Results 1 to 20 of 24
    Gaborone, Botswana
    Thanked: 1672
    Default Best Marker for Metal ?
    What marker do you use to mark metal for cutting and drilling.
    The internet recommends "Sharpie Oil-Based Paint Markers" . What is the equivalent over here?
    Kobus
    durban
    Thanked: 1719
    Default Re: Best Marker for Metal ?
    Good question. I never seem to find a markie that works or lasts. Typex might work. It also depends what type of steelwork you are doing. On clean metal I use lay out blue in a can.
    Robertson/ Larissa, Greece
    Thanked: 5159
    In my appy days we marked with engineers blue and then scribed or punched the marks and lines. Or am I misunderstanding you?
    In the scrapyards they mark parts with some sort of yellow pen. There is no way you get that off!
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 2265
    Boilermaker's chalk
    Johan Maree
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    Conqueror UEV-25
  5. The Following User Says Thank You to JohanMaree For This Useful Post:
    Apr 2017
    Durban North.. my name Dudley Reid
    Thanked: 4771
    Same in my Appy ,Engineers Blue,scriber & Centre punch
    Now a permanent marker
    Gaborone, Botswana
    Thanked: 1672
    Boilermaker's chalk
    That is what I'm using now.
    Looking for something more permanent. A white/yellow permanent marker.
    Kobus
    Nov 2017
    Thanked: 268
    Still use akrut marking blue in a tube. Occasionally use spanjaard spray marking blue but prefer the akrut.
    There was a recipe of mixing alcohol, food colouring and shellac flakes, but for me it did not dry quick enough.
    Have used permanent marker pens designed for marking labels on clothes - names on kids clothes for example.
    Everything should be made as simple as possible, but no simpler.
    Thanked: 5159
    Aug 2020
    Oasis
    Thanked: 5222
    Ek gebruik nou al die afgelope 7 jaar dieselfde steekpasser, een van daai goedkopes wat mens in die Helix Oxford skoolstelletjies kry. Die punte bly skerp en maak (vir my) 'n duidelike streep op mild steel.
    Willem Greyling
    durban
    Thanked: 1719
    Quote Originally Posted by Dudleytheplumber View Post
    No Dudley . You are getting forgetful. Toolmaker appies like you and me used marking blue or dykem or prussian blue. Engineers blue is just a dark oil paint we used for things like valves or to see if bearing surfaces blued up showing full contact. You cant use engineers blue for marking out .It doesn't dry out . You are getting forgetful.
  12. The Following User Says Thank You to plunger For This Useful Post:
  13. #11
    Aug 2020
    Oasis
    Thanked: 5222
    Een van die (nee, ek is nie 'n vrymesselaar nie)
    Willem Greyling
  14. #12
    Gaborone, Botswana
    Thanked: 1672
    Ek hou daarvan om 'n 1mm lyn te trek. Dit is dan presies waar ek sny met die 1mm cutting disk.
    Kobus
  15. #13
    Aug 2020
    Oasis
    Thanked: 5222
    Dan sal die steekpasser perfek werk.
    Willem Greyling
  16. #14
    Garsfontein
    Thanked: 2328
    I use a chinagraph pencil. Works perfectly. For me at any rate.
    Ian de Villiers
    Nissan Patrol GRX 4.5
  17. #15
    Thanked: 1356
    Double post.
ID:	619009   Click image for larger version.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  18. #16
    Thanked: 1356
    I've been using these marking pens for over a year now with good results on steel and aluminum. They cost about R25 at one of the local Chinese shops. One end is 0.4mm and the other is 0.8mm. This allows for nice accuracy when needed. When marking out cut lines for the plasma cutter I use a white marking pen that is easy to see with the dark lens glasses.
    For wood a good old 0.8mm clutch pencil with HB lead is still hard to beat. Click image for larger version.
ID:	619004Click image for larger version.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  19. The Following 2 Users Say Thank You to Paul#25 For This Useful Post:
  20. #17
    King Williams Town
    Thanked: 2008
    Boilermaker's chalk
    Aka soap stone
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  21. #18
    Nigel
    Thanked: 2637
    Plenty to choose from. https://www.google.com/search?q=stee...w=1294&bih=632
    And boilermakers chalk.
    Uniglide
    +27 zero eight 2 four 95 9252
  22. #19
    Thanked: 1627
  23. The Following 2 Users Say Thank You to Spiceman For This Useful Post:
  24. #20
    Jan 2015
    Thanked: 596
    You beat me to it! I have a few of those and they work brilliantly. It takes real effort to remove the lines from these silver markers.
    The only downside of them is that the tip is very soft, so it doesn't enjoy being dropped.
    Guy B. Vergoes Houwens
    2014 LC76 4.5 V8
  25. The Following User Says Thank You to ghouwens For This Useful Post:
