Results 1 to 20 of 24
    WC
    Thanked: 493
    Default Battery recommendations - please
    The auxiliary battery in the back of the Jeep needs replacing.
    The current battery is a Deltec 105ah.
    I'm not sure if I should get another Deltec and was wondering if you guys could share some advice and recommendations.
    I probably also need to invest in a smart charger so would very much appreciate advice on that too.
    2004 Jeep Grand Cherokee 4.7L V8
    WC
    Thanked: 493
    Default Re: Battery recommendations - please
    Look, I have tried doing the research and am now even more muddled; you have
    Semi deep cycle R2,500
    Agm R5,000
    Big difference!
    Then someone suggested just going with a high cycle and using driving to charge the battery as it charges quicker, but we won't be driving all the time.
    I have a CTEK 250S assuming this helps with faster charging?
    I truly wish someone would create a Sticky on batteries, I could certainly use it right about now.
    Ellisras
    Thanked: 1350
    If you are prepared to service (top up electrolyte) and the battery is in a proper box, you cannot get more robust than this:
    https://www.dixonbatteries.co.za/105...wh-327x170x240
    2014 Patrol GU 3.0CRD "teenager" in puberty - 126 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 125 000 km
    Hillcrest
    Thanked: 9304
    Quote Originally Posted by Chuckzoo View Post
    Agm R5,000
    Big difference!
    Here is your starter. - The CTEK 250S is going to help you fast charge just about any battery. Most certainly faster and better than with no CTEK 250S.
    Now get yourself either.
    A battery center starter battery for R2500.
    or
    A decent Deep Cycle Solar battery for R4500
    or
    A Second Life Lithium battery for R5000
    or
    A New Lithium battery for R8500
    You will live with any of them, and be happy, till it dies and you replace it.
    My choice would be - bite the bullet, get the BlueNova Lithium on special on this forum somewhere for about R8500 or less, or maybe this one at R5400.
    https://www.4x4community.co.za/forum...80#post4693480
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  5. The Following 4 Users Say Thank You to Fluffy For This Useful Post:
    Mar 2018
    Ellisras
    Thanked: 69
    If I may add another Or... Build a 100ah lithium battery from lithiumbatteriessa.co.za for less than R6k
    I've done it and works like bom
  7. The Following 2 Users Say Thank You to WantOnsKan For This Useful Post:
    WC
    Thanked: 493
    Thanks Dungbettle, appreciate the link. That make has come across my radar while looking at different types. Servicing it could be done when the Jeep is serviced.
    Someone also mentioned Willard.
    It seems that ordering a new battery is quite a drawn out process as so many people have reduced staff or have staff working off site, apparently an week to 10 days to get a battery unless you are in one of the larger cities/towns, which I am not.
    Hillcrest
    Thanked: 9304
    Quote Originally Posted by WantOnsKan View Post
    No stock.
    3 Land Rover V8's
    Jun 2018
    White River
    Thanked: 378
    No stock.
    This....
    Mike
    Out in the bush!
    2012 Amarok with a transfer case
    1956 Series 1 (now in boxes, Covid delayed the rebuild)
    1999 Land Cruiser 105 EFI
    Jun 2018
    White River
    Thanked: 378
    I went through this thought process a couple of months back.
    I eventually bit the bullet and purchased a blue nova off the forum. R8000, including courier. Its done two shorter trips so far. Very happy with it.
    Mike
    Out in the bush!
  12. The Following 2 Users Say Thank You to AfricainHD For This Useful Post:
  13. #10
    Mar 2018
    Ellisras
    Thanked: 69
    No stock.
    True... Might be due to transnet hack?
  14. #11
    Hillcrest
    Thanked: 9304
    Forgot about them. Probably my favorite underdog.
    My son just upgraded a golf cart with them.
    3 Land Rover V8's
  15. The Following User Says Thank You to Fluffy For This Useful Post:
  16. #12
    Ellisras
    Thanked: 1350
    Yep, but no stock at present....!!
  17. #13
    Mar 2018
    Ellisras
    Thanked: 69
    Phoned them, stock expected end of August. Sigh
  18. #14
    Ellisras
    Thanked: 1350
    Contact Dixon and get the number of the rep in your area. He will sort you out...
  19. The Following User Says Thank You to Dungbeetle For This Useful Post:
  20. #15
    Brackenfell
    Thanked: 537
    sold out. Been keeping an eye on this as well
  21. #16
    WC
    Thanked: 493
    or
    or
    or
    Thanks Fluffy for the choices will check on each.
  22. #17
    WC
    Thanked: 493
    Wow! Looks like about 90% stock is sold out! I must be good stuff.
  23. #18
    Thanked: 509
    Head on over to the camping and trailer threads.
    Lots of info there.
    I run 2x Dixons Deep Cycle in my Caravan.
    One is 3 years and the second 18 months.
    So far so good.
    Platkar 1: BMW 118 (SWAMBO)
  24. #19
    WC
    Thanked: 493
    Quote Originally Posted by Mitsu Fan View Post
    Lots of info there.
    So far so good.
    Thanks, good to know.
  25. #20
    Polokwane
    Thanked: 1109
    +1 for Dixon
    Had a few and currently using the AGM 105 DC battery as the auxiliary in my Jeep, very happy with the AGM!
    Conqueror Courage 2016
