Results 1 to 4 of 4
    Thanked: 257
    Default hydraulic jack repair / service
    Anyone know where in Pta I can service a large hydraulic floor jack? Seals are going, leaking oil when under pressure.
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
    Thanked: 1947
    Default Re: hydraulic jack repair / service
    Try Pretoria Hydraulic in Moot street.
  3. The Following User Says Thank You to Spiceman For This Useful Post:
    Thanked: 101
    Quick Hydraulics in Silverton will also be able to assist. We use a hydraulic supplier in Jet park. If you don't come right, PM me. Maybe we can make a plan.
    Jaco
    Isuzu KB300 DMax D/C 4x4 3" Homemade lift, Bosvark LFR Radio and free-wheel hubs.
  5. The Following User Says Thank You to jp_bez For This Useful Post:
    Dec 2014
    Thanked: 3422
    I was quoted nearly R6k to "service" an OLD 5 ton Bosal trolley jack and I ended up paying around R500 for a set of seals, another R450 to have some machining done to adapt to more modern seals and a gallon of oil from Midas.
    It still has a small leak from the pump piston chevron seal which requires re chroming and grinding of the piston, but that can wait until I'm bored enough to take it all apart again.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  7. The Following 2 Users Say Thank You to JohnnoK For This Useful Post:
