Results 1 to 20 of 38
    May 2021
    cape town
    Default Mecer charging lithium battery
    Hi is this inverter capable of charging a 12v lithium battery?
    https://www.takealot.com/mecer-1200v...00/description
    Solved: So you dont need to go through the whole thread - Rather go with the Mecer's IVR 1200MPPT for lithium. thanks everyone for the help!
    Apr 2012
    Thanked: 23
    Default Re: Mecer charging lithium battery
    Why don't you look at the MECER 1200VA 1000W 12V with build-in MPPT they can charge leadacid and lithuim?
  3. The Following 2 Users Say Thank You to Snake Oil For This Useful Post:
    May 2021
    cape town
    Quote Originally Posted by Snake Oil View Post
    Hi snake oil thank you I didn't even see that.
    Do you have any stats on the device. I look on mecer website and they barely have a description let alone specs.
    For that price of 2k though it sounds almost too good.
  5. The Following User Says Thank You to horizon For This Useful Post:
    Hillcrest
    Thanked: 8526
    Quote Originally Posted by horizon View Post
    Here you go.
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  7. The Following 3 Users Say Thank You to Fluffy For This Useful Post:
  8. #5
    Thanked: 1045
    Here you go.
    If one Googles Mecer 1000w inverter this new unit is the 1st to come up. I think a lot of times suppliers try to push their older models.
  9. #6
    Hillcrest
    Thanked: 8526
    True, but I think they are actually quite different devices intended for different applications.
    3 Land Rover V8's
  10. #7
    Thanked: 1045
    If I was in the market for a small back up solution to include PV for the present situation for essentials this will be my choice. Self contained, strong charger, external battery/ies. In this sector it is what the Axpert is for houe/office use that includes PV.
  11. #8
    Hillcrest
    Thanked: 8526
    Look closely at the unit and you may just see it is a repackaged Axpert
    3 Land Rover V8's
  12. #9
    Thanked: 1045
    I did look at the display and saw the 3 LEDs and the various bottons but it has been reworked to look different.
    Just the price is much lower than a 12V 1kW Axpert as we it.
  13. #10
    May 2021
    cape town
    are you talking about the mecer ivr 1200mppt or axpert as you small back up solution?
  14. #11
    May 2021
    cape town
    what I did notice that fooled me at first is that the mecer ivr 1200mppt is in fact modified sine wave. Mecer just called it simulated.
    im just running WiFi laptop etc etc so modified suites me fine.
  15. #12
    Thanked: 1045
    The Mecer. Like it was indicated earlier it looks like a reworked Axpert just much cheaper being a simulated sine instead of pure sine.
  16. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
  17. #13
    george
    Thanked: 170
    Hi Ekken, that mercer seems the way to go for me if i ONLY want to power lights during shedding.
    Will this lithium battery be enough for shedding: https://pclinkshop.co.za/ups-inverte...a-12v-lithium/
    I cant see that i will pull more than 500W for all lights, and i wont have them all on in anycase. And i can add solar later.
    Or blue nova battery?
  18. #14
    Hillcrest
    Thanked: 8526
    Quote Originally Posted by ezee rider View Post
    Your best bang for the buck would be to convert to LED's.
    3 Land Rover V8's
  19. #15
    Thanked: 1045
    I would think the best bang for your buck will be to manage which lights are on during LS. 2nd will be as Fluffy suggested to make an effort to convert to LED lights. Even with a lithium and a 4hr LS you will not be able to manage pulling 500W. The inverter you asked about would be a good unit if you want to go this route at a price but it will provide a way of getting on with the normal things like charging phones, routers and low power essentials.
    Converting to 220V LEDs the easy option to get round the 500W load.
  20. The Following User Says Thank You to ekkekan For This Useful Post:
  21. #16
    george
    Thanked: 170
    Hi guys, all my lights are already LED, most are downlights, some or different type led's in the lounge, kitchen, staircase, but all LED. My 500W total draw is my estimate when they all on, it will never be like that. I recon my draw would be half that. So with that said, would the mecer lith battery 200a be enough for this per load shedding?
  22. #17
    Thanked: 1045
    Yes good for 2.5h LS but not sure if in stage 4.
  23. #18
    george
    Thanked: 170
    Thanx again Ekkekan, in your opinion is lithium really needed then, i guess 2.5 hours is fine, wonder how long it takes to charge so its ready for the next load shedding nightmare. Thanx again for all the help.
  24. #19
    Paarl
    Thanked: 517
    In order to assist you making an informed decision:
    As Amps does not give "size of storage", I assume the 200A Lithium is a printing error and that it should be 200Ah (Amp hour). At 12V this will give 200 x 12 = 2400 Wh (Watt hour). Therefore you can run say 800W for 3 hours, 400W for 6 hours, 100W for 24 hours.
    Just make sure what is meant with 200A.
    Louis Farrell
  25. The Following User Says Thank You to LouisF For This Useful Post:
  26. #20
    Thanked: 1045
    I have looked at it and if you go for the 12V Mecer IVR 1200 the battery will provide about 625Wh in a 2.5h LS. Then more than enough time to recharge using the 10A charge setting. Even for stage 4 the 5h between sessions will be enough to recharge. There will be quite a bit of reserve. Should the LS be closer than 5hrs the 25A charge setting can be used. The LS cycle will use less than 30% of the battery capacity.
  27. The Following User Says Thank You to ekkekan For This Useful Post:
