Results 1 to 9 of 9
    Jul 2017
    Thanked: 8
    Default Borehole keeps on tripping?
    I am running my borehole pump for about 10minutes, then it just drips.
    There is a little "overload" protection push button on the control box that pops out.
    Any idea where I can start?
    I have opened the control box, all seems good inside, no loose or open wires.
    Here is a picture of the control box, the overload button is on the right hand side (it is pushed in now).
    If I leave the pump for a day, it works for another 10 minutes again.
    If I push in the overload button, the pump does not start again.
    Before I pull up the pump, please give me some adivce?
    krugersdorp
    Thanked: 540
    Default Re: Borehole keeps on tripping?
    all i can think of is that pump intake is partially blocked.
    Jul 2017
    Thanked: 8
    Quote Originally Posted by jadranko View Post
    Thank you, I have seen some dirt/small stones in the tap, which I just remove.
    So I need to pull the pump?
    Thanked: 19480
    The pump is shot, blocked or else your borehole is empty.
    The overload is there to protect the pump when it is drawing too many amps. This happens either when it is broken, blocked as mentioned, or when it is running dry and therefore too fast.
    You could try replace the control box. They do get old and cause faults. But the chances are...........
    Sep 2013
    Moot, Pretoria
    Thanked: 45
    I had same issue some time ago. It was the underwater cable joint. The joint heat up and then let water in....trip the system and then hours later it will run again for some minutes. I redid the joint and working OK.
    LandRover Discovery 3 TDV6 2007
    BMW 320 D (E90) 2006
  6. The Following User Says Thank You to johanventer For This Useful Post:
    Thanked: 19480
    Quote Originally Posted by johanventer View Post
    Yes a short could also do it.
    Mar 2007
    Harties Boet
    Thanked: 1768
    Does it pump water all the way up until it stops?
    Im thinking its possibly running dry. We're at the height of our lowest water table levels now at the end of the dry season, could be that your water level is just too low there now?
    Graham Robertson
    Nissan Patrol 4.8
    King Williams Town
    Thanked: 2254
    Had a farmer with similar situation, ended up being water ingress into cable and motor. Best bet is lift out pump, inspect cable for damage and check impeller and pump for muck etc etc.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Jul 2017
    Thanked: 8
    An update here.
    So it seems it is the overload switch itself that is the issue.
    I have removed the plugs and reinserted them in again and the borehole no longer drips.
    I also pulled the pump up slowly and then slowly let it go down again.
    Thank you all for the comments.
  11. The Following User Says Thank You to McGuywer For This Useful Post:
