Results 1 to 5 of 5
    Jul 2013
    KB
    Default Storing LifePo4 Batteries
    It is said that these batteries should be stored at 60% SOC.
    If I store my van connected to the mains with the freezer connected and running, is the battery "in storage "?
    Feb 2013
    Thanked: 1979
    Default Re: Storing LifePo4 Batteries
    No it's not if the fridge is running off the battery, then the battery is in use.
    I actually hope Victron will put a program for this in their chargers at some point since I have the same problem. With the van standing at home plugged in the fridge runs off 230V so the battery does nothing, but the charger still keeps it full, so ideal will be a charger setting to keep a lithium battery more or less at 50 to 60% for storage.
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
  3. The Following User Says Thank You to bigboy529 For This Useful Post:
    Jul 2013
    KB
    Are there any negatives running the fridge of the battery when the van is in storage?
    Thanked: 1947
    I believe the storage period plays a big role. If you camp once a year for two weeks, I would reason that its appropriate to put the battery in storage for the other 50 weeks. Get it to 60% and put it away and forget about it for 50 weeks.
    Thanked: 1947
    Quote Originally Posted by frans k View Post
    Obviously the battery will then not be in storage but it might just be better for battery durability to keep on using it. Like a cell phone; charge-use-charge-use etc.
