Results 1 to 18 of 18
    Mar 2020
    Thanked: 11
    Default Brake Pad Replacement - can i do it myself ?
    I`ve got a 2007 Isuzu Kb 300 Tdi double cab 4x4.
    The front brake pads needs to be replaced. So my question is wheather it can be done at home
    or is there ABS / ECU trickert that needs to be calibrated by a service centre ?
    2001 Defender 90 TD5
    joburg
    Thanked: 641
    Default Re: Brake Pad Replacement - can i do it myself ?
    No nothing fancy, easy to do yourself, but if you're unsure... it is brakes after all, so perhaps consider the R500 labor you'll pay to have them safely done money well spent.
    Oct 2017
    Vereeniging
    Thanked: 244
    Quote Originally Posted by phhenning View Post
    It is really very easy. Gooi me a PM.
    Die B staan vir Beneke
  4. The Following 2 Users Say Thank You to EtienneB For This Useful Post:
    Thanked: 106
    Brake pads should be relatively straightforward, I've always done them myself on the older vehicles I have owned. Just go slow and steady and make sure there are no bits left over when you are done assembling. I've never done the brakes on an Isuzu but my old Hilux was very straightforward and generally took an hour or less with no swearing at all!
  6. The Following User Says Thank You to Craig Van der Poll For This Useful Post:
    Feb 2012
    Sedgefield
    Thanked: 772
    Take a photo of the assembly before you pull any pins. There are retainer springs that only fit one way.
    2018 Hilux Dakar fully kitted.
    2021 Suzuli Swift 1.2 GLX Swambo's shopping trolley.
  8. The Following User Says Thank You to pwgg For This Useful Post:
  9. #6
    Jan 2020
    Thanked: 211
    if you unsure checkout a couple of YouTube videos. Bet you someone has been there and made a video. Not rocket science at all.
  10. #7
    Thanked: 101
    Very easy to do. It actually takes longer to jack up the side you want to do and remove and replace wheel.
    Drop me a PM as well and I'll help you through it.
    Jaco
    Isuzu KB300 DMax D/C 4x4 3" Homemade lift, Bosvark LFR Radio and free-wheel hubs.
  11. The Following User Says Thank You to jp_bez For This Useful Post:
  12. #8
    Jun 2008
    Terenure, Kemptonpark
    Thanked: 253
    YouTube is your friend too
  13. #9
    Mar 2020
    Thanked: 11
    Thanks all,
    Was quite easy. I did however forget to make space in the reservoir before pushing back the first piston
  14. #10
    Aug 2019
    Thanked: 398
    For R300 this little tools has been awesome. No risk of damaging the seals when pushing the piston back with a screwdriver
  15. #11
    Feb 2012
    Sedgefield
    Thanked: 772
    You don't really need the separator tool. Remove one worn pad, leave the other in place and using a big screw driver slowly push back the slave cylinder on the side you have removed the worn pad from. Put in the new pad then lever the other worn one loose, remove, push back the slave cylinder and insert the new pad.
    Have someone watching the brake fluid reservoir in the engine bay. If it looks as if it may overflow, remove some fluid with a syringe. If it was never topped up as the pads wore down it should not overflow.
  16. #12
    Aug 2020
    Oasis
    Thanked: 6367
    A G-Clamp does the trick too.
    I replaced the brake pads on my wife's polo this weekend and the G-clamp did its job perfectly.
    Edit, sorry, ek het akkas gelees, dog die tool is om die piston terug te druk.
    Willem Greyling
    "You too need a new signature" - Hedgehog
  17. #13
    Jun 2008
    Thanked: 253
    I broke the tip off a small gwala when trying to push the goete back, stuck the gwala where it was jambed in the ventilated disc, not doing anything. I'm gonna get met that thingymajic, money well spend
  18. #14
    Aug 2020
    Oasis
    Thanked: 6367
    Quote Originally Posted by LouisXander View Post
    Met geweld kan jy jou vinger...
    Willem Greyling
  19. #15
    Jun 2008
    Thanked: 253
    Ek dog di stupid ding is gebreek !! Meantime probeer ek die disk split, instede van die remskoene skuif
  20. The Following User Says Thank You to LouisXander For This Useful Post:
  21. #16
    Aug 2019
    Thanked: 398
    Quote Originally Posted by MANDREAS View Post
    Passop vir die rear discs op Volkswagens jy nodig n rewinder tool en jy moet nie die pistons terug druk nie
  22. The Following User Says Thank You to Tiaan Pot For This Useful Post:
  23. #17
    Aug 2020
    Oasis
    Thanked: 6367
    Passop vir die rear discs op Volkswagens jy nodig n reminder tool en jy moet nie die pistons terug druk nie
    Dankie, maar my vrou se polo het drom remme agter.
    Ons is cheap.
    Willem Greyling
  24. #18
    Pretoria, Hartbeesfontein
    Thanked: 1161
    Korrek, ek gebruik 'n reverse bearing puller en waterpomp tang vir die job
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
  25. The Following User Says Thank You to Tweeling For This Useful Post:
