Results 1 to 11 of 11
    Nov 2020
    Thanked: 28
    Default What is Toyota wiring colour convention for Fortuner? Aux power from roof console?
    Hi
    I am hoping that my 2016 Fortuner has permanent 12V to the roof console. Photos that refer:
Name:	WhatsApp Image 2021-07-24 at 10.04.14 (2).jpg
ID:	623982Click image for larger version.
Name:	WhatsApp Image 2021-07-24 at 10.04.14.jpg
ID:	623983Click image for larger version.
Name:	WhatsApp Image 2021-07-24 at 10.04.15 (2).jpg
ID:	623984Click image for larger version.
Name:	WhatsApp Image 2021-07-24 at 10.04.15 (1).jpg
ID:	623985Click image for larger version.
Name:	WhatsApp Image 2021-07-24 at 10.04.15 (3).jpg
ID:	623986Click image for larger version.
Name:	WhatsApp Image 2021-07-24 at 10.04.15.jpg
    The cable connector has 16 pins. Colours used there are
    Black (2 places)
    Black and white
    Red (2 places)
    White (3 places)
    Pink (2 places)
    Blue
    11 pins are connected, 5 pins are not
    Any hints on what Toyota typically uses for earth (console is not earthed), ignition 12V and permanent 12V?
    Of course, a wiring diagram would be first prize!
    Thank you
    Thanked: 1942
    Default Re: What is Toyota wiring colour convention for Fortuner? Aux power from roof console
    Use a test light or multimeter and check whether you have.
    Nov 2020
    Thanked: 28
    Of course I was planning to use a test light, but I was wondering if someone can give some hints on Toyota colours.
  4. The Following User Says Thank You to Mykel For This Useful Post:
    Kathu
    Thanked: 4308
    I might be wrong but the usual Toyota standard as per my memory.
    Earth = White/Black
    Pos Switched ignition to engine controls = White/Red.
    Pos Switched Ignition ACC = Black
    Pos Black/ White after Ignition.
    Check out the black wire on your plug should be 12v pos. Not sure if its switched or permanent live. White/Black is earth or neg.
  6. The Following 3 Users Say Thank You to grips For This Useful Post:
    Nov 2020
    Thanked: 28
    Grips, that is a very useful start, thank you very much!
  8. The Following User Says Thank You to Mykel For This Useful Post:
  9. #6
    Jan 2019
    Otjiwarongo
    Thanked: 401
    Hope this helps!
    Jörg Reddig
    1995 Discovery V8 ( Thor intake system , controlled by Spitronics Mercury 2)
    Land Rover 3.9 V8 " Defender 90 " Under Construction
    2021 Hilux Legend D/CAB ( Company Vehicle)
  10. The Following User Says Thank You to JWR For This Useful Post:
  11. #7
    Nov 2020
    Thanked: 28
    Quote Originally Posted by JWR View Post
    Hope this helps!
    Hi JWR
    Thank you - that helps me understand a bit of Toyota's logic.
    I will have to rig up some LEDs on the pins to see which stay live after I have locked and exited the vehicle. (I guess the supply to the alarm unit).
  12. #8
    Nov 2020
    Thanked: 28
    Has been confirmed that the black and white striped wire is earth on pin number 3.
    The supply to the overhead lights is the red wire on pin 5. But the power there disappears a few minutes after the car is locked (to save battery).
    The only wire that stays live overnight is the white one on pin 16. This only feeds the ultrasonic intrusion detector PN 89732-71010
    It would be fantastic to find out which fuse supplies that white wire . . . . in case my 2amp extra load blows something. Still want to find out more before I sommer connect onto that circuit.
    (I am trying to power a USB outlet up at the roof console)
  13. #9
    Nov 2020
    Thanked: 28
Name:	WhatsApp Image 2021-08-03 at 10.13.34.jpg
    Job done. Power taken off the door locking system fuse (10 Amp - fuse nr. 12) in engine bay which permanently feeds the ultrasonic intruder detector in the overhead console.
  14. The Following User Says Thank You to Mykel For This Useful Post:
  15. #10
    May 2007
    Durbanville Cape Town
    Thanked: 189
    Interesting! Would you consider doing a writeup of how you did it? Parts used etc. Would be interested in doing something similar
  16. #11
    Nov 2020
    Thanked: 28
    Quote Originally Posted by bees View Post
    Most of the write up is above.
    A couple of us in Cape Town clubbed in to get these from Amazon: https://www.4x4community.co.za/forum...uth-Africa-yet
    Extended the wires and soldered them to the back of the Toyota connector as follows:
Name:	WhatsApp Image 2021-07-24 at 10.04.15 (4).jpg
ID:	625198 the pin numbers are in yellow circles. Negative soldered to pin 3. Positive either to pin 5 or 16. 16 is permanent live for door locks, clock etc. Pin 5 switches off when power to dome lights goes off to save battery drain when vehicle not occupied.
  17. The Following User Says Thank You to Mykel For This Useful Post:
