Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 21 to 40 of 109
  1. #21
    Oct 2017
    Rustenburg
    Thanked: 8890
    Default Re: Camp fridge,105ah battery and solar?
    Quote Originally Posted by Kudus View Post
    You messing with me😀
    Question: would it be a problem if the wires are thicker than mecessary?
    No
    Andrew van Staden
    FJ - 2 Batteries, a tow bar, OME, Good Year Adventurers, and a drawer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
  2. The Following User Says Thank You to Hedgehog For This Useful Post:
  3. #22
    Mar 2012
    Ballito
    Thanked: 708
    Slightly OT as the OP wants solar only.
    My setup has 1x100W panel and a 30A DCDC with 120Ah lithium battery.
    With the fridge at 1C the battery is still full at the end of the weekend.
    ZS5CMA
    His: '17 Hilux GD-6 4x4 A/T ~135000km
    Hers: '19 Mitsu Eclipse Cross ~ 35000km
    Semi-retired: '12 Polo BlueMotion ~350000km
    Burned to a crisp: '05 WJ 2.7CRD
    https://www.instagram.com/fstopza/
  4. The Following 3 Users Say Thank You to cainslie For This Useful Post:
  5. #23
    Jul 2018
    Potchefstroom
    Thanked: 73
    Quote Originally Posted by cainslie View Post
    dumb question here. DCDC charger is only if I use the alternator as well or can you connect a DCDC for solar as well?
  6. #24
    Mar 2012
    Ballito
    Thanked: 708
    The DCDC is designed to take a feed from the alternator and charge your 2nd battery.
    An MPPT (or cheaper PWM) is designed to take a feed from your solar panel(s) and charge your 2nd battery.
    Some manufacturers make a unit that includes both DCDC and MPPT into a single device. In my setup, I have the Victron Orion Smart DCDC and the Victron Smart Solar MPPT.
    The DCDC is wired directly to the starting battery, but it is configured to only start charging when the input voltage is > 13.8V for 2 minutes so essentially it only turns on when the engine is running.
    ZS5CMA
  7. #25
    Jul 2018
    Potchefstroom
    Thanked: 73
    Thank you for explaining. Now I understand
  8. #26
    Jul 2018
    Potchefstroom
    Thanked: 73
    Next question is do I connect two solar panels in series or parallel?
  9. #27
    Mar 2012
    Ballito
    Thanked: 708
    Either.
    If your controller can handle the higher voltage of series, you can use series.
    But, parallel is most often (not always) better because shade on one panel will still allow the other panel to charge. In series, shade on one panel will be the same as shade on both panels.
    ZS5CMA
  10. The Following User Says Thank You to cainslie For This Useful Post:
  11. #28
    Thanked: 2165
    Considering that you are looking at a Victron solar regulator would it not make more sense to look at the WRND charger which combines DC to DC & an MPPT solar controller?
    https://4x4direct.co.za/dc-to-dc-cha...110661867.html
    The WRND is only a little more expensive but would give you the option to charge from alternator. Dependent on your usage the alternator can be a great way of charging the battery. In my case the morning game drive basically re-charges the battery. Back at camp I connect my 80W panel which meets the demand of 2 fridges meaning we don't dip into the battery at all.
    The afternoon game drive tops up any battery usage.
    Obviously during the night we use a bit of battery but this is replenished on the morning game drive.
  12. #29
    Friemersheim, Southern Cape
    Thanked: 5203
    You messing with me��
    Question: would it be a problem if the wires are thicker than necessary?
    Nope I am not messing with you.
    Before the fancy MPPT's arrived, all managed with PWM's and correctly sized wires.
    Blame KFC....they started this upsize trend. TIC (It does smokkel with your head in some way)
    Also blame advances in technology...this is better than that...etc.
    Read my post in that light
    Robert van den Berg...(fully vaccinated with two Pfizer jabs & certified)
    '98 Daihatsu Rocky 'The Kitty' (jabbed with 50ppm)
    '02 Daihatsu Rocky 'The Bully' (jabbed with 50ppm)
  13. #30
    Jul 2018
    Potchefstroom
    Thanked: 73
    Lol. I get it. Just as I thought I made up my mind something else comes a long😅
  14. The Following User Says Thank You to Kudus For This Useful Post:
  15. #31
    Jul 2018
    Potchefstroom
    Thanked: 73
    Quote Originally Posted by Half-Pint View Post
    Haven’t thought of it before but it makes sense. Where do you install it? Can I put it on the battery box?
  16. #32
    Fish Hoek
    Thanked: 261
    Kudus, probably more important than anything mentioned yet, ensure your panels are standing at the correct angle to the sun. I seldom see panels at the recommended 30 degrees. In my experience, standing your panels at just 10 degrees out, you will lose about 30 percent efficiency.
    My 2c worth.
  17. The Following User Says Thank You to shfish For This Useful Post:
  18. #33
    Aug 2018
    Paarl
    Thanked: 302
    Another question at what temp can fridge be st to keep meat still frozen.
  19. #34
    Thanked: 20046
    Quote Originally Posted by fatbike View Post
    Duh 0 degrees or colder?
    Jakes Louw
  20. #35
    Mar 2015
    New Germany
    Thanked: 1087
    Putting that Duh is a bit uncalled for he asked a question no need to put him down if you regard question as stupid
    2005 Defender TD5
  21. The Following 5 Users Say Thank You to clivemd For This Useful Post:
  22. #36
    Thanked: 20046
    Seriously? Asking at what temp stuff freezes?
    Jakes Louw
  23. #37
    Mar 2015
    New Germany
    Thanked: 1087
    He did not ask at what temp if freezes, but at what temp can you keep it frozen, if I go away I will put my frozen meet in fridge at 2 to 4 deg it will still stay frozen for 2 or 3 days depending how much frozen stuff you have in it and how obtain you open lid
    maybe that’s what he was Asking and his question was not specific enuf
    that’s the way see it
    2005 Defender TD5
  24. The Following User Says Thank You to clivemd For This Useful Post:
  25. #38
    Thanked: 42
    Read the question again. …many people have the same thoughts.
    What is the lowest recommended setting to keep goods (meat) frozen? I presume in the interests of reducing freezer power draw and thus reducing the load on the battery.
    2021 Toyota Fortuner 2.4GD-6 4x4 AT,
    Goodyear Wrangler AT Adventure
    2020 Suzuki Jimny 1.5 GLX Manual,
    General Grabber AT3
  26. #39
    Thanked: 20046
    Zero degrees.
    Jakes Louw
  27. #40
    Thanked: 42
    Zero degrees.
    I’ll take the bait.
    Zero degrees might be the temp at which the produce is frozen but is not that temp at which is should be stored…otherwise freezer settings would go no lower than 0c.
    https://www.fda.gov/consumers/consum...ng-food-safely
    General Grabber AT3
