Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 66
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Default These Ford engines are crap.
    Iíve done 12000 km since I started driving my 2.2 Puma D/cab after the rebuild.
    In 12000 km it didnít use a drop of oil or water, no smoke on start-up or while driving.
    Standard engine map, bigger intercooler, EGR removed and de-cat done.
    On Friday, driving at 100km/h, all of a sudden, clouds of blue smoke and loss of power. Coolant temperature normal, so it didnít overheat, it just decided to expire. Definitely lost compression on at least one cylinder.
    I suspect hole in piston.
    Will strip the pos this week to see exactly what went wrong. All though in my opinion itís a crap engine, I like to keep things standard, so will rebuild or replace with new.
    I hear the 2.2 engine new is much cheaper from Ford than from Land Rover. I will get prices tomorrow, I know the sump is different and probably some of the hanging parts, manifolds etc.
    Does anyone know if the basic engine is exactly the same and if it will work to buy an engine from Ford and change the sump and bolt on the hanging parts from my old engine?
    2017 Amarok Extreme V6
    2014 Jeep Wrangler Rubicon
    2012 LR Puma 2.2
    2012 LR Puma 2.2 D/c
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  2. The Following User Says Thank You to Bosvark Kzn For This Useful Post:
    Jul 2016
    Thanked: 646
    Default Re: These Ford engines are crap.
    First question is when you did rebuild did you replace injectors?
  4. The Following 3 Users Say Thank You to MikeBob For This Useful Post:
  5. #3
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Quote Originally Posted by MikeBob View Post
    Sorry, should have mentioned, I rebuilt the Landy (accident damage). Here’s the thread :https://www.4x4community.co.za/forum...ead?highlight=
    The engine is orginal and from what I could find out (previous owner etc.) it was serviced on time and never opened.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
    Jul 2010
    The Vale
    Thanked: 432
    So there was no history on the actual engine?
    Ranger Wildtrak
    Ex Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
    Jul 2010
    The Vale
    Thanked: 432
    Mileage?
    Ranger Wildtrak
    Mar 2015
    New Germany
    Thanked: 1084
    Probably faulty injector or injectors that coursed it
    my brother has sold a few Chev V8 and kits to ppl that have had puma engines pop, and they much happier with the V8 in now
    this set up going to Kenya with engine and auto with kit
ID:	628752   Click image for larger version.
    2005 Defender TD5
  9. The Following User Says Thank You to clivemd For This Useful Post:
  10. #7
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Quote Originally Posted by Hamtheman View Post
    From what I could find out, it was serviced at Land Rover while under warranty and thereafter at a reputable Land Rover indy until it was involved in an accident.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  11. #8
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Mileage?
    177000km
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  12. #9
    Mar 2007
    Harties Boet
    Thanked: 1832
    Is this a working vehicle or an everyday driver to the office and back?
    i have a theory that these fords arenít made for work. But are perfectly fine as everyday drivers and/or holiday cars.
    Graham Robertson
    Nissan Patrol 4.8
  13. #10
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Yes itís my dayly, the last 12000km was mostly 450km/day round trips.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  14. #11
    Mar 2007
    Harties Boet
    Thanked: 1832
    Quote Originally Posted by Bosvark Kzn View Post
    haha. Well there goes my theory then.
    but damn. Thatís a lot of driving!!
    Graham Robertson
    Nissan Patrol 4.8
  15. #12
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Probably injector, Iíll have them tested, but definitely not caused by the fuel I use. 50ppm and my whole fleet runs on the same diesel with absolutely no problems.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  16. #13
    Thanked: 230
    I have personally fitted the cylinder head supplied by ford on a defender, and no problems there.
    There is some minor differences between the hanging parts. But all the hanging parts can be built over from the old motor There is also no hole in the ford block for the oil level sensor, but that doesn't get used in the African climate. You can leave it unplugged.
    I haven't had the opportunity yet to fit a complete motor or sub assembly but visually looks like it would work.
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1999 Land Rover Discovery 2 V8 (Another one)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2010 Mercedes C350 CDI (The Daily)
    Ex.
    Discovery 1:TDI and a V8. Discovery 2 V8. Discovery 3 TDV6. Freelander 2 TD4, a C350 CDI and a Subaru Forester XT
  17. The Following 2 Users Say Thank You to JeandreDiedericks For This Useful Post:
  18. #14
    Jul 2010
    The Vale
    Thanked: 432
    Yeah injector I'm sure, although I've had a few 2.2 turbos let go as well, sorry,
    Ranger Wildtrak
  19. The Following User Says Thank You to Hamtheman For This Useful Post:
  20. #15
    Aug 2014
    Oppi plaas
    Thanked: 1080
    I donít think itís turbo. Lots and lots of blow-by when it idles with the oil filler cap removed.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  21. #16
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Quote Originally Posted by JeandreDiedericks View Post
    I’ll get prices from Ford and Land Rover tomorrow, I remember Land Rover quoted me something like R112k for an engine for my 2.4 Puma. But from what you saying it sounds like a Ranger engine from Ford will work?
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  22. #17
    Thanked: 230
    Iíll get prices from Ford and Land Rover tomorrow, I remember Land Rover quoted me something like R112k for an engine for my 2.4 Puma. But from what you saying it sounds like a Ranger engine from Ford will work?
    On the 2.2 I can't see any visual differences, except for the hole for the oil level sensor that isnt there. I think it will work. We took a chance on the cylinder head, there was almost a R25k difference between Ford and Land Rover's cylinder head.
    Ex.
  23. The Following 2 Users Say Thank You to JeandreDiedericks For This Useful Post:
  24. #18
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Thanks Jeandre, at the moment Iím leaning towards this option.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  25. #19
    Mar 2014
    Brakpan
    Thanked: 469
    Four wheels move the body,
    Landys move the soul.
    0735236742
    Current: Discovery 2 td5.
  26. The Following User Says Thank You to Sam vd Merwe For This Useful Post:
  27. #20
    Aug 2014
    Oppi plaas
    Thanked: 1080
    Had a busy Monday, but got a price from my local Ford dealer for a new engine, that is basically sump to tappet cover, no turbo, no injectors, have to bolt on the hanging bits from the old engine. R48k incl. v.a.t.
    I then went past my mate who owns an engineering shop and spoke to him. He quotes R45k to do a 2.2 complete, excluding injectors.
    I asked him about the failure on these 2.2 engines and the cause of it, he rebuilds dozens of them a month.
    In his opinion:
    He says he had to do a report for Ford warrantee on a Ranger with 14000km on the clock. Piston gone. That was the lowest mileage failure he dealt with.
    He also had some coming in with 300000 km on the clock, never opened, but overheated at 300000 km and found very little wear on the sleeves.
    95% of 2.2 engines going through his shop after breaking a piston, the injectors were tested to be 100%. So doesnít sound like injectors cause the failure in most cases.
    His opnion is that the Ford pistons itself is of inferior quality and he rebuild the engines with AE pistons and says not one of his rebuilt motors came back with a broken piston or hole in the piston.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
