Results 1 to 6 of 6
Thread: Atrac vs Trc
    Jul 2013
    White River
    Thanked: 20
    Default Atrac vs Trc
    I have a 2014 Prado 3.0D4D TX.
    I know it has Trc but does it also have Atrac. The manual is a bit vague and I have never seen a Atrac light come on.
    Does it make a big difference?
    All my previous 4X4's had diff locks.
    TIA,
    Geoffth
    Sep 2018
    Not too far from Pofadder
    Thanked: 1695
    Default Re: Atrac vs Trc
    Does it have front difflock?
    I played with the Atrac in various types of terrain now. Saturday I started climbing a sand bank at an angle till I was in a cross axle and wouldn't go further. Difflock on and it started digging in in the rear. Difflock off and Atrack on and it climbed up the bank easy peasy.
  3. The Following User Says Thank You to Bex For This Useful Post:
    Sep 2012
    Switzerland
    Thanked: 91
    I dont know the Model you drive. But look into the printed guide from toyota, how to use your car in different terrain.
    Hard to say if your rig has a center lock and probably even rear factory lockers...
    My Land Cruiser 200 is tripple locked, but with the electronic helpers I can drive very far too.
    trippin
    ___________________________________________
    Transafrica with a well equipped Land Cruiser 200
    http://transafrica2012.blogspot.com
    Henties
    Thanked: 1876
    Quote Originally Posted by Geoffth View Post
    TIA,
    Geoffth
    If it does have Atrac, there should be a button for it. It only activates when the button is pressed, you are in 4LO and at very low speeds.
    The difference between Atrac and TRC is, that TRC will try and throttle back once a wheel looses traction and might apply brakes to the spinning wheel, but the emphasis is on throttling back.
    Atrac acts purely as an electronic difflock, where a spinning wheel is braked, but power isn't cut back.
    You can easily get stuck in soft sand with TRC engaged, but Atrac will get you unstuck.
    RTFM!
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
    Jul 2013
    White River
    Thanked: 20
    My Prado has centre diff lock and no axle lockers as standard.
    The manual is very silent about Atrac or Trc as it says (if fitted).
    There is a button to turn off VSC and TRC.
    Thanks,
    Geoffth
    Oct 2017
    Rustenburg
    Thanked: 7786
    Thanks,
    Geoffth
    No button, no ATRAC. The button will say “ATRAC”
    As far as I know the TX of that year did not have it.
    Andrew van Staden
    =Anti Lockdown Activist=
    2021 FJ Cruiser
