Results 1 to 8 of 8
    Gordon`s Bay
    Thanked: 13
    Default Fortuner traction control
    Some info please---Did some dune driving and while going up a dune the fortuner lost power and the TC switched off--Is it speed dependent or do I need to go into low range to keep it engaged--Fortuner is the d4d 3l auto
    Toyota Fortuner D-4D 4x4 AT---My "speed control en navigasie "sisteem is al oor die 50 jaar oud!Ham Call ZS1SSM
    Thanked: 1435
    Default Re: Fortuner traction control
    Quote Originally Posted by Mark Sanderson View Post
    My experience is to always have TC off when doing sand/dune driving.
    Mar 2013
    Thanked: 507
    Don't know if the fortuner has stability control but that is usually the bigger momentum killer in sand. Low-range should switch off all stability aids off while possibly keeping TC in tact.
    TC is useful is some sand situations but no TC, low range 2nd and centre diff locked is a good recipe.
    Pieter Greyling
    Of all the paths you take in life make sure a few of them are dirt-John Muir
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
    Sep 2018
    Not too far from Pofadder
    Thanked: 1962
    TC off in dunes, ABS as well if you can.
    Jan 2020
    Thanked: 281
    Long press the TC off button. Had the same issue, but to completely disable the stability and traction control you need to press the button for about 5 or 6 seconds. Then you should see two lights on the dash. I think it TC and ESP/ABS
  6. The Following User Says Thank You to Schambies For This Useful Post:
    Nov 2020
    Crosby
    Hi hope everyone is doing well
    Today I got my steering rack replaced on my 2010 toyota fortuner and after putting everything back together I took the car for a drive the alignment is totally off
    when I drive about 40 to 50 the brakes grind and the traction light comes with that there is a beep noise that also come on
    Just to mention 1 more thing the car looses power after 40 to 50
    Jan 2020
    Thanked: 281
    Quote Originally Posted by Tauhir View Post
    1. You need to get an alignment done
    2. Make sure the wheel speed sensors/abs sensors are connected.
    The traction control beeps when it engages and it will reduce engine performance to increase safety. Start with getting the alignment done and see what happens. If the traction control still beeps and slows you down go chat to a mechanic
    Ballito
    Thanked: 2450
    Why post same on so many threads?
    Jaco Nell
