Page 3 of 3 FirstFirst 1 2 3
Results 41 to 54 of 54
  1. #41
    Sep 2014
    Rietkuil, Suurbraak
    Thanked: 36
    Default Re: Lifetime of Victron batteries
    Ok, set as per the specs, and pushed the Low Battery to 47V
    Which firmware is your (5year old?) Axpert running on?
    There is a well known 'float bug' with earlier Voltronics inverter / chargers, which results in the higher voltage absorbtion charge cycle being very short or skipped all together.
    Due to the seemingly poor performance of all 4 of your Victron gel batteries (as per Prof's charging spec sheet) I will say this could be due to incorrect charge settings, or the bug.
    Then dont forget that series battery connections such as yours, multiply voltage and not capacity (110Ah)
    110*12v = 1320Wh
    350w*(107min/60) = 624Wh
    624/1320= 47% DoD
    In 2 hours of load shedding with a 350w load, you are cycling your batteries past 50% - it seems you need more battery capacity to prevent premature battery failure.
  2. #42
    Thanked: 1038
    Quote Originally Posted by rnieckau View Post
    110*12v = 1320Wh
    624/1320= 47% DoD
    I think you need to relook at your calc. The 4 batteries have 5200Wh to 100% DOD. Thus 350x2hours=700Wh of the 5200Wh. Nowhere near 50% DOD.
    This is a 48V system not 12V.
  3. #43
    Sep 2014
    Rietkuil, Suurbraak
    Thanked: 36
    Quite right! (forgot to multiply the voltages....)
  4. #44
    Jan 2020
    Hi everyone,
    Last year in Feb the 4 x Deltec batteries that I installed with my 5kVA inverter in 2015 finally started dying.
    I then bought 4 x Victron Gel 12V-110Ah batteries, which have been perfect until now, when suddenly I started getting Low Battery Voltage alarms barely an hour into loadshedding, and with only a load of 200-300W.
    Surely these batteries should be lasting a lot longer than this? The claimed lifetime is 7 years, so did I waste R16K last year?
    Should I just bite the bullet and go LiIo?
  5. #45
    Jan 2020
    Yoi can revive the batteries by useing an old charger-charge at 15 volt 6 hours a day for a week.
    You should get 70% of the battery back
  6. The Following User Says Thank You to Jdpkruger For This Useful Post:
  7. #46
    Thanked: 1026
    110*12v = 1320Wh
    624/1320= 47% DoD
    Post 20. My point exactly. It still is only 110Ah capacity which is not enough for this setup.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  8. #47
    Feb 2016
    Thanked: 1508
    Thanks everyone for your input.
    I've been in touch with a few suppliers, and looking at Pylontech, Dyness, FreedomWon, and maybe even get rid of the current setup for a Tesla Powerwall.
  9. #48
    Feb 2016
    Thanked: 1508
    Has anyone got experience with these: https://dcpwr.co.za/wp-content/uploa...11/Battery.pdf ?
  10. #49
    Thanked: 1038
    Well the Power Wall is great but the 14kWh battery with all the goodies @ R146 000 is a bit of money.
  11. #50
    Feb 2016
    Thanked: 1508
    I think you mean R183k fully installed.
    Not cheap, but my best friend (in Parkhurst) had one installed and he can't stop raving about it.
    My only reluctance to spend this kind of money now is that we're semigrating as soon as we can travel again, so will only be in ZA for 6-4 months of the year, so a bit of a pointless capex.
  12. #51
    Thanked: 1038
    Recommended discharge is only 2880W. Some other batteries allow 4800W discharge. What is the price for the 7.5kwh battery?
  13. #52
    Feb 2016
    Thanked: 1508
    10kWh battery: R48300
    7.5kWh battery: R36230
    (VAT inc)
  14. #53
    Thanked: 1038
    No I only meant the PowerWall price. Install varies per home. I know how I would spend the R183 000
  15. #54
    Try this website for good prices on Lithium batteries/inverters www.mhn.co.za
    2019 Ford Ranger XLT Auto DC 2.0
