Results 1 to 14 of 14
    Hillcrest
    Thanked: 9598
    Default The Worlds Simplest Solar Sun Tracker - Really
    https://www.youtube.com/watch?v=Oj1E7o7J3qc
    It really is amazing that it works.
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
  2. The Following 17 Users Say Thank You to Fluffy For This Useful Post:
  3. #2
    Thanked: 134
    Default Re: The Worlds Simplest Solar Sun Tracker - Really
    Think I know what your next 3D print build is going to be ....
    Very cool!
    Janine
    2009 Jimny
    Transfer case and Radial cup protection
    VPU - rear wheel arches
    Packing System & Roofrack
    Geolander AT's,
    Airbags & EFS shocks
    2010 Ford Bantam XLT 1.6 - Sold
    1981 Ford Cortina - but it went forever! Until stolen
  4. The Following 2 Users Say Thank You to Grise For This Useful Post:
  5. #3
    King Williams Town
    Thanked: 2316
    Now to up scale to be able to move a larger panel. My next question, what if wind is blowing, will it not split the wind ie similar to boat bow into water. Hence panel unable to turn due to wind pressure on each solar panel side.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  6. #4
    Hillcrest
    Thanked: 9598
    The trick here is to use the small tracker to track the sun, and slave a large array to it.
    Essentially you put an angle sensor on the small array and then drive a controller and motors on the big array.
    This is how big steerable things like RADAR antenna and guns work.
    3 Land Rover V8's
  7. The Following User Says Thank You to Fluffy For This Useful Post:
  8. #5
    Nov 2008
    Ellisras
    Thanked: 1381
    I would stick to a higher rpm motor coupled to a very low geared reduction box on that thingy. That should resist other loads such as wind
    2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km.
    2014 Patrol GU 3.0CRD "teenager" in puberty - 131 000 km
    2007 Echo3 Trailer "the nest" with Braked Axle fitted >60 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 125 000 km
  9. #6
    Hillcrest
    Thanked: 9598
    If you look carefully at the video that is exactly what he did.
    3 Land Rover V8's
  10. The Following User Says Thank You to Fluffy For This Useful Post:
  11. #7
    Langebaanweg
    Thanked: 1880
    Mounting it on a equatorial mount and adjusting it for your latitude it will always have maximum exposure.
    Basically how automatic telescope tracking is done.
  12. #8
    Thanked: 1184
    Perhaps the actuators commonly used can be controlled very well. That is what the CSIR are using on their solar farm next to the N4.
  13. #9
    King Williams Town
    Thanked: 2316
    Dam, didn't think of that. Again one would need a low draw /start up motor to turn the panels.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  14. #10
    Nov 2020
    Thanked: 64
    This takes me back 40 years. Used a quadrant photo diode in box with a pinhole for the sunlight, 4 lm12 opamps and two window winder motors to track both azimuth and elevation of the sun. I vaguely remember halving the field coils of the motors so that they could forwards and backwards.
  15. #11
    Thanked: 1184
    Quote Originally Posted by Jonatan View Post
    Didn't those window winders already turn both directions??
  16. #12
    Nov 2020
    Thanked: 64
    Of course they did! As I said, a vague memory. I recall that detection circuit was simple, but that I had headache with the op amps and bi direction running.
    To marry the tiny solar panel and quadrant diode ideas. You can have two panels side by side in a box and a big light hole.
  17. #13
    Thanked: 1184
    Glad to hear someone else also battled with op-amps. I have built a lot of gadgets using them as voltage comparator. Some worked well and other for different periods. Still trying to find how to hysteresis to get differential to use 1 op-amp instead of 2 for the lower and higher levels using feedback.
  18. #14
    Nov 2020
    Thanked: 64
    This is the type of simplicity I like for a solar tracker: https://youtu.be/wL9PcGu_xrA?t=370 (the whole video is awful with a lot of talking)
    Here is another: https://youtu.be/_6QIutZfsFs?t=112 (but I had my quadrants rotated at 45 degrees)
    (Ekkekan, the only semiconductor I really understood in the 70's was the op amp. And the LM12 puts out 10 Amp - enough to drive motors directly. I see it is still on the market today, but now one probably uses FETs or some other mysterious device to drive motors . . . . like in my Centurion gate motor where the drivers are hard to actually find on the control board)
