Results 1 to 20 of 27
    Polokwane
    Thanked: 266
    Default My Disco 1 LT230 Transfer box rebuild thread
    While my gearbox is out, I'm going to open the transfer box and inspect. Clearly it has been opened in the last few years, since it isn't leaking and I can still smell the sealant on the bolts.
    I was going to just leave it, but there are two reasons why I might end up doing at the very least an inspection and seal renewal.
    1. It was a hell of a job to pull this gearbox, and I would like to do what I can in one fell swoop.
    2. This: (and a lot of these goldish particles in the oil I drained).
    New Germany
    Thanked: 1058
    Default Re: My Disco 1 LT230 Transfer box rebuild thread
    Are those copper it could be from the center diff spider gears shims only thing that is copper in the LT230,
    if you strip it you will need a new crush tube for the intermediate gear, if you change any bearing you will need to do preload with the correct shims, I had to order shim kit from UK Ashcrofts when did mine, lot of ppl just use same shims that came out and might be lucky to get the right preload
    not a hard box to strip and overhaul and full bearing kit not that bad think about 2K
    2005 Defender TD5
  3. The Following User Says Thank You to clivemd For This Useful Post:
    George
    Thanked: 16
    Will follow this thread closely. Need to fix a leak on mine-between autobox and transfer (d2 auto).
    I have a thud when selecting reverse so hopefully that is something that I can sort with shimming properly. Some clown did a rebuild of the front output shaft on the lt230, but I think he was just that, a clown.
    '99 TD5 Hardtop
    '99 TD Discovery 2 Auto
    It's a Land Rover thing... and I get it now 8)
    New Germany
    Thanked: 1058
    Oh and for the input seal get a viton seal they take the heat better then normal ones
    2005 Defender TD5
  6. The Following User Says Thank You to clivemd For This Useful Post:
    Polokwane
    Thanked: 266
    clivemd, always such useful input, thank you.
    Yes, I am suspicious about the spider if this is the original box which I think it is. I'm kicking myself for selling my old box from the previous disco, which had an uprated spider.
    Bearing and seal kit comes to about R4k now from a popular landy spares place. I was also surprised how much it went up. But still worth it.
    New Germany
    Thanked: 1058
    I donít use the paper gaskets just sealant vitor renz ( spelling) and on the bolt threads I use Wurth PTFE pipe sealant, and use Tinken bearings
    have you got the LT230 manual
    2005 Defender TD5
    Langebaanweg
    Thanked: 1830
    Ok so here is another possible explanation.
    I did some work on my rear output sharf housing, a seal I think.
    I also found some copper but it was extremely thin.
    After enquiring on a few forums, I was told that during assembly they put a very tin copper shim in some parts.
    This is apparently a sacrificial shim and only needed to ensure the correct clearance and end float.
    I can't prove it but if it is very thin I don't think it's the washers.
    Polokwane
    Thanked: 266
    Yes, I have the manual lurking on my PC somewhere...
    Polokwane
    Thanked: 266
    The piece in my photo is quite a decent chunk of copper. Just my luck.
    But all will be revealed when I have the cover off.
    Thanked: 3402
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  13. The Following User Says Thank You to JohnnoK For This Useful Post:
  14. #11
    Oct 2015
    Thanked: 159
    Hi Antvz
    I think those copper pieces is from the copper cone washers that is in the centre diff. There are 4 of those washers that are installed in the cross axles of the planetry gears withing the centre diff.
    When I opened my LT230 for a rebuild, that washers was paper thin worned, I think yours have collapsed.
    Rebuilding a LT230 is a good learning experience ahead of the R380 which is a little more complex but I agree you must use a manual just to keep track.
    I made a modification while I was working on mine with the intermediate shaft that is prone to leaking at rhe o ring end.
    I wonder if the D1 has a different gear setup as the Defender one? I always wonder about a gear ratio change in the T - case just to help the final drive a bit.
    Please post pictures as you move along, its an interesting read.
    Here are from my rebuild
ID:	622528   Click image for larger version.
ID:	622529   Click image for larger version.
    Barry Enslin
    ONE LIFE!
  15. #12
    Polokwane
    Thanked: 266
    @JohnnoK thanks, this is a good resource to have posted up on this thread.
  16. The Following User Says Thank You to antvz For This Useful Post:
  17. #13
    Polokwane
    Thanked: 266
    Quote Originally Posted by Wildkyker View Post
    Hi Antvz
    Thanks for the pics.
    The Disco has a slightly "taller" ratio than the Defender and quite a few people do this mod to give their Defender slightly longer legs.
  18. #14
    Thanked: 3402
    D1 is the same as D2, Defender & Range Rover, only ratios are different.
    Range Rover Classic has a 1:1 ratio that will stretch the legs nicely.
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  19. #15
    May 2011
    Thanked: 1124
    Edit: Have to correct myself from earlier incorrect data
    The original classic RR with LT95 4-speed gearbox with integral transfer had HR ratios of 1.174 and later 1.113
    The Vogue 4-speed manual gearbox classics had 1.1:1 HR transfer ratio, which was later changed to 1.1227 HR transfer ration for standard compression engines and 0.9962 HR transfer ratio for high compression engines. These were also LT95 inegral transfer boxes.
    When the Vogue got the LT77 5 speed manual box with LT230R transfer boxes the HR tarnsfer ratio changed to 1.192
    The closest the LT230 came to 1:1 HR ratio was when fitted behind the 3-speed Chrysler automatic, HR ratio was the 1.003.
    When 4 speed ZF auto box were fitted, LT230 HR ratio changed back to 1.192, up to 1989.
    From 1989 the Borg Warner chain driven transfer box was fitted to the classic RR, high range ratio 1.206.
    All tarnsfer boxes (LT95 integral and LT230) had 3.32 low range ratios, except for the Borg Warner with 3.244
    Mike Nieuwoudt
    '89 LR 110 V8
  20. The Following User Says Thank You to Mike N For This Useful Post:
  21. #16
    Polokwane
    Thanked: 266
    I think the shims you are talking about are the same washers the others are talking about.
    The whole thing is quite well documented on other forums and elsewhere on the Internet.
  22. #17
    Polokwane
    Thanked: 266
    So with all of the above useful information from you guys, I opened the inspection hatch in the transfer box today. There was a bit more of the copper stuff.
    All the gears looked fine. There is evidence that the whole thing has been removed and resealed at some stage in the past (so now I'm fairly sure the transfer box was done and at the same time the gearbox governor was cleaned out) - my guess is that all this was done around 2016 before the previous owner bought the car. The transfer box wasn't noisy or difficult to get into gear at all, so everything seems fine.
    With all this in mind, I did something that I really hope won't come to bite me in the near future - I closed it up again and put it back in the garage, ready for reattaching to the gearbox once I'm finished with that.
  23. #18
    New Germany
    Thanked: 1058
    Hopfully it will be ok, we have gone to 85W-140 oil now on are T-cases and Diffs
    2005 Defender TD5
  24. #19
    Thanked: 19309
    Used the same in my 110
  25. #20
    Polokwane
    Thanked: 266
    I remember an indy or two telling me they switched to this, too.
    85W140 is thicker and more heavy-duty if I understand right.
    Ironically I've just bought 10 l of 80W90 Caltex (Havoline) - have a depot in Polokwane and I've been buying all their products, from Delo 400 for the engine, their coolant, ATF and now GL5.
    I wonder if I should go back and swop it out. I've always used 80W90 in all the diffs just because this is the spec.
