Results 21 to 40 of 47
  1. #21
    Magalieskruin Pretoria
    Thanked: 1045
    Default Re: Disco 1 Auto: flexible cooler lines?
    Some neat work there gents. I can only imagine the cost is not 500 bucks unfortunately.
    HENK
  2. #22
    Mar 2014
    Brakpan
    Thanked: 520
    Good idea with pushlock and braided hoses. Why not fit a loose cooler in front. Will be better
    Four wheels move the body,
    Landys move the soul.
    0735236742
    Current: Discovery 2 td5.
  3. #23
    Mar 2015
    New Germany
    Thanked: 1111
    Quote Originally Posted by Sam vd Merwe View Post
    Agree the biggest oil cooler you can put in for a auto is the best, high oil temps kill auto box’s
    Auto cooler left and power steering cooler
    oil cooler installed below
    my sons Chevy Landy he built
    oh and AN fittings stand for Army-Navy
ID:	629454   Click image for larger version.
    2005 Defender TD5
  4. #24
    Thanked: 20097
    Quote Originally Posted by Henkus View Post
    R500 gets you a pizza and a few beers these days.....
    Jakes Louw
  5. #25
    Mar 2014
    Brakpan
    Thanked: 520
    Or a quarter tank of diesel
    0735236742
  6. #26
    Dec 2014
    Thanked: 3511
    ...and JIC Hydraulic fittings are directly interchangeable for less cost...
    Cheers,
    John Kilfoil
    'People who believe the vaccination will alter their DNA should probably consider it an opportunity"
    Rover P6
    Range Rover P38 HSE -- Sold
    Moto Guzzi LeMans
    Aprilia Tuono V2
  7. The Following User Says Thank You to JohnnoK For This Useful Post:
  8. #27
    Polokwane
    Thanked: 276
    Some nice input here guys - thank you.
    I'm particularly impressed with the fact that you can get re-usable fittings so that you can make up hoses yourself. I always thought those "crimping" things were the only way. I'm going to look into this - so that I can make them up at home to the correct length, and play around with the routing and clamping them down. For engine oil cooler and power steering lines as well.
  9. The Following User Says Thank You to antvz For This Useful Post:
  10. #28
    Thanked: 20097
    Well done bud. You've come a long way.
    Jakes Louw
  11. #29
    Polokwane
    Thanked: 276
    Thanks for the kind words, Jelo.
  12. #30
    Polokwane
    Thanked: 276
    So, the more reading up I do, the more these flexible lines make sense.
    The solid lines with the small flexible section, make sense for the original equipment version of the Disco - when it was new. After all, these lines run very near the exhaust. In fact, the more I think about it, perhaps it makes sense to leave a short length of metal line at this point. If anything had to come loose and burn on the exhaust, this would be a problem and would perhaps influence the reliability of the car.
    As for the rest - flexible makes much more sense. And actually, more rather than less flexible! The biggest problem might be temperature, rather than pressure, actually!
    A quick Google tells you that gearbox pressure is around 10 bar max in this auto box. But that's within the box. The return line to the cooler, apparently, empties back down into the pan, so would be a low pressure line. A couple of bar, max.
  13. #31
    Polokwane
    Thanked: 276
    Here's my temporary solution... remove the pipe, clean up and silver solder everywhere it looks like the leak could be.
  14. The Following User Says Thank You to antvz For This Useful Post:
  15. #32
    Polokwane
    Thanked: 276
    Ashcroft sells a kit with an autobox cooler and lines to retrofit to a Defender. A lot can be learnt from this. The biggest issue, is finding a way to get the existing nipples on the auto box side to connect to a length of flexible pipe.
    On the Ashcroft kit, you remove the nipple adapters from the gearbox and screw in a M16 (4HP22) or M18 (4HP24) banjo pushlock fitting. This seems like a very nice way of doing it, with one less connection to go wrong.
  16. #33
    Polokwane
    Thanked: 276
    Quote placed with FTF. Let's see what it all comes to
    - braided rubber line
    - braided PTFE line
    - adapters M16 to AN8
    - AN8 fittings
    (hope I'm right about the AN8 - will need to go measure properly before ordering).
  17. #34
    Jan 2016
    Golf Park
    Thanked: 326
    - braided PTFE line
    - AN8 fittings
    What are the PTFE lines for?
    The braided rubber hose to replace the standard steel line for the gearbox cooler is AN8, thats what we just did on mine.
    Im nots sure if the autobox is different but the adapters to fit the manual box were M20 to AN8
  18. The Following User Says Thank You to Jay_B For This Useful Post:
  19. #35
    Mar 2015
    New Germany
    Thanked: 1111
    Quote Originally Posted by Jay_B View Post
    normaly the braided PTFE lines are used for HP as in supply from steering pump to steering box
    and also brake lines but use different fittings for brakes
    2005 Defender TD5
  20. #36
    Polokwane
    Thanked: 276
    The auto box will take an M16 adapter.
    PTFE lines just to check the price difference. If not much more than rubber, I'll go for that. Will withstand the heat better and less likely to break up inside as well.
  21. #37
    Polokwane
    Thanked: 276
    Well, I've sent a couple of emails back and forth to FTF and have received really great responses. Slowly I'm building a picture of what I need to do with these (and future) lines.
    Ironically, the PTFE stainless braid is much the same price as the rubber line. I think I'll go for the PTFE - makes a lot of sense when ATF at high pressure and temperature is involved, and also since the lines are near the exhaust.
    Those fittings are not cheap. However, the total cost of making up those lines won't come to much more than having a hydraulic place make up the usual crimped lines - with the advantage that I can fit it at my leisure at home, and I can get the lengths exact. Also I would imagine it would be much easier to do a field repair - I should actually buy a couple of straight adapters and just leave them in my tool box with a short length of hose.
    I'll also be buying some more PTFE hose when the time comes to do that pesky coolant pipe in my Tata that runs directly underneath the exhaust manifold. And all the other small coolant pipes in the Landy. It's so hard to get decent coolant hose these days.
  22. #38
    Thanked: 323
    Antz
    on another point
    you must have several kilos under the belt with your electric vacuum pump by now
    any comments yet
    thks
  23. #39
    Polokwane
    Thanked: 276
    Antz
    on another point
    any comments yet
    thks
    I'm still very happy with it. It's been about 20 000 km now since the engine overhaul and the installation. I still need to tidy up the plumbing a bit. Same with the fuel pump. Ironically, the piping sold at FTF is making me think about doing the whole fuel line and vacuum lines over again (fuel, will use braided teflon pipe).
  24. #40
    Dec 2014
    Thanked: 3511
    Google Aeroquip Firesleeve, it should be commecially available from suppliers.
    Cheers,
    John Kilfoil
    Rover P6
    Moto Guzzi LeMans
    Aprilia Tuono V2
