Results 1 to 8 of 8
    Jul 2013
    Benoni.
    Thanked: 905
    Default Discovery steering rack appears to be leaking
    Hi guys, another question about the 2 tons of questions I have in my garage.
    I'm sorry if this is getting a bit much.
    When I was under the Disco over the weekend, i saw that the steering rack on the drivers side is sweating quite badly. I can't actually pinpoint the point where it starts, can't see it from the top and it comes from too high up to see from underneath.
    Power steering fluid is a tad low.
    Has anyone got any ideas?
    As you can tell, I'm more enthusiastic than knowledgeable.
    So far, in no particular order, she needs:
    Gearbox filter service.
    Brakes. Disks and pads.
    Coolant hose replacement and probably (definitely) a flush.
    Aux fuel tank pipe repair for the airlock and
    Now this.
    I understand that old cars need maintenance. I get it. Its one of the benefits of low insurance and zero installments but man, it never rains...
    Any pointers of where to start looking or what to try budget for, I'd be grateful.
    Jul 2013
    Benoni.
    Thanked: 905
    Default Re: Discovery steering rack appears to be leaking
    Excuse the cell phone quality and the angle Name:  IMG_20210908_122442.jpg
    Thanked: 19853
    Edited: removed my post as it seems I am wrong, those power steering units never leak
    Jakes Louw
  4. The Following User Says Thank You to jelo For This Useful Post:
    Jul 2013
    Benoni.
    Thanked: 905
    Thank you Jelo
    Thanked: 532
    Quote Originally Posted by Chopped View Post
    The steering box itself looks fairly clean (oil free). This may sound stupid, but check if the jack which is stored in the battery box is not leaking oil.
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
    Thanked: 532
    FWIW, my D2 is now 21 years old, 315k km, no leaks on steering box and pipes also still original.
    ORRA Z07
    Jul 2013
    Benoni.
    Thanked: 905
    Quote Originally Posted by TwinDisco View Post
    The day I brought her home, i found oil on the floor. Hunted for an hour before I found the jack was leaking. So, it didn't sound stupid to me.
    I folowed the advice from Jelo and Mikebob, sprayed it in degreaser, will see what I can see over the next day or two.
    Dec 2014
    Thanked: 3502
    Mine is leaking, I topped it up with Dexron and it started pouring out, so I drained it and filled it with the correct oil, drove it a bit and drained/filled/drove a few more times to flush it properly.
    It still drips a bit, but is much less now.
    Cheers,
    John Kilfoil
    'People who believe the vaccination will alter their DNA should probably consider it an opportunity"
    Rover P6
    Range Rover P38 HSE -- Sold
    Moto Guzzi LeMans
    Aprilia Tuono V2
