Results 1 to 4 of 4
    Jul 2021
    Default Amarok 2012 Diesel Pulley Failure
    Good evening guys,
    Have any of you ever had the diesel pump pulley ever fail/disintegrate?
    I had my cam belt replaced about two weeks ago and from what Iíve seen on YouTube the Cam Belt Pulley & The Diesel Pump Pulley are loosened in the process of changing the Cam Belt.
    Im now sitting with bent rockers and valves and the mechanic says itís not his fault but Iím of a different opinion as they worked on that pulley last. Also the mechanic says that this kind of pulley failure is quite a common problem on the Amaroks.
    Your help would be greatly appreciated.
ID:	624568   Click image for larger version.
ID:	624569   Click image for larger version.
    Robertson/ Larissa, Greece
    Thanked: 5486
    Default Re: Amarok 2012 Diesel Pulley Failure
    Never heard of this. I will bet my bottom dollar someone screwed up. Either too tight or not tight enough.
  3. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
    Oct 2012
    otjiwarongo
    Thanked: 272
    Quote Originally Posted by Steven38 View Post
    Good evening guys,
    Nog nooit van dit gehoor. Hou hom maar verantwoordelik en as jy versekering het kan hy dit daar eis. Die pulley sal nie gedek wees maar die resulting damage wel. Iemand het def iets nie reg gedoen daar. Sterkte
    2017 VW Amarok 3.0 TDi V6 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
    Thanked: 3692
    never heard of such a failure before. Most likely wasn't fastened properly, vibrated loose and the chatter broke the gear if I had to guess the sequence of events
    Anton Muller
    "That which can be asserted without evidence, can be dismissed without evidence." Christopher Hitchens.
    2020 X3 M40i
    Birkin SR20VET race car
