Results 1 to 2 of 2
    Hoedspruit
    Default Help Identifying Toyota Gearbox
    Hi all.
    I have a Suzuki Samurai bush car, that's only use for filming in the bush. It has a Toyota drive train and recently a bearing seized inside the gearbox and I am trying to find a replacement box. But I have a no idea what model it is. It is mated with a 4A-GE DOHC 1600 Engine. I have attached some pictures and any advice will be highly appreciated. Thank you.
ID:	618667   Click image for larger version.
ID:	618668   Click image for larger version.
ID:	618669   Click image for larger version.
ID:	618670   Click image for larger version.
    Kathu
    Thanked: 4166
    Default Re: Help Identifying Toyota Gearbox
    Quote Originally Posted by odofad View Post
    Hi all.
    Looks like a T50 from a rwd Corolla.
  3. The Following User Says Thank You to grips For This Useful Post:
