tshwanetoria
    Thanked: 1371
    Did that - before and after. As well as the anti-rust before
  27. #39
    Feb 2018
    Middelburg
    Thanked: 45
    The first rivnut that I set/installed was a 12mm and considering the size it was really not difficult to set. I donít know if you get bigger than that.
  28. #40
    Dec 2014
    Thanked: 3507
    Steel thin flange goes up to M10, thick flange to M12, Stainless to M10 and Allynumnum to M8 according to Rivco.
    Cheers,
    John Kilfoil
    'People who believe the vaccination will alter their DNA should probably consider it an opportunity"
    Rover P6
    Range Rover P38 HSE -- Sold
    Moto Guzzi LeMans
    Aprilia Tuono V2
  29. The Following User Says Thank You to JohnnoK For This Useful Post:
