Long - Long Range tank for Defender 90
Results 1 to 19 of 19
    Mar 2007
    PTA
    Default Long - Long Range tank for Defender 90
    Hi,
    we might be doing the Desert trip in Namibia....and for this i would need to have 200L of petrol with me. Now Currently I have a Extra tank so in total I have 95 odd liters, so that leaves me with about 110L to take with.
    No the obvious choice is probally 6 Jerry cans with 3 dubble jerry can holders on the roofrack.....Problem is that Jerrycans are all of the sudden 300 bucks a pop.....so that totals R1800, 3 Dubble carriers is R1650 so in total you look at more or less R3500 for something that will live most of its life in the roof of the garage being stored.
    Is there extra long range tanks one can fit to Defender 90 2.8i's?? And I don't mean the orginal left hand side tank, I allready have one, I need extra tanks....
    My thinking is that if I can fit an extra tank somewhere for the same moola it will be much more useable item for the dollars.....
    Where can I get it ??is it something you can buy or must it be made ??
    Please I need advise.....!!!
    Thanked: 15
    Speak to 'Aubrey'...he had a 110l s/s fuel tank built into his 2.8i behind the front seats, between the wheel arches.
    Mike
    Nov 2006
    Edenglen
    Thanked: 146
    You don't want to be driving in dunes with 6 full jerrycans on your roofrack.
    Erin Bosch (082 342 1909)
    4xfagger no. GP0048
    2007 Volkswagen T5 4Motion
    Dec 2007
    Kempton park
    Thanked: 58
    I have 2 extra tanks, 35 litres each. I think they are the Frontrunner ones.(Got the vehicle with them) but basically its one on both the left and the right. With electronic pumps. Yip it does mean an extra filler hole, and a bit of a sclep when filling cause you generally have to turn the vehicle around to fill the left hand side tank.
    Freddie du Preez
    '97 Defender 90 2.8i (Lots of extras) (SOLD SADLY)
    1999 Disco II V8 Auto (SOLD)
    '07 Disco 3 TDV6 S
    08 Defender 130
    We look forward to the time when the Power of Love will replace the Love of Power. Then will our world know the blessings of peace.
    William E. Gladstone
    Mar 2007
    PTA
    Quote Originally Posted by Imvubu View Post
    Jip my point exactly......that is just not Cricket........ so how viable is it to maybe try and fit the 5 cans in the back of the landy 90 ?? maybe build bracket that bolts into the body work?
    Mar 2007
    Thanked: 25
    Quote Originally Posted by Fabfender View Post
    What did you do with your battery on the left side of the 90?
    Adriaan
    Nov 2006
    Edenglen
    Thanked: 146
    Quote Originally Posted by reniervd View Post
    Unfortunately carrying petrol inside the truck isn't a good idea either. Not much help I know.
    Frontrunner make racks that carry your jerrycans on the side against the back windows. Fabfender has them on his 90. At least with these the weight is slightly lower down, but I think that an additional tank will be your best bet. I've also seen a Defender with two jerry cans on a bracket behind the spare wheel. Not too sure about the extra weight on the back door though. It may also be possible to mount a jerry can each side of the spare at the back, as low as possible.
    4xfagger no. GP0048
    Nigel
    Thanked: 2311
    Get a 120l tank from Pioneer plastics.
    Uniglide
    +27 zero eight 2 four 95 9252
    Mar 2007
    PTA
    Ok that sounds like the answer...........now comes the questions!!
    * is this a auxilary fuel tank for the car ?? especially for Defender's?
    * you say plastic, so then I sort of assume it something you take with like jerrycans?
    * if so,where do you put it ? and how do you move the 120kg item if it is full to get the juice in the tank??
    So many questions..............
    This is really a big problem......the extra tank i can get for the 90 Defender is just to small, I have 90 liters allready and an extra tank will only add 40 odd liters. leaving me 50-60 liters short(I need to do 600km at 3-4 km/l)
    And Jerrycans on the roofrack will not work.......too much weight up there.....and jerrycans in the car will also not work.....fumes fumes............the jerrycans on the side wil be ok , but that is only 2 cans at most......need 4-5 with me.
    Nov 2006
    Edenglen
    Thanked: 146
    I may be mistaken, but I'm sure I've seen a picture of a Defender with a double Frontrunner rack on each side.
    4xfagger no. GP0048
    Nigel
    Thanked: 2311
    That 120l tank is a rectangular tank. Just put it in your load bin. Attach a pipe to the tank and either just dispence into the main tank or fill a jerry can, then put it into the main tank. Once you decide to go this route, contact me and I can give you some tips. I operate 12 of these tanks and they can get very smelly if you aren't carefull and you don't handle it right.
    Uniglide
    Sep 2008
    Germiston
    Default long tanks
    hey Guys
    frontrunner make a 110L fuel tank for the right front wheel arch, but it needs a extra pump. they do the whole installation for about R5500, just check there website
    Mar 2007
    PTA
    mmmm , ok , Only problem is this is for a Defender 90....so I have no loadbin, it will then need to be in the back with all the luggage etc. Not sure it is a good idea to have a container with 120L of petrol inside the car........
    Or will it be ok
    Quote Originally Posted by Judge View Post
    hey Guys
    Ok ,don't think it will be Front fender....having 100kg's on the right hand side of the front of the car will make for some very interesting steering !!! Those tanks are usually fitted in the rear fender......also it is for the 110 Defender and not the 90 as mine.....
    Nigel
    Thanked: 2311
    That is why I said you must talk to me first.
    Putting it with the luggage is no problem. Just some things to keep in mind.
    Put an extended breather on the tank and make it vent outside.
    Put a cigarette filter in the breather pipe. Will keep dust and wasps out.
    Put a pipe on the tank with a tap. Thus you can dispence the petrol in a controlled manner.
    Make sure that the cap has a proper seal. Else it will stink in the car.
    When I send my 2700i to Zambia, I put 4 tanks in. 120l x 4 = 480l + 80l(main tank) = 560l. That then gives me a 5,000km range. (At 80km/h)
    I use these tanks on a dayly basis and I am very happy with them. I have about 15 of them.
    Uniglide
    Mar 2007
    PTA
    Ok it seems viable in a way......so now the big question.....
    what does 1 of these containers cost ??
    what is the dimensions of the box ?? (need to check if it will fit ....)
    Jan 2009
    Ellisras
    "Is there extra long range tanks one can fit to Defender 90 2.8i's?? And I don't mean the orginal left hand side tank, I allready have one, I need extra tanks...."
    I've had a long range tank on the right hand side. 40L, with the extra filling hole on the side. That will take you to 135 L.
    2000 Defender 90 2.8i aka Kabouter
    2008 Nissan Navara 2.5 4x4
    2009 Honda TRX 680 FA
    slangie76 Guest
    another related question on this thread. how many jerry cans become a problem on top of a 90?
    Hi Renier,
    Why 200L?
    Dont mean to assume anything, but do you need that much to get between fuel stops? Sure, some places may run out of fuel, so what if you need to wait a few days? What about other people carrying extra fuel for you. Are you going alone?
    I believe 150kg is the maximum weight on the roof, i think. But dont go there.
    Where are you planning to vist, BTW?
    Nigel
    Thanked: 2311
    60 Lit FUEL TANK (Fluorinated) 840L X 360W X 220H - "HT025F"
    120 Lit WATER TANK 820 X 500 X 300 - "HT014"
    The plastic these tanks are made of is VERY stable, so the water/fuel or whatever, doesn't react with the plastic.
    I usually pay about R1,000 for the 120l tank.
    Uniglide
  1. Long range tank for triton
    By Greenhorn in forum Mitsubishi
    Last Post: 2011/02/21, 09:48 PM
  2. Ford Ranger 3.0XLT Supercab Long Range Fuel Tank
    By Cruiserboy22 in forum Ford & Mazda
    Last Post: 2011/02/03, 05:16 AM
  3. Pajero SWB, 2007, BK Model Long Range Tank
    By ekiswerner in forum Mitsubishi
    Last Post: 2010/01/04, 09:57 AM
  4. Long Range Tank transfer pump - Electronic cut-out.
    By LowRange in forum General 4x4 Discussion
    Last Post: 2009/12/14, 08:03 PM
  5. Long range tank & Exhaust
    By kaptein klaserie in forum Vehicle & Technical Chat - General
    Last Post: 2009/05/01, 03:28 PM
