Results 1 to 20 of 34
    Hillcrest
    Thanked: 8402
    Default I haven't got a wheelbarrow so I fixed my braai instead.
    I have been itching try out my new gas torch, but unfortunately I don't have a wheelbarrow.
    So I decided to fix my braai. One of the steel clips that retains the grid rusted off, so I made a new clip and brazed it in place.
    I decided not to fill the gap as the damn fluxed silver based ones are R90 each.
    Not beautiful but functional.
ID:	618845   Click image for larger version.
ID:	618846   Click image for larger version.
ID:	618847   Click image for larger version.
    ZS5KAD
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  2. The Following 3 Users Say Thank You to Fluffy For This Useful Post:
    Hillcrest
    Thanked: 8402
    Default Re: I haven't got a wheelbarrow so I fixed my braai instead.
    Some paint - I am not holding my breath.
    ZS5KAD
    3 Land Rover V8's
  4. The Following User Says Thank You to Fluffy For This Useful Post:
  5. #3
    durban
    Thanked: 1700
    Whats wrong with a bolt? I know . Its just not as much fun. We all want to know what your gas torch looks like.
  6. The Following User Says Thank You to plunger For This Useful Post:
  7. #4
    Hillcrest
    Thanked: 8402
    To what can I bolt it, oh Plunger oh Plunger, to what can I bolt it .......
    Not obvious from the pics, but there is about 20mm radius of nonethingness there.
    ZS5KAD
    3 Land Rover V8's
  8. #5
    Aug 2020
    Oasis
    Thanked: 5007
    Oom Keith, would a piece of flat 0,5mm steel plate riveted from the inside not have been easier or cheaper?
    Anyway, well done - you must be a patient man.
    Willem Greyling
  9. #6
    Thanked: 1345
    That "engine" spray paint can handle up the 200c according to my contact in the industry. SprayOn has now released a new paint that is marketed as "braai" paint and should handle 600c. Have a look for it at the better hardware suppliers.
    I've been using a new paint to spray braai's and ovens that is good for 700c. You have to use a special type of thinners with it and if you don't get the ratio correct, it looks like your spray gun is spewing candyfloss. When mixed correctly it gives great coverage and looks good when dry. Click image for larger version.
ID:	618865Click image for larger version.
    The humble person makes room for progress; the arrogant person believes theyre already there.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  10. The Following 3 Users Say Thank You to Paul#25 For This Useful Post:
  11. #7
    Hillcrest
    Thanked: 8402
    TaaaDaa - phpft
    ZS5KAD
    3 Land Rover V8's
  12. The Following 3 Users Say Thank You to Fluffy For This Useful Post:
  13. #8
    Hillcrest
    Thanked: 8402
    Quote Originally Posted by MANDREAS View Post
    Let me guess, OASIS is not near the coast.
    I found the only 3 sq mm of stuff that would shine once cleaned with a grinder.
    Besides, I have already used my pop rivet gun.
    Next stop - Creme Brulee
    ZS5KAD
    3 Land Rover V8's
  14. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  15. #9
    durban
    Thanked: 1700
    Ah .So it'd not an icy acetylene set. So you are using a small Mapp gas canister. Very useful
  16. #10
    Hillcrest
    Thanked: 8402
    I would give my left battery for an oxy. Why don't they make baby oxy set sets.
    I goggled my fingers to death on that gas burner set. Some burners are good for heating large areas but difficult to get a really hot spot, others with MAPP and a pencil beam concentrate the heat hot enough to braze, but only for small items.
    Funny thing is. I actually bought three burners, and the one in the pic is the best one for brazing and the cheapest buy far - bought from - my local MICA.
    ZS5KAD
    3 Land Rover V8's
  17. #11
    Feb 2020
    Minneapolis and Las Vegas
    Thanked: 1197
    They make a baby sized set...
    Around $300 USD here in the states
    David Vierra
    21 Toyota Tacoma 4X4 3.5L M/T
    52 Beech Bonanza
  18. #12
    Hillcrest
    Thanked: 8402
    Quote Originally Posted by AardvarkNV View Post
    Lovely. I think the problem here is that the bottles are actually on hire, you never really own them, and you need a major vendor to support the sizes.
    Don't think you get disposable size cannisters.
    ZS5KAD
    3 Land Rover V8's
  19. #13
    durban
    Thanked: 1700
    They do the porta pack which you own but swop when the gas runs out. But they are about 30 k.
    Fortunately I own one
  20. The Following User Says Thank You to plunger For This Useful Post:
  21. #14
    Apr 2014
    Thanked: 5329
    I managed to buy proper acetylene/oxygen set with cutting head 2nd hand. They are as scares as chicken teeth (as 2nd hand). SWAMBO needed one. I do not have the hard soldering nozzles but they are readily available. I cannot solder or weld. My hands were shaking before I was born. Acetylene was too hot to use. Normal home gas with correct regulator coupled with oxygen works well. It could be easier to use for soldering.
    Silver solder is good but I suspect very much overkill for the job.
    Using oxygen/acetylene welding is possible. 1984 or 1985 summer I saw steam line welded that way.
    For OP to read:
    https://www.sciencedirect.com/topics...ng/gas-welding
    Consumable is not as expensive as that silver solder
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car 8)
  22. #15
    durban
    Thanked: 1700
    Quote Originally Posted by Jouko View Post
    For OP to read:
    I think fluffy used a brazing rod.Or at least a brazing flux coated rod would get the task done. But what concerns me here is that no one has got into a fight about the fact that he repaired it. Weber braais are only R1000 So why bother and waste your time and energy trying to repair it.
    It's not like it has been souped up and can braai better😁Members have forgotten the wheelbarrow thread
  23. The Following User Says Thank You to plunger For This Useful Post:
  24. #16
    Dec 2014
    Thanked: 3155
    Save your left battery, contact your home loans people to up your bond and get a PortaPack, by AFROX. There are also similar mini kits around, but I have no idea about refilling them.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  25. #17
    Hillcrest
    Thanked: 8402
    I have been waiting for 4e to klap me on the kop.
    The rod is actually "Silver Solder Flux Coated" Working Temp 650 - 700 C
    Normal brazing rod, I just cant get up to temp. Takes a loong time, and then the weld doesn't flow properly and leaves a matt rough finish.
    ZS5KAD
    3 Land Rover V8's
  26. #18
    Feb 2020
    Thanked: 1197
    Bottles on hire here are a lot more common now and easily swapped out (but Im in a major metro area)... I much happier with hired bottles, no waiting and more importantly owned bottles have become problematic with the regulations regarding hydrostatic testing... My old O2 bottle that is owned was not worth re-testing...
    Disposables are available here in this size/style...
    David Vierra
    52 Beech Bonanza
  27. The Following User Says Thank You to AardvarkNV For This Useful Post:
  28. #19
    Hillcrest
    Thanked: 8402
    I'm think really small sets, with disposable tins like the propane gas ones used by plumbers.
    EDIT Lo and behold -
    https://leroymerlin.co.za/kit-weldin...-page-product2
    ZS5KAD
    3 Land Rover V8's
  29. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  30. #20
    Apr 2014
    Thanked: 5329
    Our 2nd hand set was one of these. Empty bottles. Filled up cheaply or they were exchanged. I cannot remember. At the time you could buy the kits at Builders for a fortune. I was a bit lucky.
    https://www.gumtree.co.za/s-afrox+portapak/v1q0p1
    Jouko
    2012 Smart
  31. The Following User Says Thank You to Jouko For This Useful Post:
