Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 41
Thread: Exide 105aH
    Apr 2012
    Jhb
    Thanked: 175
    Default Exide 105aH
    Is this exide deep cycle battery any good?
    all I can get where I am
    Apr 2012
    Jhb
    Thanked: 175
    Default Re: Exide 105aH
    Need to buy in the next hour.
    any comments on the battery please
    Apr 2016
    Thanked: 114
    How long is the warranty and what do they cover?
    Polokwane
    Thanked: 1102
    Price?
    Conqueror Courage 2016
    Polokwane
    Thanked: 1102
    Quote Originally Posted by RonS View Post
    Where are you?
    Apr 2012
    Jhb
    Thanked: 175
    Default Re: Exide 105aH I am in Bela Bela and the price is R2293 with a 2 year waranty.
    Okahandja, Windhoek
    Thanked: 1185
    Better than Willard and Sabbat
    Johan Kriel
  8. The Following User Says Thank You to JLK For This Useful Post:
    Aug 2010
    Thanked: 136
    Do not have experience with the deep cycle battery itself but Exide is known to me since childhood and according to the price it is not to expensive and since you are in Bela Bela go for it.
    2016 Hilux 2.8 GD6 4x4 Dc
    2021 Bushlapa Kewer 2480
    Hillcrest
    Thanked: 9216
    An old name that garners respect.
    They are made by First National Battery.
    Why Deep Cycle - can you charge it properly and easily. If OK to this, go for it, cant see you being sorry or doing much better with anything else in a similar class and price range.
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
    Apr 2012
    Jhb
    Thanked: 175
    Using it with a mecer inverter for wifi and laptop during load shedding. Therefore it needs to be deep cycle.
    but I dont know if exide makes a good deep cycle?
    Thanked: 1100
    The Exide and Raylite from Battery Centre is the same SMF100/101 made by FNB. It is also sold by Ellies. It can be deep cycled with out damage a number of times but not everyday. For normal use stay below 50% DOD.
  13. The Following User Says Thank You to ekkekan For This Useful Post:
  14. #12
    Jan 2021
    Thanked: 24
    Bought one from Battery Centre December. After 1st camp, I noticed the Victron usage over night was not that much, but battery voltage did not look lekker. Contacted the number on the battery to find out what voltage level is 50%. 12.2 was the advice, but 12.1 under load. So I tested it and got about +-21AH out of it. Well, Batery Centre said there is something wrong with my setup, so he gave me another, with advice that I will/should get full load @50% as provided. Did not hook it up at all. Straight home, on the charge a bit more, and then tested it. 27AH, of the expected 52 at 12.1V cutoff. Load at 2.5amps. Well, I got refunded. Any battery I would buy these days, I would like to test it. In comparison, I bought a second hand 240AH with my trailer. Was a year old. Same test resulted in 94AH of 120 @50%. That is almost 80% capacity at 50% or 12.1v under load.
    I know if you don't have to tools to check it, it might be tricksy, but if you can, check your battery(ies) you buy. I would.
    Cz.
    EDIT:
    If you already bought it, test it. If it is way off, take it back, else, keep it.
  15. The Following 2 Users Say Thank You to CeeZee For This Useful Post:
  16. #13
    Hillcrest
    Thanked: 9216
    Holy cow.
    3 Land Rover V8's
  17. #14
    Mossel Bay
    Thanked: 136
    Quote Originally Posted by CeeZee View Post
    Cz.
    EDIT:
    Wow theres not maybe something wrong with the test apparatus or you are really bad luck with batteries.
    2017 Hilux 2.4 SRX D/C 4x4 2012 Cross Polo [mamma s'n]
    http://travel.webshots.com/album/558867451ncpSPZ
  18. #15
    Mossel Bay
    Thanked: 136
    I'm running the same Exide now for 5 years for loadshedding on a Mecer 1200VA 720W 12V Inverter for my TV, Explora router and a light and it never let me down ..some times up to 3 hours easy.I must add that for the first 3 years loadshedding was only a handfull of times in the area I stay.
  19. The Following User Says Thank You to Lofty For This Useful Post:
  20. #16
    Jan 2021
    Thanked: 24
    Well, I think all off the above could be correct. Bad luck with batteries, faulty test apparatus, other "apparatus" faulty, et al.
    Could have been a bad batch, sitting too long, faulty meter. Well, all I can say the chap at BC and the supplier where help full over the phone. I never received a phone call back from BC. Any how. I cross checked my meter, and with old battery as per description, and if memory serves correct, with amp meter, and still use it on LiFePo4 cells to test them, etc. Calibrated? Nope, not by a long shot. But, the shot above is quite long.
    BTW, if the manufacturer reads this, and want to see some images and discussion I still have left on my phone, I'll be more than help full. This is not brand busting. They can PM me. Always good to do some quality insurance in the field, if I where in this kind of business. That's why I phoned them first to get 1st hand voltage cut-off points, after all. And, maybe I can learn a lot from this as well. Who knows?
    Previous deep cycle lasted 6 years. (Note: I never tested the capacity! Don't think there was much left to test, to be honest.)
    If it works, it works! Happy camping. Batteries can run dry, but hout, vleis en eis? Eikonna!
    Cz
    EDIT:
    Sorry, have to edit. May take on products is this day and age, Chinese or local, is not if it will fail, but when. Over the last 6 months, I dealt with 3 suppliers related to this forum, which their products/services failed. 2 of them, which one is above, stands by their product and or refunds you, or leaves you in a better place. Companies like that, you can recommend. Those that tell you to FO? Well....
  21. The Following User Says Thank You to CeeZee For This Useful Post:
  22. #17
    Apr 2016
    Thanked: 114
    How do you test the capacity of your batteries?
  23. #18
    Hillcrest
    Thanked: 9216
    He uses the wrong voltage to make the wrong conclusion using an uncalibrated meter and the wrong method.
    Did you see my holy cow comment just above.
    3 Land Rover V8's
  24. #19
    Thanked: 1100
    I am not so sure that the uncalibrated meter would read 1 value on a battery and a different value on another.
    This test can easily be done on the suspect battery and a benchmark unit.
    I had a similar experience years ago buying 2 x 7Ah batteries from the same place on the same day. Both charged the same. Same load test and 1 gave a capacity close to spec and the other less than 50%.
    I took it back within 7days and the major seller of inverters, panels etc refused to even do any test and I had to foot the bill. Not good enough from a customer service point of view.
    Also tested with uncalibrated Fluke multimeter know to be accurate. It was compared to a Fluke 45 dual display.
  25. #20
    Hillcrest
    Thanked: 9216
    Question Re: Exide 105aH
    He is making a decision on a battery state where 0.1V error is a life or death situation.
    There is a huge difference between a 7AH SLA from China produced by the millions, made in probably a 1000 factories of unknown origin, supplied by a dubious supply chain,
    AND
    Two large expensive batteries from a single source premium Brand name exhibiting the same almost impossible fault.
    3 Land Rover V8's
