Results 1 to 11 of 11
    Default Bush Baby trailer swaying badly
    My Venter bush baby trailer with a Howling Moon tent on top sways from side to side at around 110 km/hr, anybody have a recommendation to rectify?
    Thanked: 101
    Default Re: Bush Baby trailer swaying badly
    Dont take anything I say as actual advice or fact. I dont.
    Haval H9 2.0T AWD
    Ex 2019 Ranger DC XLT Manual 4x4
    Ex 2017 Ranger DC XL Auto 4x4
  3. The Following 2 Users Say Thank You to PsyPhin For This Useful Post:
    Jan 2019
    White River
    Thanked: 79
    Fit shock absorbers
    Thanked: 1611
    Maybe increase the weight on the towball.
  6. The Following User Says Thank You to Spiceman For This Useful Post:
    Thanked: 20
    My Bush baby has got shocks. Only sways when loaded incorrectly. Too much weight after axle. Like said above put more weight on ball. How much weight is loaded in trailer when it sways?
    Thanked: 3071
    best option is to get the weight distribution and trailer angle correct
    if you cannot do the above, or want additional margin of safety then consider a stabiliser, I use a trapezium straightliner on the car trailer and caravan and it really works.
    Anton Muller
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Henties
    Thanked: 1858
    Are you sure the wheel bearings are ok, the axle isn't bent and the brakes aren't maybe not fully released on one side?
    Things that contribute to swaying are usually a tail heavy trailer and / or a nose up attitude of trailer when towing.
    Make sure you got something like 70+ kg on the tow ball, when the trailer is loaded and it stands either level or with a slight nose down attitude when it's hooked to the tow vehicle.
    Generally the Venter BB is well enough designed that it shouldn't have a tendency to sway, unless it has been modified.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
    Thanks for all your comments, the trailer has shocks but I am sure the problem is incorrect weight distribution as it sways most when not loaded much. Appreciated thanks again
    Thanked: 71
    Quote Originally Posted by nolanrc View Post
    I have a Trapezium straighliner if you are interested. PM me.
    Thanked: 69
    Also check your tyre pressure, too low pressure and high sidewalls can also result into sway. All the best getting it sorted out. Travel safe.
    Jannie
    2017 Hilux GD6 4x4 MT
    2017 Fortuner GD6 4x4 MT
    Bush Lapa Miskruier
  13. #11
    Thanked: 369
    If it sways more when not loaded see if you can move the tent forward
    Wicus Diedericks
