Results 1 to 8 of 8
    Friemersheim, Southern Cape
    Thanked: 5175
    Default Propshaft alignment
    There is a guy in our area that bought a Rocky sans a gearbox and TC.|
    He had a pre 1998 Toyota 2.8D 4x4 gearbox and TC fitted. He had a Rocky bellhousing and they cut and joined the two housings.
    The only thing is the alignment of the propshaft to the pumpkins, especially the one at the back. There is an angle, not very acute, but there.
    The universals will handle the the offset, the purpose of universals.
    My question is...to my mind the 'more straight' the propshaft is, the less strain on the universals. Or am I missing something?
    My first words to him was, you will have to watch your universals, they might need to be replaced more regularly.
    Robert van den Berg...(fully vaccinated with two Pfizer jabs & certified)
    '98 Daihatsu Rocky 'The Kitty' (jabbed with 50ppm)
    '02 Daihatsu Rocky 'The Bully' (jabbed with 50ppm)
    Jun 2012
    Thanked: 3827
    Default Re: Propshaft alignment
    The universals can take a lot of angle without issue, what is important is that the gearbox and diff is parallel to each other, or as close as possible.
    If the diff and gearbox are sitting at different angles you get accelerated wear and vibration on the universals
    Even on stationary equipment your dont mount the propshaft perfectly straight as the universals wear on only 1 spot so wear out quicker.
    Anton Muller
    "That which can be asserted without evidence, can be dismissed without evidence." Christopher Hitchens.
    2020 X3 M40i
    Birkin SR20VET race car
  3. The Following 2 Users Say Thank You to mullerza For This Useful Post:
    Mar 2014
    Richards Bay
    Thanked: 60
    Yes Prof, the lower the angle the better ,although it is still better to have a small angle instead of dead straight otherwise the needle bearings will wear into the universal cross journalís due lack of movement.
  5. The Following 2 Users Say Thank You to GollyJeep For This Useful Post:
    Thanked: 2071
    I am quite certain that members such as @grips or @reenen who has done conversions will be able to assist wrt advice.
  7. The Following User Says Thank You to Spiceman For This Useful Post:
  8. #5
    Thanked: 19888
    The rear pinion must point straight at the transfer case output. Put a double Cardon joint top, normal UJ at the axle.
    Jakes Louw
  9. #6
    May 2016
    Thanked: 4767
    On live axle suspension, the vertical angle changes all the time.
    2006 VW Touareg V10 (Sold)
  10. The Following User Says Thank You to 4ePajero For This Useful Post:
  11. #7
    Kathu
    Thanked: 4453
    Prof to answer you. The more in line the better. I have tilt rear diff`s to reduce angles.
    But then have a look a the front shaft of a 76 F250 with a low pinion front diff. Those front props sit at quite and angle straight from the factory and as far as I can remember UJ
    were not effected.
    If there is no vibration then things will be fine.
  12. The Following User Says Thank You to grips For This Useful Post:
  13. #8
    Robertson/ Larissa, Greece
    Thanked: 5615
    One most important factor. The angle of the UJ at the diff must be the same as the angle of the UJ at the gearbox output shaft and in phase.
  14. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
