Results 1 to 6 of 6
Thread: Carberettor
    Apr 2019
    Thanked: 66
    Default Carberettor
    Client sent me these photos and asked for a 4 hole one , i can only find a 2 hole one. Dont know which engine this is for , rover v8 carb?
    1996 300tdi Defender 110
    2017 2.4gd6 Hilux 4x4 DC Manual
    Jan 2015
    Thanked: 13
    Default Re: Carberettor
    4 Hole gasket or 4 hole carb?
    The carb is a Zenith 36IV or copy, off Series 3. Gasket is correct, the small holes go nowhere on manifold.
    1964 SII 88"
    1984 LR90 V8
    1998 Def 90 2.8i
    2011 Def 90 Puma
    2018 Amarok V6
    Apr 2019
    Thanked: 66
    Quote Originally Posted by Blikkie View Post
    4 hole carb .
    Nov 2011
    Langebaanweg
    Thanked: 1844
    Die Stromberg en Solex caburators wat op die ou V8 Landies is het 'n square gasket.
    'n Gat in elke hoek met 'n grote in die middel.
    Maar dan is dit 'n 5 gat gasket
    Thanked: 4346
    Quote Originally Posted by Niela View Post
    4 hole carb .
    You're talking Weber 34 or 36
    Ettienne de Kock
    1998 Disco Tdi
    1959 SII 88"
    197? RRC
    Apr 2019
    Thanked: 66
    Do you know where i will be able to get it?
    Edit: Was sent another photo , so just need the 4 bolt hole carb instead of the 2.
