Results 1 to 3 of 3
    Feb 2017
    Default Electronic ignition replacement 4Y engine
    Has anyone installed this electronic ignition replacement for the coil and points system in a 2.2 Hilux 4Y engine? Experience and reliability and will you do it again?
    Toyota Hilux 2.2 4Y 87-94 Electronic Distributor (onlinecarparts.co.za)
    Kathu
    Thanked: 4584
    Default Re: Electronic ignition replacement 4Y engine
    I have owned several 4Y SFA with the factory Electronic dizzy. Never had a days trouble relating ignition .
  3. The Following User Says Thank You to grips For This Useful Post:
    Oct 2012
    Roodeplaat
    Thanked: 107
    I installed one one one of our firefighter bakkies old 1994 Nissan Hardbody 2.4
    Work very well starts easier,idling is better,bakkie pulls better
    Two wire installation and TDC knowledge and off you go
