Page 3 of 3 FirstFirst 1 2 3
Results 41 to 43 of 43
    Jun 2018
    White River
    Thanked: 653
    Default Re: National Luna 12v Split Charger System
    Eish but if you forget to flip the switch back to off once you've reached your destination and keep on forgetting about it for a day or 3....
    Not a bad plan... however if I were to do it like that I would def have the positive for trigger linked to my ignition, hahahaha
    Mike
    Out in the bush!
    2012 Amarok with a transfer case
    1956 Series 1 (now in boxes, Covid delayed the rebuild)
    1999 Land Cruiser 105 EFI
  2. #42
    Thanked: 281
    I hear you. That is why I use an illuminated DC switch on the dash. So I can easily see when it is switched on.
    In fact, I normally leave it on (batteries connected) when I stop in camp to run the fridge off both batteries for a while, if I do not connect to solar, immediately. This is in order to use the starter battery a while to help the auxiliary battery before I use only the auxiliary battery for the night.
    I also use a normal starter battery as an auxiliary battery. I just monitor the batteries SOC, closely though. Also this system works for me currently and I have not experienced any starting problems in the morning. Cheap and basic.
  3. #43
    Thanked: 1052
    Quote Originally Posted by Viertrek View Post
    Good idea!
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
