Results 1 to 17 of 17
    May 2012
    Witbank
    Thanked: 240
    Default D4D Suspension Issue
    Some advise please gents...
    I've recently noticed my D4D leans to the left, see photos below, first pic shows the full weight and lean to the left, second photo vehicle is on a lift and the lean is less but still there...
    When measuring from the bottom of the rim to the bottom of the wheel arches there is a 30mm difference both front and back left.
    The vehicle is fitted with OME Constant 600, with heavier coils in the front to compenate for the winch.
    What would cause this to happen, and what is my solution? It's started to sag recently and not sure what the caused it.
    Thanks.
Name:	WhatsApp Image 2021-07-28 at 10.12.27 AM.jpg
ID:	625988   Click image for larger version.
Name:	WhatsApp Image 2021-07-28 at 10.17.34 AM.jpg
    NJ Vermaak
    Toyota Hilux 3.0 D4D | Bush Lapa Miskruier 404
    Thanked: 19868
    Default Re: D4D Suspension Issue
    Leaf springs are murtu.
    So in this case Old Man Emu Not So Constant 600.........
    How old?
    Jakes Louw
    May 2012
    Witbank
    Thanked: 240
    Was afraid of that, mur duur to replace....
    Bought the vehicle 2nd hand in 2016, suspension was done around 2014 if I remember correctly.
    NJ Vermaak
    Thanked: 19868
    Quote Originally Posted by njvermaak View Post
    oops
    only a 3 year warranty
    Jakes Louw
    Feb 2012
    Thanked: 607
    oops
    Ya but it worked for 7 years.
    @OP what is the cost to replace the leaf springs?
    Regards,
    William
    4x4 'Tuna
    Quote Originally Posted by Murray Walker
    I don't make mistakes. I make prophecies which immediately turn out to be wrong.
  6. The Following User Says Thank You to willben For This Useful Post:
    Apr 2017
    Thanked: 25
    Might be the case that only one of the leafs in the pack had broken. Might be possible to find a replacement for it
    Groot berge en lang grondpaaie
  8. The Following User Says Thank You to pietas For This Useful Post:
    Nov 2016
    Thanked: 121
    Thanks.
    How can the vehicle lean to a side when it is on a lift? (all 4 wheels off the ground and supported on the chassis rails?) Surely that points to another issue than the leafs?
    May 2012
    Witbank
    Thanked: 240
    Quote Originally Posted by willben View Post
    I have not gotten a quote to replace yet, two of the solutions was to have the leaf springs and coils reconditioned, or fit air suspension - I'm not so sure about either of these as a permanent solution... replacing the entire suspension is going to be very expensive!
    Quote Originally Posted by coetzer94 View Post
    I have no idea, I have heard of a leaf spring collapsing or coil collapsing, but both on the same side of the vehicle at the same time is suspect...when on the lift the lean should not be there as the chassis should be carrying the weight not the suspension?
    NJ Vermaak
    Nov 2016
    Thanked: 121
    Not to suspect the worst, but check your chassis to ground measurements on a few points as a precaution.
    It can also be that the supports on the lift are uneven and causes the lean in the air. If the supports are at equal height your vehicle should be perfectly level in the air.
  12. The Following User Says Thank You to coetzer94 For This Useful Post:
  13. #10
    May 2012
    Witbank
    Thanked: 240
    Thank you Coetzer, will measure and revert back.
    NJ Vermaak
  14. #11
    Pretoorsdorp (Centurion)
    Thanked: 167
    It might be the front coil pulling the nose down and raise the Right rear as well - easy to check is to swap front shocks with coils from left to right, wont be to expensive to do this exercise, then you will know where is the problem
    Easier to swap the front shocks with coils than the rear leaf springs
    I would start there to be sure where the problem is.
  15. #12
    Feb 2016
    Paarl
    Thanked: 825
    Just a question. Found this on a Isuzu once, but not sure of Hilux construction. Could it not be due to collapsed cab/bin mounting rubbers?
    2011 Honda CRV 2.4
    2012 Fiat Panda 1200
  16. #13
    Apr 2012
    Thanked: 321
    My suggestion..
    Take the vehicle to Darryl at Mikem Suspensions in Selby
    He will do a free inspection and provide advice and a solution to your problem pronto.
    Trust me, this man knows his stuff.
    RechardT
    Now- Toyo GD6 2.8- Creed
    One day is One day- Dodge Ram 6.7l TD.
    You can go anywhere you want in life as long as its in a 4x4.
  17. #14
    May 2012
    Witbank
    Thanked: 240
    Just an update....
    So I finally got around to taking the vehicle to someone who knows more than me.
    The bushes on the front shock are shot, as well as those on the rear leaf spring. They reccommended replacing front shocks, bush kit on the rear (might as well do both sides), I'm also considering doing the back shocks while we're busy.
    Question is now to replace with Old Man Emu again, or change to Iron Man... Iron Man Foam cell is the cheaper option at the moment, I'm awaiting more quotes.
    NJ Vermaak
  18. The Following User Says Thank You to njvermaak For This Useful Post:
  19. #15
    joburg
    Thanked: 649
    Those bushes on front shocks must be tightened only after settling with weight or they can fail quite quickly.
    I normally leave slightly loose quick spin around block, come back and tighten properly while still on 4 wheels.
  20. The Following User Says Thank You to sparewheel For This Useful Post:
  21. #16
    Thanked: 543
    My suggestion..
    RechardT
    I second this
    Im very happy with my fortuner on gravel.
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  22. The Following User Says Thank You to Robbief For This Useful Post:
  23. #17
    Thanked: 2495
    Quote Originally Posted by rechardt View Post
    My suggestion..
    yes - he was complaining about my amarok not siting level after he put some springs in.
    To be honest I could not see any issues, but he kept the wagon for another day or two, and was measuring the chassis and springs and all sorts of things, only to determine that it was my load bin rubbers that had collapsed as suggested above.
    Either way he would get to the root cause of the issue and I believe his solutions are every bit as good as the imported stuff.
    I have mentioned before, the engineers handbook to suspension design, sitting on the office desk, would indicate that he has matric and probably knows more that most of the armchair experts.
  24. The Following 2 Users Say Thank You to stephenplumb For This Useful Post:
