Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 80
    Sep 2018
    Thanked: 36
    Default Anderson Plug Crimping Tool
    What is the correct crimping tool to use on anderson plugs?
    I used one for small cable connectors and stuffed it up!
    Is crimping better than soldering?
    Read that solder adds to the resistance and voltage loss in the connection.
    Thanks in advance
  2. The Following User Says Thank You to TimTDP For This Useful Post:
    Jul 2014
    Waterfall
    Thanked: 144
    Default Re: Anderson Plug Crimping Tool
    You get a very nice Hex crimper. I see 4X4 Direct sells them.
    2016 V8 D/Cab Cruiser
    Land Cruiser VDJ 71
    2020 LC 200 GXR
    2020 LC FJ
    Thanked: 2128
    I have this one
    https://www.adendorff.co.za/product/...caAuAfEALw_wcB
    I must admit that for me its not user friendly, you have to pomp the handle for ages to actually crimp something. I did use it on some 25mm cable & then it seriously came into its own.
    I will get this one at some point seeing as it should be less fiddly
    https://4x4direct.co.za/tools-/9121-...242063176.html
    Jan 2020
    Thanked: 233
    It might be easier to solder but the loss you mention is negligable. Alternatively depending on number of crimps you doing it might be advantagious to get a decent hex crimper like this one. you get in a smaller size as well but they are somewhat pricey
    Thanked: 1176
    Quote Originally Posted by Wylie E View Post
    Actually the hex crimper in the earlier link is a good buy.
    King Williams Town
    Thanked: 2309
    The problem with soldering by some is that wires tend to break off due to rigidity etc etc. As for resistance, not enough to even consider losses unless you dealing with a space ship. Nice thing about crimping is that wire has flex at back of crimp. But it's a heavy debated subject.
    Find a friendly sparky in your area and ask him to crimp those big lugs for you.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Nov 2014
    Thanked: 3416
    I have a heavy duty pair similar to these that I bought from a departing HT electrical guy. Work well on different size lugs, they just don't fit the bigger Anderson plugs, only really good to 50amp. Beyond that I use a makulu pair of pliers.
    I crimp and then solder as well. I have no idea if it is better that way but I figure it can't do any harm.
    https://www.builders.co.za/Tools-%26...iABEgLVT_D_BwE
    Nemo me impune lacessit
    Thanked: 1897
    If it's just a couple, try your closest Auto Elec or the Battery Centre guys are very helpful
    Sep 2016
    Thanked: 27
    I fill the Anderson lugs with small bits of solder, heat up with a blowtorch and then push the cable in. I have had no problems in 10 years and 3 caravans later.
  11. The Following 11 Users Say Thank You to rhaynes For This Useful Post:
    Thanked: 1176
    Quote Originally Posted by rhaynes View Post
    I can just say just like welding some solder joints could be good or bad. In my 2nd car a Fiat 124ST I wired in an ammeter with charge and discharge through the ammeter. I drove it for 14years and those 8 solder joints never gave problems. Those years crimping tools were not a standard tool in every toolbox. Times are a change.
  13. #11
    Okahandja, Windhoek
    Thanked: 1196
    I also fill that lug with solder, heat it up and push the wire in. Done that for many years and never had a failure. My crimping tool is anyway also useless for that.
    Johan Kriel
  14. The Following User Says Thank You to JLK For This Useful Post:
  15. #12
    May 2012
    Thanked: 202
    [QUOTE=JLK;4729211]I also fill that lug with solder, heat it up and push the wire in. Done that for many years and never had a failure. My crimping tool is anyway also useless for that.
    I crimp, then heat the base of the connection with a small gas blowtorch and melt the solder into the connection - it runs in like water and that works really well for me.
    Rob Pollock
  16. The Following User Says Thank You to Onematch For This Useful Post:
  17. #13
    Jun 2013
    Potgietersrus
    Thanked: 917
    Solder it and heat shrink . Gives the wire a bit more support at the pin
  18. The Following 4 Users Say Thank You to Eli Stone For This Useful Post:
  19. #14
    Mar 2015
    Thanked: 43
    Quote Originally Posted by Eli Stone View Post
    That's what I do, seems to work
  20. #15
    Ellisras
    Thanked: 1381
    The advantage of soldering it is that you can always desolder and use again
    2014 Patrol GU 3.0CRD "teenager" in puberty - 131 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 125 000 km
  21. #16
    King Williams Town
    Thanked: 2309
    [QUOTE=Onematch;4729293]
    Saw a video. Chap crimps lug then at top of lug, melts solder into inspection hole. He says it prevents water ingress into cable(I can agree here), then he adds heatshrink over back of lug and cable.
    With our High voltage joints we use to use weak back ferrels to join cable, ie crimp around cable and pour in solder. The solder not only joined cable but acted as a moisture stop. Today we use solid Centre ferrels to joint with.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  22. The Following 3 Users Say Thank You to hunter26 For This Useful Post:
  23. #17
    Thanked: 1011
    Always ensure you have the correct lug size for the wire diameter, and if you do, you cannot give the wire a twist after stripping the plastic, because then it no longer fits into the lug.
  24. The Following User Says Thank You to Heinz Modricky For This Useful Post:
  25. #18
    Thanked: 543
    Ever heard of a dry Joint
    Who is correct.
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  26. #19
    Apr 2016
    Thanked: 115
    The Anderson connectors are really solid so you'll need a meneer of a crimper to crimp them successfully.
    However soldering is comparatively easy. If you use solder with flux impregnated into it the join will be fine if you heat it well enough. (and don't move the cable or connector until it has solidified!)
  27. The Following 2 Users Say Thank You to Richard Mackay For This Useful Post:
  28. #20
    Thanked: 3165
    Problem with an Anderson or Brad Harris plug is that the plug hole is more often than not waaay bigger than the cable going in to it. If you are going to crimp it it is important to double it back on itself a few times to get the hole as full as possible before crimping it. A hex crimper works verry well and if you can get solder in after crimping that is first prize. having a piece of heatshrink is a brilliant idea,
    When soldering with rosin core the flux migrates ynder the insulation and at the point it stops it creates a weak spot where the wire breaks off, the heat shrink adds suport at that transition point. This is the main reason why aytomotive luggs are designed to be crimped and not soldered, the vibration breaks the cable at the transition point. Plumbing solder is a capilary solder and the flyx is critical for the solder to flow so it can be better controlled just make sure the solder is cleaned off all flux as it is usually acid based
    Contrary to popular belief the plug on an Anderson is not so thick as one would like to think.
    Whatever you do do not use a side cutter
    Henk
    Follow us on Facebook
  29. The Following 2 Users Say Thank You to hbannink For This Useful Post:
