Results 1 to 2 of 2
    Mar 2013
    Thanked: 494
    Default Pajero GEN4 SWB suspension
    Hi All
    Looking to lift my SWB v6 slightly and have subsequently had spacers made up that should lift the little paj around 55-60mm. This was due to manufacturing tolerances not being perfect as I was looking for more of a 50mm lift as Iv read 60mm is the very upper limit.
    I came across a post on another forum to use LWB rear coils and SWB diesel coils for the front of the V6. This should reduce sag when loaded etc. Has anyone tried this ?
    From the manual exerts you can clearly see the difference in coils used. I understand the front has a lift ratio of 1.8 and the rear 2.4.
Name:	GEN4 front coil stats.png
ID:	624408   Click image for larger version.
Name:	GEN4 rear coil stats.png
    Pieter Greyling
    Of all the paths you take in life make sure a few of them are dirt-John Muir
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
    Jun 2013
    Thanked: 3106
    Default Re: Pajero GEN4 SWB suspension
    Speak to Mikem and get some progressive coils, solve all the issues.
    Stranger
    BMW R1200R
