Results 1 to 9 of 9
    Aug 2020
    Thanked: 34
    Default Trailer Coupling Height Increase
    Greeting all
    So I have an Tow ball to trailer coupling height issue and the system fitted to my vehicle is a fixed swan neck type so no way of fitting a drop plate. Tow Ball height 510mm, Trailer coupling 465mm = 45mm Tow Ball drop. To fix I got a 50mm Solid piece of sq bar to raise to the required height, longer ht bolts and bobs your uncle. Pics Attached. Its now perfect with a slightly nose down position. Anybody see any potential issues?
ID:	618285   Click image for larger version.
ID:	618286   Click image for larger version.
ID:	618287   Click image for larger version.
  2. The Following 3 Users Say Thank You to Battlestar For This Useful Post:
    Thanked: 1612
    Default Re: Trailer Coupling Height Increase
    I want to do the same for some time but havent come around to it yet. I believe my difference is much more.
    Apr 2014
    Thanked: 5363
    I have seen some comments about the load carrying capacity of the "original" tow hooks. I know one forum member who reinforced his.
    I found out also that there are two custom made types for Jeep: Heavy duty and something like standard. These are from a proper company. My originally supplied was useless. Broke twice.
    Worth to check the max load on those tow hooks.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car 8)
    Wilderness
    Thanked: 1462
    Personally. I would upgrade the bolts to gr10, and not use normal gr8.8. Also i would torque those bolts to max spec, with a torque wrench. The longer bolts are more prone to stretch and bend forces. I have noted that your trailer is a 750kg without run in brake. Make sure when loading, of the correct weight distribution and tongue weight. With sudden braking, you could have a ton pushing against those bolts 2 bolts.
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  6. The Following User Says Thank You to Pieterk For This Useful Post:
    Brisbane
    Thanked: 599
    Assuming those are M16 coarse thread bolts:
    Nom stress area is 157mm^2
    Proof Stress for G8.8 is~640MPa
    If you torque them to 75% utilisation which is what most torque tables work on
    If we use a code consistent coefficient of friction of 0.3
    2x157x640x0.75x0.3
    Those two bolts are good for circa five tons in friction grip before they see any bending or actual shear stress. So unless you routinely brake at more than six g I’d say you’re going to be 100%. If you were in Oz and asking for a “blue plate” for your mod, ie a certificate to put it on the road I’d give you one.
    The key is your using solid bar, swop that for SHS and the whole game changes.
    If you need a torque to achieve that utilisation let me know.
  8. The Following 5 Users Say Thank You to BruceB For This Useful Post:
  9. #6
    Aug 2020
    Thanked: 34
    Trailer is only rated GVM 500kg. Tare 320kg with 180kg payload. I recon I’m toping the scales at max 400kg. The bolts also pass through bushes in the sq tubing. They are m12
  10. #7
    Aug 2020
    Thanked: 34
    Quote Originally Posted by BruceB View Post
    2x157x640x0.75x0.3
    would be greatful for the calcs on the m12 8,8s and a torque for tightening up.
  11. #8
    Aug 2020
    Thanked: 34
    Initially I was looking at using 50mm sq tube x 2.5mm thick but it didn’t look right. Found the solid sq bar and now it’s proper sturdy
  12. #9
    Brisbane
    Thanked: 599
    Quote Originally Posted by Battlestar View Post
    So an M12 has a cross sectional area of 84.3mm^2. So just replace that in the above. You need to divide by 9.81 to get it in kg, that formula gives you N.
    Working in that you get about 2.5t of friction grip. I’m not familiar with the SANS requirements for tow bars, but that’s more than enough for Oz standards, so should be Ok for SANS as well. You should torque to ~70Nm for a galv bolt lightly oiled.
  13. The Following User Says Thank You to BruceB For This Useful Post:
