Results 1 to 2 of 2
    Feb 2019
    Northcliff, Johannesburg
    Default 3.0 TDCI 2008 Ranger Injector Connector
    Afternoon all
    My ranger started running sluggish no power and noticed black smoke.
    Checked injectors,and found when removing connector on number 3 the motor still idles the same (sluggish)
    When disconnecting one of the other plugs the motor dies.
    Tested voltage and got 5v.
    So I switched around number 2 and 3 injectors-found that the problem stays the same . Now when removing the connector on old number 3 now in number 2 . motor dies.
    I have come to the conclusion that the connector does not make proper contact anymore.??
    Please advice where i will be able to get one of these connectors without buying the complete harness.
    Feb 2019
    Default Re: 3.0 TDCI 2008 Ranger Injector Connector
    Thanks all got ir sorted.
    Problem was with the connector on the ECU pin 103.
  3. The Following User Says Thank You to Radman For This Useful Post:
