Results 1 to 15 of 15
    Apr 2021
    Thanked: 16
    Default URGENT-Best Mag refurbisher in Cape Town area?
    Hi my new cars wheels are buckled and dealership needs some qoutes. Whos the best for this job?
    Mar 2007
    Harties Boet
    Thanked: 1562
    Default Re: URGENT-Best Mag refurbisher in Cape Town area?
    Brand new car?
    I dont see how its your problem to run around doing all this, this is the dealerships issue.
    Sorry, I know, no help at all, but, just saying.
    Graham Robertson
    Nissan Patrol 4.8
  3. The Following User Says Thank You to Graham For This Useful Post:
    Apr 2021
    Thanked: 155
    Brand new car?
    most likely new to the OP. Regardless, make it the dealerships problem
    Gaborone
    Thanked: 1357
    Who tampers with rims on warranty with a brand new car?
    Did you buy it that way or did you hit a curb on the test drive
    Let the dealer replace them under warranty.
    Walter Rene Gygax
    Kalahari Safari
    ORRA Call:​ WB58 | ICASA ZRF430
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
    Feb 2016
    Brackenfell, Cape Town
    Thanked: 27
    Hi
    I never had any luck to have a mag refurbished.... I have tried a couple of places in Cape Town.
    I am very petty, so usually end up buying new mags.
    Robertson/ Larissa, Greece
    Thanked: 5114
    A string of replies and not one answers the OP's question!
    I have had good service from https://www.wheelservicecentre.co.za/
  8. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
    Apr 2021
    Thanked: 16
    Thanks for the reply's
    Back story:
    Bought the car in Jozi. Not brand new but from respectable dealer. Had alignment rechecked as balancing etc was off. They messed up the alignment which was corrected however in doing so discovered that wheels are buckled. They are covering all the costs, i just need to provide them with 1 or 2 quotes.
    *Thanks Francois will give them a shout
    Feb 2016
    Paarl
    Thanked: 797
    These guys. Not the cheapest, but in your case it shouldn't be an issue. I have a guy across the road that repairs rims, but if I want a proper repair, Wheel service centre.
    2011 Honda CRV 2.4
    2012 Fiat Panda 1200
    Langebaan
    Thanked: 27
    I have used these guys before.
    http://www.magworkshop.co.za
    Better photos on https://www.facebook.com/pg/magworks...=page_internal
    Couple of very fancy cars in the photos.
    I cannot say that they are better or worse than others, but I was satisfied with the result.
    Apr 2021
    Thanked: 16
    Quote Originally Posted by rian skip View Post
    thanks got a quotes that i have forwarded to them
    magmasters
    twt through wheel collision Centre
    Mcarthy Auto Trimmers who also do wheel repairs
    wheel service centre need to remove the wheels and place it on their machine before quote can be given
  13. #11
    Gaborone
    Thanked: 1357
    Quote Originally Posted by Bira82 View Post
    Back story:
    Okay, that changes the perspective a bit, quite a bit then.
    Not a product warranty job then but a dealer warranty which is an important difference.
    As a matter of fact, I was forced twice to refurb some German Mags (Borbet that was).
    If done properly, the they can be as good as new.
    I witnessed one process where the rim was mounted on a lathe and spun at about 500 rpm, heated with a gas blow torch until it became like jelly, then the guy was using 2 wooden sticks to form the initial shape whilst spinning and cooling down. Balancing with the tyre on was no issue later.
    This was a repair after I was forced to drive the car with a flat tyre (2nd blow-out in the same night) for 10 kms on the rim in the middle of the Karoo at night.
    This was done in Kimberley after being driven back from Strydenburg to get new tyres.
    The rims are still mounted on that E34 BMW
    Walter Rene Gygax
    Kalahari Safari
  14. #12
    Dec 2018
    Thanked: 30
    Mmagmaster in Killarney Gardens all the sealers use them.
  15. The Following User Says Thank You to Landymac For This Useful Post:
  16. #13
    Feb 2016
    Thanked: 1491
    TruTurn, in Strand
  17. #14
    Apr 2021
    Thanked: 16
    TruTurn, in Strand
    Thanks, I know of TruTurn and have heard good things, however out of the way for me. All the quotes i got are within a 10km radius.
  18. #15
    Apr 2021
    Thanked: 16
    Car going into Magmasters tommorow. Thanks, will give feedback on work done
