Results 1 to 20 of 26
    Hillcrest
    Thanked: 8421
    Default I just couldn't stop myself - so I put a brake on things.
    I am building a bike.
    The bike has terrible backpedal back brakes and no front brakes.
    I have google, a few Rands and a new Gas Torch.
    Caliper brakes are useless. V-Brakes are excellent, but not as good as disks.
    The bike cant take disks cause it has two rear sprockets, one either side.
    So, lets modify a bike frame to take V-Brakes.
ID:	619384   Click image for larger version.
ID:	619385   Click image for larger version.
    ZS5KAD
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
    Thanked: 303
    Default Re: I just couldn't stop myself - so I put a brake on things.
    Kief!
    Remember to add a hole for the return spring to slot into.
  3. The Following User Says Thank You to PhlippieV For This Useful Post:
    Sep 2019
    Pretoria East
    Thanked: 1475
    Is it still going to be a bicycle by the time you have finished fiddling with it?
    Hillcrest
    Thanked: 8421
    Brazed on the threaded Hex bar - cut to size - clean - paint.
    Make adapter between V-brake mount and Hex bar.
ID:	619390   Click image for larger version.
ID:	619391   Click image for larger version.
    ZS5KAD
    3 Land Rover V8's
    Thanked: 1346
    Wouldn't it be better to have front brakes on your bike?
    You can easily change the front fork over for a unit that has mountings for a hydraulic caliper and fit a system like the mountain bikes use. On my bike I changed from the standard 110mm disc to a 130mm disc on the front. That not only gave me better ultimate stopping power but also much better feel to modulate the amount of braking depending on the surface.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  7. The Following User Says Thank You to Paul#25 For This Useful Post:
    Robertson/ Larissa, Greece
    Thanked: 5114
    Excuse my ignorance but what are caliper brakes if not discs?
    Hillcrest
    Thanked: 8421
    Oh yea of little faith.
    I have to be careful with disks on the front. Had to upgrade to a Rock Shock. People have no idea of the forces involved where the fork tube interface to the frame. If the weld on the tube isn't perfect it can fracture during heavy breaking with devastating results.
    ZS5KAD
    3 Land Rover V8's
    Thanked: 1346
    There you go Fluffy, you will be doing "endo's" in no time. Next you will need a steering damper fitted to dampen out the high speed head-shake.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
    Hillcrest
    Thanked: 8421
    Quite correct. In Bicycle terms there are three basic types.
    Caliper (what we were used to 40 years ago)
    V-Brakes (what I am adding)
    Disks - go figure
ID:	619429   Click image for larger version.
    ZS5KAD
    3 Land Rover V8's
    Hillcrest
    Thanked: 8421
    Now that you mention it.
    ZS5KAD
    3 Land Rover V8's
  13. #11
    Jul 2010
    Pinetown
    Thanked: 2591
    Traction control coming soon ?
    Peter Hutchison
    Platkar = Chevy Spark 1.2
  14. #12
    Hillcrest
    Thanked: 8421
    And the V-Brake final install.
    ZS5KAD
    3 Land Rover V8's
  15. #13
    Apr 2021
    Thanked: 155
    Disks - go figure
    just a small correction, the correct term is “cantilever” brakes, not calliper brakes. Regardless, they are pretty useless at stopping anything, amd if they just get a hint of moisture they stop working all together.
  16. #14
    Hillcrest
    Thanked: 8421
    Quote Originally Posted by Scheepers85 View Post
    A quick Google reveals
ID:	619445   Click image for larger version.
    ZS5KAD
    3 Land Rover V8's
  17. #15
    Oct 2018
    Magaliesig
    Thanked: 715
    Awesome project, Keith. Many of many talents, I see. Now how about an Arduino-based ECU?
    Rob Kirk
    Amarok V6.
  18. The Following User Says Thank You to Ama-newbie For This Useful Post:
  19. #16
    Thanked: 303
    That Schwinn frame might crack at the head tube if you ride it into a wall. At speed.
    But you will break traction or flip over the bars long before you crack it from braking forces.
    Take it from someone who tries really really hard to break every frame I ride. And those that I have broken, have all been at the seat tube, BB or rear triangles.
  20. The Following User Says Thank You to PhlippieV For This Useful Post:
  21. #17
    Thanked: 5114
    Disks - go figure
    If you will bear with me. Why is the one so much better than the other? The friction material looks the same. Do you just exert more pressure with the v brakes due to the operating mechanism design?
  22. #18
    Thanked: 1057
    V brakes have much more leverage than the cantilever brakes
  23. The Following 3 Users Say Thank You to niclemaitre For This Useful Post:
  24. #19
    Hillcrest
    Thanked: 8421
    Distance from - where it connects to the frame - to the pads.
    On the one you have a single bolt (6mm) mount at the top and the pads are about 100mm away. That's a long lever and the whole brake mechanism just buckles and twists because of the leverage.
    On the other one, each arm has a 10mm attachment point to the fame and the distance between the mount point and the pad is 2-30mm. Also the fulcrum (mounting point) has a large lever effect to the advantage of pressure on the pads.
    ZS5KAD
    3 Land Rover V8's
  25. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  26. #20
    King Williams Town
    Thanked: 1994
    Keith...
    1)Just pivot a long piece of wood onto frame ie see saw. Lift one side of wood to allow other side to scrape on ground... Friction brakes.
    2) extend soles under shoes and use that for brakes.
    Both points have saved you money so you can purchase that oxycetalene pack you wanted.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
