Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 69 of 69
  1. #61
    Thanked: 323
    Default Re: These Ford engines are crap.
    it would be interesting to understand what those values mean
    on the various D3 forums they seem to post values around the 1000 mark
    i don't think that is bars of pressure
  2. #62
    Aug 2014
    Oppi plaas
    Thanked: 1156
    That’s the one thing no one can tell me. I don’t know much about common rail injectors, but I think it makes more sense to test the injector performance across the rev range, not only at idle.
    Not sure, but I also don’t think it’s bars of pressure. Maybe someone with knowledge of this stuff can help us here.
    2017 Amarok Extreme V6
    2014 Jeep Wrangler Rubicon
    2012 LR Puma 2.2
    2012 LR Puma 2.2 D/c
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  3. #63
    Mar 2014
    Brakpan
    Thanked: 523
    A normal common rail is running upwards of 1000 bar. Only returning fuel at over 1500 bar.
    Four wheels move the body,
    Landys move the soul.
    0735236742
    Current: Discovery 2 td5.
  4. The Following User Says Thank You to Sam vd Merwe For This Useful Post:
  5. #64
    Aug 2014
    Oppi plaas
    Thanked: 1156
    Fitted the new injectors last night. Genuine VDO, old injectors was Continental, which is the same as Siemens and VDO as per the research I did.
    Replaced the injector hold down bolts with new as itís strech bolts and torqued it 6nm and 180į.
    For those who may need it in future, the correct part number for the 2.2 is: 2910000177400
    The Landy sounds good and there a noticeable improvement in performance, so maybe the old injectors were shot. Iíll send it for testing (for what itís worth) Ďcos Iím keen to get to the bottom of the failure. Was it bad injectors or low quality pistons?
    Hopefully the Ford behaves now.😂
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  6. The Following 3 Users Say Thank You to Bosvark Kzn For This Useful Post:
  7. #65
    Thanked: 410
    Quote Originally Posted by Bosvark Kzn View Post
    good news, thanks for the update!
    I'm sure you will now have many happy miles and smiles!
    Defender 130
    Defender 90
  8. The Following User Says Thank You to D-tox For This Useful Post:
  9. #66
    Aug 2014
    Oppi plaas
    Thanked: 1156
    Right, so Iíve hit the 3000km mark after engine overhaul and about a 1000 km with the new injectors. So far running smooth and performance definitely better. I notice an improvement in speed uphills and generally it just feels more nippy, after replacing injectors.
    Itís on 180000km after today, so tomorrow Iíll replace all filters and the engine oil. Going forward, Iíll service at 10000km intervals and hopefully Iíll get good mileage out the Ford.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  10. The Following 4 Users Say Thank You to Bosvark Kzn For This Useful Post:
  11. #67
    Aug 2014
    Oppi plaas
    Thanked: 1156
    Right, so I’ve hit the 3000km mark after engine overhaul and about a 1000 km with the new injectors. So far running smooth and performance definitely better. I notice an improvement in speed uphills and generally it just feels more nippy, after replacing injectors.
    It’s on 180000km after today, so tomorrow I’ll replace all filters and the engine oil. Going forward, I’ll service at 10000km intervals and hopefully I’ll get good mileage out the Ford.
    7000 km today, on the overhauled engine. No problems to report at all, hope I’m not jinxing myself here, but who said these motors can’t be rebuilt successfully? Or is it too early to tell?
    2.4 I rebuilt early in the year also running 100%
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  12. The Following 3 Users Say Thank You to Bosvark Kzn For This Useful Post:
  13. #68
    Sep 2015
    Thanked: 14
    7000 km today, on the overhauled engine. No problems to report at all, hope Iím not jinxing myself here, but who said these motors canít be rebuilt successfully? Or is it too early to tell?
    Great news and you sure push the kilos
    2.25 S111 109 Pick up
    2.25 S111 109 Hard top
    3.5 110 County SW
    300 Tdi 90 Pick up
    2.2 Puma SW - current
  14. #69
    Aug 2014
    Oppi plaas
    Thanked: 1156
    Quote Originally Posted by Test Pilot View Post
    Doing waaaaay to much mileage, itís my daily at the moment, but will probably go V8 Cruiser in the new year and keep the Landy for a Sunday drive.
    2012 LR Puma 2.2
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
