Results 1 to 9 of 9
    Thanked: 121
    Default Grondpad vanaf Durbanville tot anderkant Baviaanskloof
    I am planing a slow trip from Durbanville to Baviaans and then return Prince Albert, Swartberg pas. I am trying to do this all on gravel/offroad. My route at this stage is Durbanville - Greytown - Aguhlas - Malgas - Heidelberg then gravel roads North of Heidelberg until it links up with the Seven passes road. I would like some info on which gravel roads from Heidelberg. I am still busy with the route further on to Baviaans and thereafter.
    Where could I look for camping site from Heidelberg and along the 7 passes route or any nearby.
    Plan is to start mid August and return end September so it is a slow trip sightseeing is the main plan. My mode of transport is Hilux and Bush Lapa on tow.
    Thanks.
    Ben
    RY WAAR JY MAG MET PASSIE
    2009 Toyota Hilux 3.0 D4D DC 4X4
  2. The Following User Says Thank You to Whisky For This Useful Post:
    Melkbosstrand
    Thanked: 602
    Default Re: Grondpad vanaf Durbanville tot anderkant Baviaanskloof
    Ben, kyk bietjie roete van Heidelberg via Attakwas.
    Praat met eienaar by Bonnievale plaas. Hy sal jou sÍ of jy met wa Attakwas mag doen.
    Ek sal bietjie deur my ou roetes ook gaan.
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
    Melkbosstrand
    Thanked: 275
    following... because this sounds like an awesome trip!
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
    Thanked: 121
    Quote Originally Posted by Papsak View Post
    Dankie Morne,waar is die Bonnievale plaas? Jy sal my baie help indien jy vir my nog inligting kan gee.
    Groete,
    OK ek het dit gekry, ek sien dis Bonniedale 4wds.
    Ben
    Melkbosstrand
    Thanked: 602
    Ja sorry... Bonniedale.
    Somerset-West
    Thanked: 44
    Dit klink na n baie lekker trip.
    Ons het in Desember 2012 min of meer so iets gedoen.
    Somerset Wes na Struisbaai - net die kortste pad gevolg, so niks ompaaie.
    Struisbaai oor Malagas tot by Swellendam. N2 tot naby Riversdal, oor Garciaspas na Van Wyksdorp. Lekker stil grondpad waar jy nog hekke moet oop en toe maak. Naby Ladismith weer by R62 aangesluit. Net na Calitzdorp afgedraai op Red Stone Hills pad, tot by Swartbergpas en tot in Gamkaskloof. Paar dae daar gebly.
    Van daar gou n draai in Oudtshoorn gemaak vir inkopies, en oor De Rust na die Baviaanskloof. Heerlik gekamp by Uitspan, en verder in die kloof af by Kudu Kaya. Toe in die rigting van PE. Die res was maar n mak terug ry op die N2 met n lekker stop in Knysna.
    Indien ek die roete weer aanpak sal ek n punt daarvan maak om by Gamkaberg buite Calitzdorp te kamp. Klein, stil kamp (net twee kampplekke), waar dit amper voel of jy die enigste mens op aarde is.
    Nog n opsie hier naby wat baie mooi is, is die grondpaaie tussen Grabouw en Kleinmond, bv die Highlands pad. Dit is net nog n lekker draai tussen hier en Struisbaai, ens.
    Geniet dit, en kom wys die foto's!
  8. The Following User Says Thank You to Jaco vdW For This Useful Post:
    Loevenstein, Bellville
    Thanked: 529
    From Heidelberg you can take the Gysmanshoek pass over the mountain and then stick next to/ north of the mountain to the R327. This bring you close to Herbertsdale but before you get there, head east again, taking any of those back roads to George.
    Alternatively turn left on the R327 to Van Wyksdorp, Rooiberg pass and then south east across the Gouritsrivier to the R328 (beware: there are MANY gate to open and close).
    Grootvadersbosch close to Heidelberg has quite nice camping.
    Alternative routes to consider:
    - There are many interesting gravel roads between Touwsrivier and Van Wyksdorp.
    - You can drive (mostly) gravel from Malgas to Stilbaai, Gouritsrivier and Mossel Bay and then head inland from there.
    Niel
    2012 BMW F800GS
    Thanked: 121
    Quote Originally Posted by Musashi View Post
    Dankie Misashi, wil net hoor kan ek die Gysmanshoek pass doen met die BL op sleep? Plan is om by Grootvadersbosch te staan. Vandaar oor Gysmanshoek pass en dan Oos tot by George soos jy hierbo noem.
    Ben
    Thanked: 529
    Quote Originally Posted by Whisky View Post
    Ja, ek dink nie dit sal probleem wees nie. Ek het dit paar jaar laas gery maar sover ek weet is die toestand nog goed. Low range sal help om dinge stadig te kan vat maar dit is nie vreeslik tegnies nie. Die noordekant af was laas in redelike goeie toestand so as mens bo kom is dit maklik af.
    Niel
    2012 BMW F800GS
  12. The Following User Says Thank You to Musashi For This Useful Post:
