Results 1 to 20 of 31
    Mar 2011
    Walker Bay
    Thanked: 1534
    Default Tankwa roads eating tyres
    Tyre warning----- those Tankwa stones can shred tyres sidewalls.
    I have just heard of a party there about two weeks ago who lost two tyres.
    I suspect the roads were recently graded which caused those sharp stones to stand upright.
    It takes a while for cars to push them to the side of the tracks. Also do not cross the middlemannetjie.
    Most important - keep speeds below 60km. Take puncture kits and compressor.
  2. The Following User Says Thank You to Paul Dold For This Useful Post:
    Nov 2011
    Langebaanweg
    Thanked: 1882
    Default Re: Tankwa roads eating tyres
    High speed, according to me, is the biggest reason for the high amount of punctures on that road.
  4. The Following User Says Thank You to jfh For This Useful Post:
  5. #3
    Dec 2014
    Thanked: 430
    I had to learn the hard way to ignore the Hilux Handbook recommendation for 2.4 Front and 2.8 Rear when loaded, when on this (and similar) roads. A local farmer who stopped to help me with a wheel change here once said that he ran his bakkie at 1.6 all round.
    I find 1.6 a bit scary, but now run at 1.8 all round in this district. This also compels me to limit my speed to to 80 km/hr max, which is what you should do on a gravel road with a loose surface anyway. I haven't had a puncture since adopting this policy.
  6. The Following 4 Users Say Thank You to RodS For This Useful Post:
  7. #4
    Apr 2011
    Thanked: 175
    Same experience with running at 1.8. No issues with the Isuzus after many trips through the area.
    Did lose a trailer tire though, but this was a 5 year old fong kong product and I didn't expect it to last. We bought a spare for it before heading down the R355. It failed in the last 10km on that road, taking half the wheel arch with
  8. #5
    Brackenfell
    Thanked: 562
    Lower speed and 1.6bar is spot on for bad gravel roads.
    We have done 2 Namibia trips in the past, with some big gravel sections. Never lost a tyre (all terrains) with above advise.
    We had family get together trip at DIe Dam between Gansbaai and Struisbaai. Everyone deflated and got there nice and early, except one guy who said the ford's book says 2.6bar. He got there way after dark after losing one tyre and fixing another.
    After that he deflated.
  9. #6
    Nov 2006
    Thanked: 451
    Deflating is a debatable issue. We were three Dc bakkies with similar loads doing Namibia. Two, normal pressure and one deflated (on gravel). The guy with deflated tyres was the one who lost a tyre. Could be that he had Bridgestones.
    Most important factor is drivestyle and an approriate tyre for the conditions. An HT tyre will not survive the Tankwa.
    Bostoe
  10. #7
    Wartburg
    Thanked: 2715
    Quote Originally Posted by bostoe View Post
    Bostoe
    I alsways deflated to about 1.8b with my Defender. It is a debatable subject though as when you deflate, you expose your sidewall more.
    Mike Lauterbach
  11. #8
    Dec 2014
    Thanked: 430
    I agree that there is an additional risk here, but I have had 4 punctures in this area over the years, (with hard tires), and all of them were a sharp piece of crushed stone punching straight through the tread.
  12. The Following 2 Users Say Thank You to RodS For This Useful Post:
  13. #9
    Thanked: 886
    Agree, speed is a huge culprit.
    I had a set of cheap AT tyres, some fourteen gravel road punctures later I got rid of them..... but each time I got a puncture it was a rear tyre and almost always as I approach 100km/hr on gravel.
    With those tyres, if I stuck to 80km/hr or below, no problem, approaching 100km/hr on a bad gravel road almost guaranteed me a puncture.
    All were rear tyre stone penetrations between the tread blocks.
    Edit: Removed tyre brand name.
  14. #10
    krugersdorp
    Thanked: 585
    can someone comment on highlighted route.
  15. #11
    Thanked: 926
    Trying to understand why higher speed will result in (more) punctures?
  16. #12
    Thanked: 1914
    Quote Originally Posted by jadranko View Post
    Nice. Gannaga Pass is very pretty. Don't expect much of Middlepos, there's really nothing there. Gannaga Lodge is a nice stop.
    I'm not sure what the roads in Tankwa National Park are like, often very corrugated. If you can I would suggest that you turn off near Tankwa Padstal (also worth a visit) and then take Skieterrypas and Katbakkiespas and then Op-Die-Berg and Ceres. It's a really beautiful drive.
    https://goo.gl/maps/aMY22Zy2ojuHhhgh6
  17. The Following 2 Users Say Thank You to niclemaitre For This Useful Post:
  18. #13
    Oct 2017
    Rustenburg
    Thanked: 8888
    The roads are extremely corrugated, probably because of the non deflation spoken about earlier... Because it's "debatable"
    Seriously.. When we tackle some corrugations now.. My wife gives them a rating against those in Tankwa - We have not found their equal yet
    Andrew van Staden
    FJ - 2 Batteries, a tow bar, OME, Good Year Adventurers, and a drawer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
  19. #14
    Thanked: 1914
    I have a vivid recollection of deflating my tyres to 1.2 bar, and crawling the 30 km from the gate to the offices at 10 km/h, because that produced the easiest ride of all speeds tried between 0 and 100 km/h.
  20. The Following 2 Users Say Thank You to niclemaitre For This Useful Post:
  21. #15
    Thanked: 56
    I was there 3 weeks ago and the roads were not in bad condition one had to govern ones speed.
    I suggest you allow a longer time for that route - many places to see that are worth while.
    It would be interesting to find out which side tyres punctured the most - drivers or passenger. As I have a theory that the closer one gets to the side of the road the easier it is to puncture.
    We lost a trailer tyre on the last trip on the passenger side - side wall gash, just after we passed vehicle coming from the front.
    Luckily the tyre pressure monitor alerted us and we did not shred it.
  22. #16
    Nov 2016
    Thanked: 420
    I have seen a Jag SUV with no rubber on the rims, any rims, all four.
    During the burn, I must have plugged over 50 tires.
    Its the ultimate test, highish speed, shale rock and corrugations.
  23. #17
    Thanked: 1398
    Debatable, I've heard a few guys say that you rather over inflate, when I went I dropped to 1.8, stayed at 60 and still lost a tyre..no corrugations to speak of.
    FJC - Just Cruising
  24. #18
    Cape Town - RSA
    Thanked: 519
    I think you need to be careful about a blanket rule for Tankwa "skallie" gravel and other areas like Namibia.
    I'v done the Tankwa a few times and the only time I had a flat was running lower pressures with the trailer attached (extra weight on the rear tyres).
    I'd be interested to see if all the punctures where the rear wheels, and probably left rear.
    As mentioned, left is closer to the edge.
    My theory is that the front tyres flip up a stone (in Tankwa they are shaped like an axe head) and then then rear tyre either runs over it or into it causing a sidewall cut. So decent tyres with sidewall protection will help, and higher pressures will help keep the sidewall out of harms way. By higher I mean 2.0 or so.
    Ex - 2005 Cherokee CRD
  25. #19
    Mar 2011
    Walker Bay
    Thanked: 1534
    I have heard the locals don't deflate - use normal pressure - but keep speed to 60kmh max.
  26. #20
    Oct 2014
    Bluff
    Thanked: 13
    Quote Originally Posted by PieterOos View Post
    The front tyres fling the stones backwards into the rear tyres. cutting the inside wall.
  27. The Following User Says Thank You to Karl Reay For This Useful Post:
