Results 1 to 20 of 20
    Nov 2020
    Default Trailer tyre advice
    I recently bought a trailer, but the problem is that it is too high for my vehicles tow ball, so it sits leaning down when towing. It has quite large tyres, 75 profile. So my question is, if I reduce the profile to say 60, will I get the full reduction at the nose, or is there anything that I am missing. Note that these tyres are not standard, the previous owner fitted them because he did a lot of off-roading.
    Is there anything else that I could do to reduce the height?
    I would prefer to make the adjustments on the trailer rather than the vehicle, so things like drop plates etc are out of the question.
    Rangeview Krugersdorp
    Thanked: 1772
    Default Re: Trailer tyre advice
    Change tyres but should always be slightly nose down.
    Ford Figo 2016
  3. The Following User Says Thank You to duncang For This Useful Post:
    Thanked: 808
    I guess it depends on how nose down it is, but like duncang said, nose down is good, nose up is a problem. Perhaps you can provide more details on the trailer/tow vehicle? I agree with changing the trailer instead of the vehicle though.
  5. The Following User Says Thank You to Commander For This Useful Post:
    Thanked: 2546
    You could look at a spring over vs spring under conversion, but that would assume that there is space between the leaf springs and the chassis? Assuming it has leaf springs. You could look at mounting the tow coupling higher? Ie mount it on some square tubing etc that would get things back into a even keel? I am assuming a relatively light trailer. If it is heavy then any such changes need to be thought through properly and engineered appropriately.
    Smaller rims and tyres? Air Springs. So many options.
    Do you have any photos of the rig attached to tow vehicle? This would assist in better understanding how much you need to lower the trailer and how big the trailer is?
  7. The Following User Says Thank You to stephenplumb For This Useful Post:
  8. #5
    Apr 2014
    Thanked: 168
    Before changing to many things, go to a tyre size calculator website (just google tyre size calculator) and check how much lower the 60 profile tyre will be compered to the 75 profile. Half of that will be your axle drop and maybe its all you need.
  9. The Following 2 Users Say Thank You to 340 For This Useful Post:
  10. #6
    Thanked: 2106
    You supplied a bit too little info regarding the exact problem, such as measurements etc.
  11. The Following User Says Thank You to Spiceman For This Useful Post:
  12. #7
    Mar 2017
    Okahandja
    Thanked: 1094
    What was the standard tyre size. A picture might also help. What tow vehicle are you using. Maybe a drop plate will solve the problem.
  13. The Following User Says Thank You to Erwin Schimper For This Useful Post:
  14. #8
    Thanked: 2106
    Quote Originally Posted by Erwin Schimper View Post
    OP said drop plates are out of the question.
  15. The Following User Says Thank You to Spiceman For This Useful Post:
  16. #9
    Jul 2010
    Pinetown
    Thanked: 2781
    He said no drop plate type solution (Not sure why since that may be the simplest solution.
    Yes - that means that he needs to change something on the trailer.
    More info. needed to help with any sensible tips.
    Peter Hutchison
    Platkar = Chevy Spark 1.2
  17. #10
    Apr 2014
    Thanked: 168
    Quote Originally Posted by Peter1949 View Post
    Drop plate will increase the problem, his trailer hook is too high!
  18. #11
    Thanked: 2106
    Quote Originally Posted by 340 View Post
    I used a drop plate on a Ford Laser. I raised the gooseneck. I guess the item is called "drop plate" but one can use it for a "raise plate" or "lift plate" also.
  19. The Following 3 Users Say Thank You to Spiceman For This Useful Post:
  20. #12
    Mar 2017
    Okahandja
    Thanked: 1094
    Maybe it should be call adjustmant plate. It can be used to lower of raise plate. It works up or down posistion. I have seen with 4 hole and 6 holes.
  21. #13
    Mar 2014
    Brakpan
    Thanked: 488
    If you go with changing tyre ratios remember to get rated tyres. Insurance wants it like that
    Four wheels move the body,
    Landys move the soul.
    0735236742
    Current: Discovery 2 td5.
  22. #14
    Thanked: 2182
    Quote Originally Posted by Sam vd Merwe View Post
    Please excuse my ignorance, but what is this rating for - c rated for commercial? And why is it required?
    Stephan G
    4x4: 2018 Isuzu KB250 D-Teq 4x4 DC
    Platkar: 2019 Suzuki Baleno GLX
    "All of us get lost in the darkness. Dreamers learn to steer by the stars"
  23. #15
    Thanked: 1017
    Quote Originally Posted by stephenplumb View Post
    You need to mount the coupler lower to make the nose higher - which is usually a tad more difficult than raising the coupler on a pedestal.
    The 60 and 75 are aspect ratios of the width of the tyre. So if this is a 245, the height changes from 75% of 245 to 60% of 245. That's 36 mm. If the tyre is narrower like a 205, then the difference is 30mm.
    Look at raising the axle, the points to consider here are how much travel you have under trailer. If you have lots, maybe the leafspring mounts can be shortened, leafsprings can be flattened, or as mentioned, just fit the axle above the leafsprings.
  24. #16
    Mar 2014
    Brakpan
    Thanked: 488
    Quote Originally Posted by Groenman View Post
    Yes. Its commercial. Loadrating is much higher and blowouts is less. Make sure by your insurance first. My friend had a claim rejected because of that
    0735236742
  25. #17
    Nov 2020
    Thanks for all the replies thus far. It's clear that without pictures, the solutions will be difficult to arrive at. So please see attached. It might not look very tilted, but while I am driving, i can see the entire roof of the trailer.<br>Size of the tyre is 30x9.50R15
  26. #18
    Thanked: 56
    I would leave it as is - looks fine to me.
    My previous vehicle had the trailer towing basically level. Since changing the vehicle my trailer tows nose down (Like yours) and it is seems way more stable on the road.
  27. The Following 2 Users Say Thank You to Ingetrap For This Useful Post:
  28. #19
    Nov 2020
    Reason being that from what i've heard and read is that the towball height is determined in accordance with the position of the chassis, so moving it up or down changes the direction of the forces placed thereon. I know that much cleverer people than myself have done the calculations and in their opinion (which may be right) it will be fine, but I would prefer to tweak the cheaper of the 2.
  29. #20
    Thanked: 808
    I also think that looks fine, but if it bothers you changing the tires would probably be the easiest way to go.
    The internet tells me 30/9.5R15 is roughly equivalent to 235-75R15, so it would depend on how much lower the trailer needs to sit, I can't really comment on that based on the photo. Perhaps you can measure the distance from the A-frame to the ground once hitched, then unhitch and adjust the A-frame height using the jockey wheel until it looks right to you (remember some downward angle is needed), then remeasure and find the difference. Once you have the result (eg. 20mm) you can look for a tire that will have a diameter reduction of double that (40mm).
    Here are some examples:
    235-75R15 --> 28.8" --> 0 reduction = 0
    225-70R15 --> 27.4" --> 1.4" reduction = 17.5mm
    205-65R15 --> 25.5" --> 3.3" reduction = 41.2mm
    205-60R15 --> 24.7" --> 4.1" reduction = 46.1mm
    etc.
    Use a tire size calculator to get to the size you need, I would recommend you don't reduce the profile too much as trailer tires usually have as high a profile as possible. It would be a good idea to find out if your local tire shop would be willing to fit the tire and then see if the trailer sits right behind your car before committing to buying.
    I use this tire size calculator, but there ae many good ones out there:
    https://www.1010tires.com/Tools/Tire...ismetric=False
