Results 1 to 10 of 10
    Secunda
    Thanked: 71
    Default Air compressor in bonnet
    I'm thinking of install a air compressor in the engine bay of my 2008 Hilux v6. I do have a 105 amp battery in already.
    What is the options with the compressor? Pump tyers and possible using a pneumatic impact wrenches tool to loos the wheel nuts.
    What is the best one without air tank (will it be able to operate pneumatic impact wrenches) Is the air pumps that is used in suspension of cars?
    potchefstroom
    Thanked: 108
    Default Re: Air compressor in bonnet
    Quote Originally Posted by Nico H View Post
    Arb compressor. But are a bit pricey but worth it
  3. The Following User Says Thank You to circe For This Useful Post:
    Thanked: 574
    Quote Originally Posted by circe View Post
    Agree. Mine is now under the bonnet for 9 years without any issues.
    www.lani4travel.com
    Louis Le Grange
    Polokwane
    Thanked: 945
    Conqueror Courage 2016
    potchefstroom
    Thanked: 108
    Mine is in a carrying case. And lives in the bakkie. I can install it but don't want to loose the compressor if i sell the bakkie
    Thanked: 1363
    Unless the compressor you install can supply a constant 4CFM (114 l/min) to 8CFM (230 l/min) at about 3bar pressure, you won't be able to use any air tools. I haven't seen any of the 12v automotive compressors that can supply anything close to that type of flow rate.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  8. The Following User Says Thank You to Paul#25 For This Useful Post:
    Postmasburg
    Thanked: 512
    No way that an under bonner air compressor would be able to power air tools without a air tank,….. even with a tank you will wait for it to be recharged at some stages of your wheel changing experience.
    JHB
    Thanked: 235
    Thanked: 6453
    Quote Originally Posted by Woolf View Post
    The ARB twin with a 4L air tank will do it but you'll hoes
    Agree, works for me for the last +- 10 years.
    Stanley Weakley.
    Toyota Landcruiser 76SW 4,2L diesel.
    Trans East Africa 2015/2016 Trip report https://www.4x4community.co.za/forum...-6-SLOW-DONKEY
    OR
    http://www.4x4community.co.za/forum/...e16?highlight= from post 315.
  12. The Following User Says Thank You to Stan Weakley For This Useful Post:
  13. #10
    Wartburg
    Thanked: 2636
    True for most. The ARB twin will come close for intermittent air tool use - it is rated at pressure, unlike the 160l/min Chinese versions. The only true air tool compressor will be a belt driven compressor.
    Mike Lauterbach
