Results 1 to 17 of 17
    Apr 2009
    Thanked: 359
    Default Viscous sheared off
    yesterday, the ultra-gauge possibly saved my engine (I Hope!!)
    temps suddenly spiked to 103, I coasted and it went to 95, stopped at the garage and water streaming out.
    Viscous sheared off, probably hit the radiator or coolant pipe, hope my engine did not take any shots...
    There was no noise at all, not even when it came off.. initially though it was a siezed bearing, but heard no lockup from the fan.. strange failure , but it had a viscous spacer fitted, could possibly have added extra stress on the fan.
    D90
    D130
    Joburg
    Thanked: 701
    Default Re: Viscous sheared off
    Wow. I hope your engine is ok. Iíve never heard of a viscous shearing off.
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Range Rover 4.4 V8 sold
    Audi A3T sold
  3. The Following User Says Thank You to Beesblaas For This Useful Post:
    Thanked: 118
    Very strange indeed. If the fan is turning, either by the engine when engaged or by the wind, then it is almost impossible to shear off like that.
    I think the spacer caused the viscous to be off balance or not butting properly. That put strain on the shaft and snapped off, or maybe a factory defect?
    2006 Defender 110 Td5
    Apr 2009
    Thanked: 359
    exactly, and if it had locked up completely there would have been a serious noise from the fan blowing, still should not be able to shear..
    and if it had come of at speed it would have sounded like the engine was falling out..
    Ai, and I just spent a shed load recently on all "hang on" parts around the engine... except a new Viscous ... sigh
    D90
    D130
    Apr 2009
    Thanked: 359
    okay, fan hit the radiator.. 8k later
    then its testing to hope the engine is still okay... holding thumbs..
    D90
    D130
    Thanked: 18110
    Quote Originally Posted by Beesblaas View Post
    Me neither. Those shafts are hard.
    Joburg
    Thanked: 701
    8k for just the radiator or radiator plus viscous?
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Audi A3T sold
    Apr 2009
    Thanked: 359
    both + coolant etc and labor
    D90
    D130
  10. The Following User Says Thank You to D-tox For This Useful Post:
    Jan 2015
    Thanked: 12
    Quote Originally Posted by Suid-Wes View Post
    Probably vibration fatigue failure from step in shaft + incorrect/ damaged radius + vibration. Lots of Tata bakkies suffered from similar failures initially
    1964 SII 88"
    1984 LR90 V8
    1998 Def 90 2.8i
    2011 Def 90 Puma
    Thanked: 118
    Quote Originally Posted by Blikkie View Post
    His "bakkie" was before it became a TATA....
  13. #11
    Thanked: 18110
    Probably why my Tata has dual electric fans............
  14. #12
    Apr 2009
    Thanked: 359
    I'm starting to wonder
    sounds like an recall upgrade from 'land rover'
    D90
    D130
  15. #13
    Thanked: 18110
    Dunno, but bloody efficient. They do draw a crapload of power.
  16. #14
    Apr 2009
    Thanked: 359
    okay, tata 130 running again!, no engine damage.. shoo, thanks Ultra Gauge!!
    labor 1300
    rad 2500
    fan 1700
    coolant + consumables 400
    so not tooooo bad ...
    D90
    D130
  17. #15
    Thanked: 18110
    labor 1300
    rad 2500
    fan 1700
    awesome. keep an eye on that coolant gauge. I assume you have a proper one?
  18. #16
    Jan 2015
    Thanked: 12
    Just avoid Tata Telcoline part number 254720150126 !!
    Where is the "viscous spacer" fitted? is it aligned?
    The fracture face should give a good indication of flaw origin/ type of failure.
    1964 SII 88"
    1984 LR90 V8
    1998 Def 90 2.8i
    2011 Def 90 Puma
  19. #17
    Apr 2009
    Thanked: 359
    yes, the digital gauge usually sits at 80 degrees, it went up to 103, then dropped to 95 when I coasted..
    the factory gauge was still wondering if it should respond
    it sheared between the actual viscous nut and the fan, the spacer is made on a lathe and balance tested .. so maybe a dodgy viscous??
    thinking of fitting a fine stainless mesh guard on the inside of the radiator, but that might be overthinking it and maybe too paranoid.
    D90
    D130
