Results 1 to 20 of 23
    Kriel
    Thanked: 138
    Default Hi guys....question on winches...
    I drive a light weight Russian 4x4 and it only weigh around 1200kg...my question is...what is the proper capacity optimum size winch i should use...when laoded i dont think to exceed 1700kg's would a 2000 or 3000 or 4000 or even a 5000kg winch be good enough...?..don't wanna install a too big or too heavy winch for the car....
    Polokwane
    Thanked: 941
    Default Re: Hi guys....question on winches...
    Quote Originally Posted by John.oosthuizen95 View Post
    If you go double the vehicle's loaded weight, you will be ok.
    Conqueror Courage 2016
    Kriel
    Thanked: 138
    Quote Originally Posted by DC Polokwane View Post
    So if i install a 3500pound capacity winch i will have sufficient pulling power.. ?......then the estimate is around 1600 kg pull power on a 1200 kg vehicle....or should i rather go for 4500 pound pull power that is just over 2000 kg pull capacity...?
    I'm still new to this offroad thing so i ask before i do...
    Kriel
    Thanked: 138
    I forgot to ask...is the Runva winches any good.....?
    Okahandja, Windhoek
    Thanked: 1161
    It seems the norm is at least 3 x the empty weight.
    Runva is fine for leisure uese.
    Johan Kriel
    Polokwane
    Thanked: 941
    Most manufactures recommend 1.5x
    In Africa we go 2x
  7. The Following User Says Thank You to DC Polokwane For This Useful Post:
    Polokwane
    Thanked: 941
    I would suggest a 8000p
    Kriel
    Thanked: 138
    In Africa we go 2x
    So then a 4500 pound winch will do...thanks...
    Kriel
    Thanked: 138
    Not into really heavy offroading but when i do find myself stuck in a rudd or in some clayish mud i wanna be able to at least pull myself out...
    Kriel
    Thanked: 138
    Plus it's my daily drive as well...so wanna limit the weight i pull along...
  12. #11
    Thanked: 2029
    I would check the mass of the winch and how much you think your suspension can take.
    I had a want 8274, 8000lbs, but industrial and around 56kgs from memory. Really only any good on a land cruiser or series landrover. They are very heavy.
    THen there is a the question of Synthetic rope vs steel cable. This can make a big difference to the total mass. Also remember that you will need to add a winch plate or some means of mounting which will also add a few kgs.
    I would guess that a 6000lbs winch would be fine for your use and a snatch block will double that. Remember the winches are rated on the first layer of the drum and loose capacity quickly as they wind more line on. The snatch block lets you get more line out and halves the speed but doubles the pulling force.
    I don't think many people have had issues with Runva, but I would check if you can get spares before you commit. I purchased comeup and I know they carry spares locally.
  13. #12
    Okahandja, Windhoek
    Thanked: 1161
    In Africa we go 2x
    4x for cruiser, Real Africa 12000lb
    3x for hilux, not that hard core 9000lb
    1.5x for a daily drive in a City
    But 2x might not be too bad, just use snatch block that you can double the pulling force, if needed
    Johan Kriel
  14. The Following 2 Users Say Thank You to JLK For This Useful Post:
  15. #13
    Jul 2009
    Thanked: 384
    1200kg x 2 = 2400kg = 5291lbs
    I (personally) would probably go for a 6000lbs
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
  16. The Following User Says Thank You to SinWolf For This Useful Post:
  17. #14
    Kriel
    Thanked: 138
    I'm driving this and it has center diff lock so dont think more than 5000 pound winch is necessary...I'm not planning on getting a Land Cruiser unstuck....
  18. #15
    Kriel
    Thanked: 138
    As long as i can get myself unstuck it's good...
  19. #16
    joburg
    Thanked: 621
    Ive only ever used a winch to "unstuck" other vehicles
  20. #17
    Benoni.
    Thanked: 795
    I like it when guys ask and answer their own questions.
  21. The Following User Says Thank You to Chopped For This Useful Post:
  22. #18
    Kriel
    Thanked: 138
    Quote Originally Posted by Chopped View Post
    I came to the not more then 5000 pound winch needed conclusion based on the answers i got from this thread....i originally wanted to fit a 3000 pound winch but nou will install atleast a 4500 pound winch based on what i learned here....so my question was answered by you good guys...thanks...
  23. The Following User Says Thank You to John.oosthuizen95 For This Useful Post:
  24. #19
    Jan 2017
    Thanked: 30
    Snatch block will double or triple your pulling power. Read up a bit on that and do your sums.
    04 Discovery II V8 Auto - The Duchess
  25. #20
    Benoni.
    Thanked: 795
    Actually John, I feel like I owe you an apology. I was being a little b### and my comment was uncalled for.
    I'm sorry.
  26. The Following 2 Users Say Thank You to Chopped For This Useful Post:
