Results 1 to 20 of 35
Thread: Camping oven
    Oct 2017
    Rustenburg
    Thanked: 8890
    Default Camping oven
    Anyone got an idea what I can look at that can be used as or is a camping oven:
    Something small, that can either work with 12v or gas (I have a WeberQ)
    I was thinking of something like the road chef, but that does not require me to offer my nuts for adoption to pay for it
    Andrew van Staden
    FJ - 2 Batteries, a tow bar, OME, Good Year Adventurers, and a drawer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
    Oct 2017
    Rustenburg
    Thanked: 8890
    Default Re: Camping oven
    Has anyone got experience with this one: Alva gas canister oven
    Andrew van Staden
    Ex:
    Robertson/ Larissa, Greece
    Thanked: 5637
    Something small, that can either work with 12v or gas (I have a [email protected])
    Do you really think R4400 is too much? I won't ever buy one since it is not something I will use, but it sounds reasonable in today's crazy world.
    Or am I way out of touch?
    Thanked: 205
    We have a Kexin gas stove / oven. Very light, not to big, but don't know if they are still available locally.
    - Leonardo Da Vinci
    Also on
  5. The Following User Says Thank You to Rooikop For This Useful Post:
    Oct 2017
    Rustenburg
    Thanked: 8890
    That oven is TINY (two pies - max - mammas pies) And then you wait minimum 2 hours for them to cook
    Andrew van Staden
    Ex:
  7. The Following User Says Thank You to Hedgehog For This Useful Post:
    Thanked: 2293
    I am assuming the [email protected] = WeberQ?
    We have done roast leg of lamb, roast chicken, muffins and bread in our Weber Q's. We have the Q1200 as well as the Q200, I soon realised the error of my way with the Q200 and and immediately converted it to the Q220 by buying the lid complete with thermometer.
    Oct 2017
    Rustenburg
    Thanked: 8890
    Yes thanks, I fixed my post
    I use the Q a lot, but it's not the same as an oven
    Andrew van Staden
    Ex:
    Sep 2014
    Thanked: 71
    Thumbs up Re: Camping oven
    We have almost the same one except ours have the 2 burners on top and runs off a normal cylinder. Ours is quite heavy but solidly built. Imho the canisters should last for one baking session maybe 2 ? You do have pre heat and then watch the thermostat constantly in order to keep the temperature constant otherwise you are going to burn your bread/scones or chicken. Otherwise worth it
  11. The Following User Says Thank You to Duke1098 For This Useful Post:
  12. #9
    Jun 2015
    Pretoria East
    Thanked: 1369
    Do I assume it needs to be 12V Andrew?
    Thus the ability like the Auzzies to cook/heat your food whilst driving, ready for when you "In darkness we find camp"
    Then gas is not an option.
    Dirk Theron - Life's a journey, enjoy the ride!
    18 Land Cruiser FJ - build to play
    19 Hilux 2.8 GD-6 Auto 4x4 - my best overland build ever
    2013 LC 200 4.6 Petrol V8 - Ex. The best car I have owned, apart from its thirst
    2014 LC 79 V8 - Ex
    2001 LC 105 4.5 EFI - Ex
    2013 FJ Cruiser - Ex
    1996 LC 80 UK spec VX 4.5 EFI auto - Ex
    2001 Jeep TJ 4L - Ex
    2006 Jeep Cherokee - Ex
    1989 LC Bundera 1KZ-TE 3L auto - Ex
    1996 Nissan Sani DC 4x4 - Ex
  13. #10
    Oct 2017
    Rustenburg
    Thanked: 8890
    Quote Originally Posted by DCTheron View Post
    12v is the option but gas would be preferred. I would like a quicker oven that the one you are referring to..
    Andrew van Staden
    Ex:
  14. The Following User Says Thank You to Hedgehog For This Useful Post:
  15. #11
    Thanked: 2293
    We have a small gas oven in our Jurgens Caravan at the Vaal Dam. I prefer the WeberQ due to the size. It is more difficult to control the temperature in the caravan oven due to the size and the location of the burner. It get hot real quick. Potato bakes are continually burnt at the rear where the burner is, too much effort to keep opening the oven and rotating. Muffins come out better in the Q.
    Not suggesting that you don't use the correct gear but using the correct trivet and the correct aluminium foil base we find that the Q operates well enough as an an oven to not want to buy another.
  16. #12
    Oct 2017
    Rustenburg
    Thanked: 8890
    Any suggestions on that foil base and trivet.. Weber does not sell them in SA anymore
    Andrew van Staden
    Ex:
  17. #13
    Addo
    Thanked: 335
    Ive got the gasburners that works with the canisters , the problem that I have is that when its cold the cannister does loose pressure and the flames dies , then you need to warm the cannister again to work , that is frustrating , in warm wheather its ok
    Range Rover Sport SC 4.2 V8 ( FATBOY )
    Disco1 V8 ( LAZYBOY )
    Austin Mini 1380cc ( Finiky )
  18. #14
    Oct 2017
    Rustenburg
    Thanked: 8890
    Quote Originally Posted by lazyboy View Post
    Ive got the gasburners that works with the canisters , the problem that I have is that when its cold the cannister does loose pressure and the flames dies , then you need to warm the cannister again to work , that in frustrating , in warm wheather its ok
    If the canisters "freeze" up, then they are not properly "seated" on the nozzle connection
    Andrew van Staden
    Ex:
  19. #15
    Apr 2011
    Thanked: 216
    I have a Defy Traveller that is perfect but only gas
    I see there is one on FB Marketplace for R700
    Hou op om almal altyd gelukkig te probeer hou, Jy is nie n braaibroodjie nie
  20. #16
    Addo
    Thanked: 335
    The seating is good , they not freezing but getting very cold , got three of the burners , all three doing the same , a bitch on a cold morning the get your water to boil ,
  21. #17
    Oct 2017
    Rustenburg
    Thanked: 8890
    Quote Originally Posted by spicydave View Post
    Is it as big as it looks?
    Andrew van Staden
    Ex:
  22. #18
    Jan 2009
    Oral
    Thanked: 1035
    You don't say what you want the oven for. I fin that a simple cast iron pot works well. Just put a grid in the bottom depending on what you are heating.
    C
  23. #19
    Apr 2011
    Thanked: 216
    420mm (W) x 480mm (H)
  24. #20
    Oct 2017
    Rustenburg
    Thanked: 8890
    that is quite compact
    Andrew van Staden
    Ex:
