Results 1 to 6 of 6
    Aug 2015
    Thanked: 365
    Default Rear wheel studs
    I have two broken wheel studs: left rear (don't ask....)
    Apparently there is no space to press the rear ones out (as there is on the front), and you need to install a new hub assembly (incl the bearing).
    Does anybody have any experience of this? I don't have a press so I am going to have to get the work done at an indy or agent.
    So far the quotes have been quite extreme. Agents want R20k!
    2007 Disco 3 TDV6 SE
    2007 Fortuner 3.0 D4D
    Joburg
    Thanked: 709
    Default Re: Rear wheel studs
    Quote Originally Posted by zoneout View Post
    What about a used hub assembly? Get a quote from LP4A.
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Range Rover 4.4 V8 sold
    Audi A3T sold
  3. The Following User Says Thank You to Beesblaas For This Useful Post:
    Joburg
    Thanked: 709
    Have a look on YouTube- there are a few videos on rear hub removal/bearing replacment. You can remove the rear hub and press new studs in.
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Audi A3T sold
  5. The Following User Says Thank You to Beesblaas For This Useful Post:
    Aug 2015
    Thanked: 365
    Thanks Beesblaas.
    Agents want to install a new hub and wheel bearing. I think they don't see separate studs in their drawings so they assume the only way to get them is by buying a new hub. At R7500.
    Apparently the studs from a P38 are the same. So they can be pressed into the old hub after its separated from the bearing/carrier and the old broken studs are pressed out. No need for a new hub at all. But I need them to press the hub out of the carrier.
    Joburg
    Thanked: 709
    Thanks Beesblaas.
    Yes you need a press but at least you can use the old hub.
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Audi A3T sold
  8. The Following User Says Thank You to Beesblaas For This Useful Post:
  9. #6
    Jul 2016
    Thanked: 629
    zoneout im pretty sure there is enuf space in there to remove the studs. take the disc off and maybe handbrake shoes. knock them out. you can buy studs at any spares shop
  10. The Following User Says Thank You to MikeBob For This Useful Post:
